Demande Ajout Zemismart : Bouton Poussoir + Commande Volet roulant
Je débute tout juste avec jeedom, j’ai pris hier le plugin Zigbee, et mes deux premiers (et seul pour le moment) équipements ne sont pas dispo.
Est-il possible de les ajouter ? :
Lien achat interrupteur TS0013 Aliexpress
Pour info j’arrive à le faire marcher avec le Zemismart TS0011 déjà présent en rajoutant les commandes avec l’id 3
    "ieee": "60:a4:23:ff:fe:d4:4e:2b",
    "nwk": 13095,
    "status": 2,
    "lqi": "135",
    "rssi": "-77",
    "last_seen": "1619894626.0318282",
    "node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": "_TZ3000_wyhuocal",
            "model": "TS0013",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 65
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_wyhuocal"
                            "id": 5,
                            "name": "model",
                            "value": "TS0013"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "name": "off_wait_time",
                            "value": 0
            "id": 2,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": null,
            "model": null,
            "output_clusters": [],
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
            "id": 3,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
    "signature": {
        "model": "TS0013",
        "node_desc": {
            "byte1": 2,
            "byte2": 64,
            "mac_capability_flags": 128,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    0,
                    4,
                    5,
                    6
                    25
            "2": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6
            "3": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6
    "class": "zhaquirks.tuya.ts001x"
Dans l’ordre On-off sur les 3 boutons
[2021-05-01 14:05:16][DEBUG] : {"devices":{"60:a4:23:ff:fe:d4:4e:2b":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-05-01 14:05:16][DEBUG] : Search attribut for 60:a4:23:ff:fe:d4:4e:2b logicalId : 1::6::0 => Bool.true
[2021-05-01 14:05:18][DEBUG] : {"devices":{"60:a4:23:ff:fe:d4:4e:2b":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-05-01 14:05:18][DEBUG] : Search attribut for 60:a4:23:ff:fe:d4:4e:2b logicalId : 1::6::0 => Bool.false
[2021-05-01 14:05:20][DEBUG] : {"devices":{"60:a4:23:ff:fe:d4:4e:2b":{"2":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-05-01 14:05:20][DEBUG] : Search attribut for 60:a4:23:ff:fe:d4:4e:2b logicalId : 2::6::0 => Bool.true
[2021-05-01 14:05:22][DEBUG] : {"devices":{"60:a4:23:ff:fe:d4:4e:2b":{"2":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-05-01 14:05:22][DEBUG] : Search attribut for 60:a4:23:ff:fe:d4:4e:2b logicalId : 2::6::0 => Bool.false
[2021-05-01 14:05:23][DEBUG] : {"devices":{"60:a4:23:ff:fe:d4:4e:2b":{"3":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-05-01 14:05:23][DEBUG] : Search attribut for 60:a4:23:ff:fe:d4:4e:2b logicalId : 3::6::0 => Bool.true
[2021-05-01 14:05:25][DEBUG] : {"devices":{"60:a4:23:ff:fe:d4:4e:2b":{"3":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-05-01 14:05:25][DEBUG] : Search attribut for 60:a4:23:ff:fe:d4:4e:2b logicalId : 3::6::0 => Bool.false
[2021-05-01 14:07:19][DEBUG] : {"devices":{"60:a4:23:ff:fe:d4:4e:2b":{"1":{"6":{"0":{"value":"Bool.false","cluster_name":"On\/Off"},"16385":{"value":"0","cluster_name":"On\/Off"},"16386":{"value":"0","cluster_name":"On\/Off"},"32769":{"value":"enum8.undefined_0x01","cluster_name":"On\/Off"},"32770":{"value":"enum8.undefined_0x00","cluster_name":"On\/Off"}}},"2":{"6":{"0":{"value":"Bool.false","cluster_name":"On\/Off"},"16385":{"value":"0","cluster_name":"On\/Off"},"16386":{"value":"0","cluster_name":"On\/Off"}}}}}}
Commande de volet
J’ai acheté celui-ci ZW-EU-4C
Mais j’ai eu la référence ZW-EC-01
ZW-EC-01 Store Zemismart
https://fr.aliexpress.com/item/1005001437122520.html?spm=a2g0o.productlist.0.0.5bb013a3IyCDHz&algo_pvid=aa648634-dbb7-4fc0-8e18-37bde6450436&algo_expid=aa648634-dbb7-4fc0-8e18-37bde6450436-1&btsid=2100bb4a16198694554161470ee159&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
J’espère que ce n’est pas un « faux »
