Demande ajout détecteur présence
Bonjour, une nouvelle demande d’ajour d’un module sympa : le détecteur de mouvement Lexman, avec immunité aux animaux :
https://www.leroymerlin.fr/produits/electricite-domotique/domotique-et-objets-connectes/domotique/accessoires-de-gestion-des-motorisations-et-automatismes/detecteur-de-mouvement-animaux-lexman-82428878.html?megaBoost&gclid=CjwKCAjwqeWKBhBFEiwABo_XBkRnDwtQHY54AOVn-t5A_JX4nxggv4wgTWadIuq_IuOXRFafdxE5lhoCBk4QAvD_BwE&gclsrc=aw.ds
    "ieee": "5c:02:72:ff:fe:94:7c:96",
    "nwk": 54495,
    "status": 2,
    "lqi": "136",
    "rssi": "-66",
    "last_seen": "1633325377.3224218",
    "node_descriptor": "02:40:80:77:12:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 1026,
            "profile_id": 260,
            "manufacturer": "ADEO",
            "model": "LDSENK10",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 2
                            "id": 2,
                            "name": "stack_version",
                            "value": 6
                            "id": 3,
                            "name": "hw_version",
                            "value": 2
                            "id": 4,
                            "name": "manufacturer",
                            "value": "ADEO"
                            "id": 5,
                            "name": "model",
                            "value": "LDSENK10"
                            "id": 6,
                            "name": "date_code",
                            "value": "20190523-16"
                            "id": 7,
                            "name": "power_source",
                            "value": 3
                            "id": 16384,
                            "name": "sw_build_id",
                            "value": "2.03"
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": []
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 32,
                    "name": "Poll Control",
                    "attributes": [
                            "id": 0,
                            "name": "checkin_interval",
                            "value": 14400
                    "id": 1280,
                    "name": "IAS Zone",
                    "attributes": [
                            "id": 16,
                            "name": "cie_addr",
                            "value": [
                                158,
                                132,
                                119,
                                254,
                                255,
                                80,
                                75,
                                128
                    "id": 2821,
                    "name": "Diagnostic",
                    "attributes": []
    "signature": {
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4727,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "input_clusters": [
                    0,
                    1,
                    3,
                    32,
                    1280,
                    2821
                    25
    "class": "zigpy.device"
Et l’image !
Ah enfin un capteur zigbee, avec immunité sur les animaux ça fait des mois que j’attends, par contre il n’est pas donné quand même.
Une fois intégré je veux bien ton retour!
Pas donné ? 34€ ? C’est sur qu’on n’est pas aux 10e du capteur xiaomi, mais tous les détecteurs avec immunité animaux que j’ai trouvé sont plus cher, sauf pour les filaires, donc personnellement, je trouve le prix très bien, et en plus il est discret et qualitatif (en main il fait solide).
Et comme tu dis « enfin un détecteur Zigbee avec immunité animaux ». Je ne manquerais pas de faire un retour :slight_smile:
Etant nouveau, comment sait on si notre demande d’ajout a été prise en compte ou si on peut aller se gratter ? :smiley:
Juste un peu de patience :wink: et au pire regarder la liste de compatibilité disponible ici
Mais c’est super !
Merci, je suis sur que beaucoup seront satisfait de cet ajout. Très efficace la team.
Dernière question, je vois que l’ajout est en beta. Ça signifie qu’il faut tester je suppose ? Vu que c’est moi qui ai fait la demande c’est à moi de tester non ?
Dois je télécharger la dernière version ? Est ce automatique ? Dois je reinclure le module ? Bref je fais quoi ? :slight_smile:
Oui sauf si d’autre personne on le même device.
Si il dise en beta c’est que c’est uniquement dans la version beta du plugin.
oui c’est préférable
Test en beta pour voir si cela fonctionne afin d’être certain qu’il n’y ai pas de bug avant que cela passe en stable
Merci, je vais tester ça avant la fin de semaine. Les version beta et stable sortent à quelles dates en général ?
Stable aucune idée et pour la beta il y en a eu une ce matin par exemple et ton capteur fait partie de la beta de ce matin :wink:
J’ai vu qu’il en fesait parti oui :slight_smile:
Merci pour tous ces renseignements.
Je suis impressionné par la réactivité d’ajout en tout cas, bravo et merci.
il te reste plus qu’a tester si tout est OK :wink:
Alors je viens de tester. Verdict : les commandes sont bel et bien présentes, par contre on dirait qu’il passe de 0 a 1 une fois par minute… Soit il ne fonctionne pas, soit il y a un soucis de cadence d’envoi.
J’ai ouvert un nouveau sujet.
C’est normal et bien dans ce protocole car certains mettent généralement 2mn (xiaomi et sonoff) reste à vérifier l’immunité aux animaux :wink:
Et on ne peut pas réduire ce temps ? Car c’est assez inutile de remonter une info de mouvement toutes les deux minutes :confused:
Est ce bien ici pour faire les rémontées de bon fonctionnement ?
Parce que je suis un peu perdu, pour la config, je ne sais pas si je peux optimiser ou non, si c’est le plugin, ou mon matériel qui est limité…
Il faut partir du principe qu’il s’agit d’un capteur de présence plutôt qu’un détecteur de mouvement d’où la latence sur le changement d’état.
Ha bon ? Je n’y connais pas grand chose. Les capteur de présence sont plus lents que les capteurs de mouvement ?
