Demande ajout référence INNR
Vous serait il possible d’ajouter la référence suivante dans le plugin ZIGBEE:
lampe INNR RB 278 T-2
code Json (j’espère que c’est bien ça qu’il faut joindre!!)
    "ieee": "00:15:8d:00:05:a2:5c:74",
    "nwk": 64580,
    "status": 2,
    "lqi": "None",
    "rssi": "None",
    "last_seen": "None",
    "node_descriptor": "01:40:8e:66:11:7f:5a:00:00:2a:5a:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 268,
            "profile_id": 260,
            "manufacturer": "innr",
            "model": "RB 278 T",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 2
                            "id": 1,
                            "name": "app_version",
                            "value": 16
                            "id": 2,
                            "name": "stack_version",
                            "value": 21
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "innr"
                            "id": 5,
                            "name": "model",
                            "value": "RB 278 T"
                            "id": 6,
                            "name": "date_code",
                            "value": "20180810-1"
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                            "id": 16384,
                            "name": "sw_build_id",
                            "value": "2.0"
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                    "id": 8,
                    "name": "Level control",
                    "attributes": [
                            "id": 0,
                            "name": "current_level",
                            "value": 99
                    "id": 768,
                    "name": "Color Control",
                    "attributes": [
                            "id": 3,
                            "name": "current_x",
                            "value": 29991
                            "id": 4,
                            "name": "current_y",
                            "value": 26872
                            "id": 7,
                            "name": "color_temperature",
                            "value": 370
                    "id": 4096,
                    "name": "LightLink",
                    "attributes": []
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "node_desc": {
            "byte1": 1,
            "byte2": 64,
            "mac_capability_flags": 142,
            "manufacturer_code": 4454,
            "maximum_buffer_size": 127,
            "maximum_incoming_transfer_size": 90,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 90,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 268,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    8,
                    768,
                    4096
                    25
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zigpy.device"
Fournisseur DOMADOO INNR - Ampoule connectée type E27 - ZigBee 3.0 - Blanc réglable (domadoo.fr)
Cordialement.
BONJOUR (bis repetita) :grinning:
Après lecture plus attentive de la documentation, je présente à nouveau ma demande en essayant de mieux respecter les demandes de l’équipe:
    "nwk": 64580,
    "status": 2,
    "lqi": "207",
    "rssi": "-68",
    "last_seen": "1620122032.1001751",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 268,
            "profile_id": 260,
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 2
                            "id": 1,
                            "value": 16
                            "id": 2,
                            "value": 21
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "value": "innr"
                            "id": 5,
                            "name": "model",
                            "value": "RB 278 T"
                            "id": 6,
                            "id": 7,
                            "value": 1
                            "id": 16384,
                            "value": "2.0"
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                    "id": 8,
                    "attributes": [
                            "id": 0,
                            "value": 254
                    "id": 768,
                    "attributes": [
                            "id": 3,
                            "value": 29991
                            "id": 4,
                            "value": 26872
                            "id": 7,
                            "value": 454
                    "id": 4096,
                    "attributes": []
            "id": 242,
            "status": 1,
            "device_type": 97,
            "model": null,
                    "id": 33,
                    "attributes": []
    "signature": {
        "node_desc": {
            "byte1": 1,
            "byte2": 64,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 268,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    8,
                    768,
                    4096
                    25
            "242": {
                "device_type": 97,
                    33
les logs:
[2021-05-03 15:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-03 16:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-03 17:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-03 18:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-03 19:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-03 20:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-03 20:57:39][ERROR] : Erreur exécution de la commande [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8][On] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"00:15:8d:00:05:a2:47:b8","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0x83af:1:0x0006]: Message send failure","code":0}
[2021-05-03 20:58:52][ERROR] : Erreur exécution de la commande [SALON][lampe salon][On] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"00:15:8d:00:05:a2:5c:74","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0xfc44:1:0x0006]: Message send failure","code":0}
[2021-05-03 20:59:45][ERROR] : Erreur exécution de la commande [SALON][lampe salon][On] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"00:15:8d:00:05:a2:5c:74","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0xfc44:1:0x0006]: Message send failure","code":0}
[2021-05-03 21:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-03 22:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-03 23:00:07][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-04 00:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-04 01:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-04 02:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-04 03:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-04 04:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-04 05:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-04 06:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-04 07:00:07][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-04 08:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-04 09:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-04 10:00:06][ERROR] : Le module [SALON][innr.RB_278_T 00:15:8d:00:05:a2:47:b8] n'a pas envoyé de message depuis plus de 1440 min
[2021-05-04 11:58:58][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-05-04 11:58:58][DEBUG] : {"ieee":"00:15:8d:00:05:a2:5c:74","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-05-04 11:58:59][DEBUG] : {"devices":{"00:15:8d:00:05:a2:5c:74":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-05-04 11:58:59][DEBUG] : Search attribut for 00:15:8d:00:05:a2:5c:74 logicalId : 1::6::0 => Bool.true
[2021-05-04 11:59:18][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-05-04 11:59:18][DEBUG] : {"ieee":"00:15:8d:00:05:a2:5c:74","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false}
[2021-05-04 11:59:19][DEBUG] : {"devices":{"00:15:8d:00:05:a2:5c:74":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-05-04 11:59:19][DEBUG] : Search attribut for 00:15:8d:00:05:a2:5c:74 logicalId : 1::6::0 => Bool.false
[2021-05-04 11:59:43][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device auto --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey u4qCWNEt5ax5AZZy7l6AvmLNL04pB2SA --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller deconz --sub_controller auto --channel 15
[2021-05-04 11:59:45][DEBUG] : null
[2021-05-04 11:59:51][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2021-05-04 11:59:42
[2021-05-04 12:00:15][DEBUG] : http://127.0.0.1:8089/device/all type : GET
[2021-05-04 12:00:15][DEBUG] : null
[2021-05-04 12:00:15][ERROR] : Erreur sur la fonction cronHourly du plugin : Echec de la requête HTTP : http://127.0.0.1:8089/device/all cURL error : Failed to connect to 127.0.0.1 port 8089: Connection refused
[2021-05-04 12:03:30][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device auto --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey u4qCWNEt5ax5AZZy7l6AvmLNL04pB2SA --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller deconz --sub_controller auto --channel 15
[2021-05-04 12:03:33][DEBUG] : null
[2021-05-04 12:03:36][DEBUG] : {"devices":{"00:15:8d:00:05:a2:5c:74":{"1":{"768":{"7":{"value":"454","cluster_name":"Color Control"}}}}}}
[2021-05-04 12:03:36][DEBUG] : Search attribut for 00:15:8d:00:05:a2:5c:74 logicalId : 1::768::7 => 454
[2021-05-04 12:03:51][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-05-04 12:03:51][DEBUG] : {"ieee":"00:15:8d:00:05:a2:5c:74","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-05-04 12:03:52][DEBUG] : {"devices":{"00:15:8d:00:05:a2:5c:74":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-05-04 12:03:52][DEBUG] : Search attribut for 00:15:8d:00:05:a2:5c:74 logicalId : 1::6::0 => Bool.true
[2021-05-04 12:04:01][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-05-04 12:04:01][DEBUG] : {"ieee":"00:15:8d:00:05:a2:5c:74","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false}
[2021-05-04 12:04:01][DEBUG] : {"devices":{"00:15:8d:00:05:a2:5c:74":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-05-04 12:04:01][DEBUG] : Search attribut for 00:15:8d:00:05:a2:5c:74 logicalId : 1::6::0 => Bool.false
Voilà, j’espère que c’est complet cette fois, et surtout, un grand merci à l’équipe pour son travail!! :slightly_smiling_face:
Ca sera dans la prochaine beta du plugin
Merci Loïc. Ta réactivité est sans égale! :wink:
