Demande d’ajout Projecteur extérieur blanc Philips
Serait-il possible d’ajouter ce projecteur exterieur blanc Philips.
    "ieee": "00:17:88:01:09:84:2a:b5",
    "nwk": 42984,
    "status": 2,
    "lqi": "None",
    "rssi": "None",
    "last_seen": "1652122084.795",
    "node_descriptor": "01:40:8e:0b:10:52:80:00:00:2c:80:00:00",
    "endpoints": [
            "id": 11,
            "status": 1,
            "device_type": 257,
            "profile_id": 260,
            "manufacturer": "Philips",
            "model": "1743630P7",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 2
                            "id": 1,
                            "name": "app_version",
                            "value": 2
                            "id": 2,
                            "name": "stack_version",
                            "value": 1
                            "id": 3,
                            "name": "hw_version",
                            "value": 0
                            "id": 4,
                            "name": "manufacturer",
                            "value": "Philips"
                            "id": 5,
                            "name": "model",
                            "value": "1743630P7"
                            "id": 6,
                            "name": "date_code",
                            "value": "20190529"
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                            "id": 16384,
                            "name": "sw_build_id",
                            "value": "1.56.7_r29434"
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                    "id": 8,
                    "name": "Level control",
                    "attributes": [
                            "id": 0,
                            "name": "current_level",
                            "value": 254
                    "id": 4096,
                    "name": "LightLink",
                    "attributes": []
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4107,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 128,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 128,
        "endpoints": {
            "11": {
                "profile_id": 260,
                "device_type": 257,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    8,
                    4096
                    25
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zigpy.device"
Lien vers le site du produit : Hue White Projecteur extérieur
Voici l’image pour le projecteur :
Et voici le fichier debug après execution des commandes reconnu:
zigbee.txt (7,0 Ko)
Merci beaucoup,
Mathieu
