Pourriez vous intégrer ce spot au plugin zigbee ? Disponible chez ali express et 100% compatible Philips Hue, pour ma part, il s’agit de la version 9W, je ne sais pas si les autre dimensions sont compatibles.
https://fr.aliexpress.com/item/1005002589543259.html?spm=a2g0s.9042311.0.0.5a986c37byze7s
Merci beaucoup
"ieee": "00:12:4b:00:23:4c:68:55",
"nwk": 30552,
"status": 2,
"lqi": "176",
"rssi": "-56",
"last_seen": "1623417377.3030934",
"node_descriptor": "01:40:8e:00:00:50:a0:00:00:00:a0:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 528,
"profile_id": 49246,
"manufacturer": "eWeLight",
"model": "ZB-CL01",
"output_clusters": [],
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 13
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "eWeLight"
"id": 5,
"name": "model",
"value": "ZB-CL01"
"id": 6,
"name": "date_code",
"value": "20201216"
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "1.0.13"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"name": "Level control",
"attributes": []
"id": 768,
"name": "Color Control",
"attributes": []
"id": 13,
"status": 1,
"device_type": 57694,
"manufacturer": null,
"model": null,
"id": 4096,
"name": "LightLink",
"attributes": []
"input_clusters": [
"id": 4096,
"attributes": []
"signature": {
"model": "ZB-CL01",
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 0,
"maximum_buffer_size": 80,
"maximum_incoming_transfer_size": 160,
"server_mask": 0,
"maximum_outgoing_transfer_size": 160,
"endpoints": {
"1": {
"device_type": 528,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768
"13": {
"input_clusters": [
4096
4096
"class": "zigpy.device"
