Vous serez-t-il possible d’ajouter la référence suivante jeezigbee ?
Schneider Wiser S520531 Odace
Informations brutes:
"date_code": "",
"definition": {
"description": "LK FUGA wiser wireless battery 4 button switch",
"exposes": [
"access": 1,
"category": "diagnostic",
"description": "Triggered action (e.g. a button click)",
"label": "Action",
"name": "action",
"property": "action",
"type": "enum",
"values": [
"on_top",
"off_top",
"on_bottom",
"off_bottom",
"brightness_move_up_top",
"brightness_stop_top",
"brightness_move_down_top",
"brightness_move_up_bottom",
"brightness_stop_bottom",
"brightness_move_down_bottom",
"access": 1,
"description": "Remaining battery in %, can take up to 24 hours before reported",
"label": "Battery",
"name": "battery",
"property": "battery",
"type": "numeric",
"unit": "%",
"value_max": 100,
"value_min": 0
"access": 1,
"description": "Link quality (signal strength)",
"label": "Linkquality",
"name": "linkquality",
"property": "linkquality",
"type": "numeric",
"unit": "lqi",
"value_max": 255,
"value_min": 0
"model": "550D6001",
"options": [
"access": 2,
"description": "Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ",
"features": [
"access": 2,
"description": "Delta per interval, 20 by default",
"label": "Delta",
"name": "delta",
"property": "delta",
"type": "numeric",
"value_min": 0
"access": 2,
"description": "Interval duration",
"label": "Interval",
"name": "interval",
"property": "interval",
"type": "numeric",
"unit": "ms",
"value_min": 0
"label": "Simulated brightness",
"name": "simulated_brightness",
"property": "simulated_brightness",
"type": "composite"
"supports_ota": false,
"vendor": "Schneider Electric"
"disabled": false,
"endpoints": {
"21": {
"bindings": [
"cluster": "genOnOff",
"target": {
"endpoint": 1,
"ieee_address": "0x00212effff05df4a",
"type": "endpoint"
"cluster": "genLevelCtrl",
"target": {
"endpoint": 1,
"type": "endpoint"
"cluster": "genPowerCfg",
"target": {
"endpoint": 1,
"type": "endpoint"
"clusters": {
"input": [
"genBasic",
"genPowerCfg",
"genIdentify",
"genPollCtrl",
"manuSpecificSchneiderLightSwitchConfiguration"
"output": [
"genIdentify",
"genGroups",
"genScenes",
"genOnOff",
"genLevelCtrl",
"genOta",
"closuresWindowCovering"
"configured_reportings": [
"attribute": "batteryPercentageRemaining",
"maximum_report_interval": 65000,
"minimum_report_interval": 3600,
"reportable_change": 0
"scenes": []
"22": {
"bindings": [
"target": {
"endpoint": 1,
"type": "endpoint"
"target": {
"endpoint": 1,
"type": "endpoint"
"clusters": {
"input": [
"genBasic",
"genPowerCfg",
"genIdentify",
"output": [
"genIdentify",
"genGroups",
"genScenes",
"genOnOff",
"genLevelCtrl",
"configured_reportings": [],
"scenes": []
"23": {
"bindings": [],
"clusters": {
"input": [
"genBasic",
"genPowerCfg",
"genIdentify",
"output": [
"genIdentify",
"genGroups",
"genScenes",
"genOnOff",
"genLevelCtrl",
"scenes": []
"24": {
"bindings": [],
"clusters": {
"input": [
"genBasic",
"genPowerCfg",
"genIdentify",
"output": [
"genIdentify",
"genGroups",
"genScenes",
"genOnOff",
"genLevelCtrl",
"scenes": []
"friendly_name": "0x70ac08fffe13a984",
"ieee_address": "0x70ac08fffe13a984",
"interview_completed": true,
"interviewing": false,
"manufacturer": "Schneider Electric",
"model_id": "FLS\/AIRLINK\/4",
"network_address": 51411,
"power_source": "Battery",
"software_build_id": "002.009.001 R",
"supported": true,
"type": "EndDevice"
De quelles autres informations auriez-vous besoin ?
Ce switch peut s’utiliser en 2 ou 4 boutons (2 montées et 2 descentes)
Actuellement je n’arrive pas à dissocier si l’appui vient du bouton monté 1 ou du bouton monté 3. Egalement pour le bouton descente 2 et 4.
Après un appui sur 1, 3, 2 et 4 j’ai les logs suivants:
[2024-12-21 10:03:15] DEBUG : [Intérieur][Wiser Centralisation] Check for update action => "on_top", raw : "on_top"
[2024-12-21 10:03:15] DEBUG : [Intérieur][Wiser Centralisation] Check for update battery => 60, raw : 60
[2024-12-21 10:03:15] DEBUG : [Intérieur][Wiser Centralisation] Check for update last_seen => "2024-12-21 10:03:15", raw : "2024-12-21T09:03:15.412Z"
[2024-12-21 10:03:15] DEBUG : [Intérieur][Wiser Centralisation] Check for update linkquality => 255, raw : 255
[2024-12-21 10:03:19] DEBUG : [Intérieur][Wiser Centralisation] Check for update action => "on_top", raw : "on_top"
[2024-12-21 10:03:19] DEBUG : [Intérieur][Wiser Centralisation] Check for update battery => 60, raw : 60
[2024-12-21 10:03:19] DEBUG : [Intérieur][Wiser Centralisation] Check for update last_seen => "2024-12-21 10:03:19", raw : "2024-12-21T09:03:19.414Z"
[2024-12-21 10:03:19] DEBUG : [Intérieur][Wiser Centralisation] Check for update linkquality => 255, raw : 255
[2024-12-21 10:03:22] DEBUG : [Intérieur][Wiser Centralisation] Check for update action => "off_top", raw : "off_top"
[2024-12-21 10:03:22] DEBUG : [Intérieur][Wiser Centralisation] Check for update battery => 60, raw : 60
[2024-12-21 10:03:22] DEBUG : [Intérieur][Wiser Centralisation] Check for update last_seen => "2024-12-21 10:03:22", raw : "2024-12-21T09:03:22.210Z"
[2024-12-21 10:03:22] DEBUG : [Intérieur][Wiser Centralisation] Check for update linkquality => 255, raw : 255
[2024-12-21 10:03:25] DEBUG : [Intérieur][Wiser Centralisation] Check for update action => "off_top", raw : "off_top"
[2024-12-21 10:03:25] DEBUG : [Intérieur][Wiser Centralisation] Check for update battery => 60, raw : 60
[2024-12-21 10:03:25] DEBUG : [Intérieur][Wiser Centralisation] Check for update last_seen => "2024-12-21 10:03:24", raw : "2024-12-21T09:03:24.754Z"
[2024-12-21 10:03:25] DEBUG : [Intérieur][Wiser Centralisation] Check for update linkquality => 255, raw : 255
[2024-12-21 10:03:15] DEBUG : {"zigbee2mqtt":{"0x70ac08fffe13a984":{"action":"on_top","battery":60,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"0x70ac08fffe13a984","hardwareVersion":1,"ieeeAddr":"0x70ac08fffe13a984","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"550D6001","networkAddress":51411,"powerSource":"Battery","softwareBuildID":"002.009.001 R","stackVersion":6,"type":"EndDevice","zclVersion":3},"last_seen":"2024-12-21T09:03:15.412Z","linkquality":255}}}
[2024-12-21 10:03:19] DEBUG : {"zigbee2mqtt":{"0x70ac08fffe13a984":{"action":"on_top","battery":60,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"0x70ac08fffe13a984","hardwareVersion":1,"ieeeAddr":"0x70ac08fffe13a984","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"550D6001","networkAddress":51411,"powerSource":"Battery","softwareBuildID":"002.009.001 R","stackVersion":6,"type":"EndDevice","zclVersion":3},"last_seen":"2024-12-21T09:03:19.414Z","linkquality":255}}}
[2024-12-21 10:03:22] DEBUG : {"zigbee2mqtt":{"0x70ac08fffe13a984":{"action":"off_top","battery":60,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"0x70ac08fffe13a984","hardwareVersion":1,"ieeeAddr":"0x70ac08fffe13a984","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"550D6001","networkAddress":51411,"powerSource":"Battery","softwareBuildID":"002.009.001 R","stackVersion":6,"type":"EndDevice","zclVersion":3},"last_seen":"2024-12-21T09:03:22.210Z","linkquality":255}}}
[2024-12-21 10:03:25] DEBUG : {"zigbee2mqtt":{"0x70ac08fffe13a984":{"action":"off_top","battery":60,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"0x70ac08fffe13a984","hardwareVersion":1,"ieeeAddr":"0x70ac08fffe13a984","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"550D6001","networkAddress":51411,"powerSource":"Battery","softwareBuildID":"002.009.001 R","stackVersion":6,"type":"EndDevice","zclVersion":3},"last_seen":"2024-12-21T09:03:24.754Z","linkquality":255}}}
[2024-12-21 10:04:35] DEBUG : {"zigbee2mqtt":{"0x70ac08fffe13a984":{"action":"on_top","battery":60,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"0x70ac08fffe13a984","hardwareVersion":1,"ieeeAddr":"0x70ac08fffe13a984","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"550D6001","networkAddress":51411,"powerSource":"Battery","softwareBuildID":"002.009.001 R","stackVersion":6,"type":"EndDevice","zclVersion":3},"last_seen":"2024-12-21T09:04:35.523Z","linkquality":255}}}
Auriez-vous une idée ?
D’avance je vous remercie pour le futur ajout et votre aide.
Bonne journée et bonnes fêtes.
Cordialement.