    "ieee": "bc:33:ac:ff:fe:56:fc:18",
    "nwk": 56895,
    "status": 2,
    "lqi": "135",
    "rssi": "-77",
    "last_seen": "1619895370.5795248",
    "node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 514,
            "profile_id": 260,
            "manufacturer": "3A Smart Home DE",
            "model": "LXX60-CS27LX1.0",
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 3,
                            "value": 0
                            "id": 4,
                            "value": "3A Smart Home DE"
                            "id": 5,
                            "name": "model",
                            "value": "LXX60-CS27LX1.0"
                            "id": 7,
                            "value": 0
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                    "id": 258,
                    "name": "Window Covering",
                    "attributes": [
                            "id": 7,
                            "name": "config_status",
                            "value": 3
                            "id": 8,
                            "name": "current_position_lift_percentage",
                            "value": 100
                            "id": 23,
                            "name": "window_covering_mode",
                            "value": 20
    "signature": {
        "node_desc": {
            "byte1": 1,
            "byte2": 64,
            "mac_capability_flags": 142,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 514,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    258
                    3
    "class": "zigpy.device"
Dans l’ordre j’ai appuyé sur descendre, un nouvelle fois sur descendre ce qui a arreté le volet, puis une 3eme fois pour que le volet descende jusqu’en bas.
J’ai ensuite appuyer sur monté.
[2021-05-01 21:35:26][DEBUG] : {"devices":{"bc:33:ac:ff:fe:56:fc:18":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}],"258":{"8":{"value":"0","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x01","cluster_name":"Window Covering"}}}}}}
[2021-05-01 21:35:26][DEBUG] : Search attribut for bc:33:ac:ff:fe:56:fc:18 logicalId : 1::6::0 => Bool.false
[2021-05-01 21:35:26][DEBUG] : Search attribut for bc:33:ac:ff:fe:56:fc:18 logicalId : 1::258::8 => 0
[2021-05-01 21:35:26][DEBUG] : Search attribut for bc:33:ac:ff:fe:56:fc:18 logicalId : 1::258::61440 => enum8.undefined_0x01
[2021-05-01 21:35:53][DEBUG] : {"devices":{"bc:33:ac:ff:fe:56:fc:18":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}],"258":{"8":{"value":"0","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x01","cluster_name":"Window Covering"}}}}}}
[2021-05-01 21:35:53][DEBUG] : Search attribut for bc:33:ac:ff:fe:56:fc:18 logicalId : 1::6::0 => Bool.false
[2021-05-01 21:35:53][DEBUG] : Search attribut for bc:33:ac:ff:fe:56:fc:18 logicalId : 1::258::8 => 0
[2021-05-01 21:35:53][DEBUG] : Search attribut for bc:33:ac:ff:fe:56:fc:18 logicalId : 1::258::61440 => enum8.undefined_0x01
[2021-05-01 21:36:01][DEBUG] : {"devices":{"bc:33:ac:ff:fe:56:fc:18":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-05-01 21:36:01][DEBUG] : Search attribut for bc:33:ac:ff:fe:56:fc:18 logicalId : 1::6::0 => Bool.true
[2021-05-01 21:36:01][DEBUG] : {"devices":{"bc:33:ac:ff:fe:56:fc:18":{"1":{"258":{"8":{"value":"100","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x00","cluster_name":"Window Covering"}},"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-05-01 21:36:01][DEBUG] : Search attribut for bc:33:ac:ff:fe:56:fc:18 logicalId : 1::258::8 => 100
[2021-05-01 21:36:02][DEBUG] : Search attribut for bc:33:ac:ff:fe:56:fc:18 logicalId : 1::258::61440 => enum8.undefined_0x00
[2021-05-01 21:36:02][DEBUG] : Search attribut for bc:33:ac:ff:fe:56:fc:18 logicalId : 1::6::0 => Bool.true
Merci :slight_smile:
Les modules sont ajouté. Merci la prochaine fois de bien mettre les images, j’ai traité la demande quand meme la mais ca ne se reproduira plus.
Merci !
Oups désolé pour les images, j’ai suivi la Doc jeedom et ce n’était pas demandé, mais c’est vrai que dans toutes les autres demandes il y avait les images :wink:
Encore merci je teste tout ça ce soir :slight_smile:
