Demande ajout ampoule led Oeeone
Est ce qu’il serait possible d’ajouter cette ampoule zigbee SVP ?
Oeeone Ampoule à Filament LED Intelligente E27
Lien : https://www.amazon.fr/Ampoule-filament-Fonctionne-Assistant-nécessaire/dp/B07WXPZSLT/
Image :
Json :
    "ieee": "00:15:8d:00:05:3a:3d:3c",
    "nwk": 45420,
    "status": 2,
    "lqi": "128",
    "rssi": "-68",
    "last_seen": "1622381549.5344844",
    "node_descriptor": "01:40:8e:29:10:7f:5a:00:00:2c:5a:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 268,
            "profile_id": 260,
            "manufacturer": "ZigBee\/CCT",
            "model": "CCT Light",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 4111,
                    "name": "Cluster",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 2
                            "id": 1,
                            "name": "app_version",
                            "value": 1
                            "id": 2,
                            "name": "stack_version",
                            "value": 1
                            "id": 3,
                            "name": "hw_version",
                            "value": 21
                            "id": 4,
                            "name": "manufacturer",
                            "value": "ZigBee\/CCT"
                            "id": 5,
                            "name": "model",
                            "value": "CCT Light"
                            "id": 6,
                            "name": "date_code",
                            "value": "20200505"
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                            "id": 16384,
                            "name": "sw_build_id",
                            "value": "00.00.01"
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                    "id": 8,
                    "name": "Level control",
                    "attributes": [
                            "id": 0,
                            "name": "current_level",
                            "value": 255
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 768,
                    "name": "Color Control",
                    "attributes": [
                            "id": 3,
                            "name": "current_x",
                            "value": 20650
                            "id": 4,
                            "name": "current_y",
                            "value": 21396
                            "id": 7,
                            "name": "color_temperature",
                            "value": 153
                    "id": 65535,
                    "name": "Manufacturer Specific",
                    "attributes": []
                    "id": 4096,
                    "name": "LightLink",
                    "attributes": []
                    "id": 4111,
                    "name": "Cluster",
                    "attributes": []
            "id": 242,
            "status": 1,
            "device_type": 102,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": [
                    "id": 33,
                    "attributes": []
    "signature": {
        "node_desc": {
            "byte1": 1,
            "byte2": 64,
            "mac_capability_flags": 142,
            "manufacturer_code": 4137,
            "maximum_buffer_size": 127,
            "maximum_incoming_transfer_size": 90,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 90,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 268,
                "input_clusters": [
                    0,
                    4,
                    3,
                    6,
                    8,
                    5,
                    768,
                    65535,
                    4096,
                    4111
                    25,
                    4111
            "242": {
                "device_type": 102,
                "input_clusters": [
                    33
                    33
    "class": "zigpy.device"
Merci d’avance !
Juju
