Je vois un délai entre le moment où une commande est actionnée (via l’interface) et l’action au niveau de somfy, quelqu’un a une idée sur le sujet?
Voici le log:
[2024-09-28 17:07:03] DEBUG : +- Method: SomfyUnified\UnifiedAPI::sendActionToOverkizAPI($serverName: somfy_developer_mode - $arguments (json_encode): {"apiAction":"get_setup","importDataAsJson":true})
[2024-09-28 17:07:03] DEBUG : +- Method: SomfyUnified\GetFileContent::fileGetContents - Succeeded to read file (/var/www/html/plugins/SomfyUnified/userData/localAuth/authTokens_xxxxxxxxxxxxxx.json)
[2024-09-28 17:07:10] INFO : |Un| [serv11] action: execute_commands - result[0] = "2beeb905-434f-4298-9798-b1c2d1d11f0a"
[2024-09-28 17:07:10] DEBUG : |Un| Command exec() executed - Output= not empty - Exit code= 0 -> Command executed successfully
[2024-09-28 17:07:10] INFO : ..........
[2024-09-28 17:07:10] INFO : Execute Cmd: serv11 - {"label":"setClosure","actions":[{"commands":[{"name":"setClosure","parameters":[40]}],"deviceURL":"io:\/\/xxxxxxxxxxxxxx\/5485159"}]}
[2024-09-28 17:07:10] INFO : executionId: 2beeb905-434f-4298-9798-b1c2d1d11f0a
[2024-09-28 17:07:11] DEBUG : |INC| Succeeded to load SomfyUnified\UtilsLib
[2024-09-28 17:07:11] INFO : |Re| Message from OverkizApi received in PHP (json_encode): {"server":"somfy_developer_mode","events":"[{\"name\": \"ExecutionRegisteredEvent\", \"timestamp\": null, \"setupoid\": \"<<non-serializable: _CountingAttr>>\", \"owner_key\": null, \"type\": null, \"sub_type\": null, \"time_to_next_state\": null, \"failed_commands\": [], \"failure_type_code\": null, \"failure_type\": null, \"condition_groupoid\": null, \"place_oid\": null, \"label\": null, \"metadata\": null, \"camera_id\": null, \"deleted_raw_devices_count\": null, \"protocol_type\": null, \"gateway_id\": null, \"exec_id\": \"2beeb905-434f-4298-9798-b1c2d1d11f0a\", \"device_url\": null, \"device_states\": [], \"old_state\": null, \"new_state\": null}, {\"name\": \"ExecutionStateChangedEvent\", \"timestamp\": null, \"setupoid\": \"<<non-serializable: _CountingAttr>>\", \"owner_key\": null, \"type\": null, \"sub_type\": null, \"time_to_next_state\": null, \"failed_commands\": [], \"failure_type_code\": null, \"failure_type\": null, \"condition_groupoid\": null, \"place_oid\": null, \"label\": null, \"metadata\": null, \"camera_id\": null, \"deleted_raw_devices_count\": null, \"protocol_type\": null, \"gateway_id\": null, \"exec_id\": \"2beeb905-434f-4298-9798-b1c2d1d11f0a\", \"device_url\": null, \"device_states\": [], \"old_state\": \"INITIALIZED\", \"new_state\": \"IN_PROGRESS\"}]"}
[2024-09-28 17:07:11] DEBUG : |INC| Succeeded to load SomfyUnified\SupportedServers
[2024-09-28 17:07:11] DEBUG : + Method: SomfyUnified::manageEvents ($serverIdent (json_encode): "serv11" $events: Array)
[2024-09-28 17:07:11] DEBUG : event[serv11][0][name]= "ExecutionRegisteredEvent"
[2024-09-28 17:07:11] DEBUG : event[serv11][0][timestamp]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][setupoid]="<<non-serializable: _CountingAttr>>"
[2024-09-28 17:07:11] DEBUG : event[serv11][0][owner_key]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][type]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][sub_type]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][time_to_next_state]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][failed_commands]= []
[2024-09-28 17:07:11] DEBUG : event[serv11][0][failure_type_code]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][failure_type]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][condition_groupoid]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][place_oid]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][label]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][metadata]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][camera_id]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][deleted_raw_devices_count]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][protocol_type]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][gateway_id]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][exec_id]= "2beeb905-434f-4298-9798-b1c2d1d11f0a"
[2024-09-28 17:07:11] DEBUG : event[serv11][0][device_url]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][device_states]= []
[2024-09-28 17:07:11] DEBUG : event[serv11][0][old_state]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][0][new_state]= null
[2024-09-28 17:07:11] INFO : |*** event[serv11][0][name]= "ExecutionRegisteredEvent"
[2024-09-28 17:07:11] INFO : | event[serv11][0][timestamp]= null
[2024-09-28 17:07:11] INFO : | event[serv11][0][setupoid]= "<<non-serializable: _CountingAttr>>"
[2024-09-28 17:07:11] INFO : | event[serv11][0][type]= null
[2024-09-28 17:07:11] INFO : | event[serv11][0][sub_type]= null
[2024-09-28 17:07:11] INFO : | event[serv11][0][label]= null
[2024-09-28 17:07:11] INFO : | event[serv11][0][exec_id]= "2beeb905-434f-4298-9798-b1c2d1d11f0a"
[2024-09-28 17:07:11] DEBUG : event[serv11][1][name]= "ExecutionStateChangedEvent"
[2024-09-28 17:07:11] DEBUG : event[serv11][1][timestamp]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][setupoid]="<<non-serializable: _CountingAttr>>"
[2024-09-28 17:07:11] DEBUG : event[serv11][1][owner_key]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][type]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][sub_type]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][time_to_next_state]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][failed_commands]= []
[2024-09-28 17:07:11] DEBUG : event[serv11][1][failure_type_code]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][failure_type]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][condition_groupoid]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][place_oid]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][label]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][metadata]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][camera_id]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][deleted_raw_devices_count]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][protocol_type]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][gateway_id]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][exec_id]= "2beeb905-434f-4298-9798-b1c2d1d11f0a"
[2024-09-28 17:07:11] DEBUG : event[serv11][1][device_url]= null
[2024-09-28 17:07:11] DEBUG : event[serv11][1][device_states]= []
[2024-09-28 17:07:11] DEBUG : event[serv11][1][old_state]= "INITIALIZED"
[2024-09-28 17:07:11] DEBUG : event[serv11][1][new_state]= "IN_PROGRESS"
[2024-09-28 17:07:11] INFO : |*** event[serv11][1][name]= "ExecutionStateChangedEvent"
[2024-09-28 17:07:11] INFO : | event[serv11][1][timestamp]= null
[2024-09-28 17:07:11] INFO : | event[serv11][1][setupoid]= "<<non-serializable: _CountingAttr>>"
[2024-09-28 17:07:11] INFO : | event[serv11][1][owner_key]= null
[2024-09-28 17:07:11] INFO : | event[serv11][1][type]= null
[2024-09-28 17:07:11] INFO : | event[serv11][1][sub_type]= null
[2024-09-28 17:07:11] INFO : | event[serv11][1][time_to_next_state]= null
[2024-09-28 17:07:11] INFO : | event[serv11][1][failed_commands][0][rank]= null
[2024-09-28 17:07:11] INFO : | event[serv11][1][failed_commands][0][device_url]= null
[2024-09-28 17:07:11] INFO : | event[serv11][1][failed_commands][0][failure_type]= null
[2024-09-28 17:07:11] INFO : | event[serv11][1][failure_type_code]= null
[2024-09-28 17:07:11] INFO : | event[serv11][1][failure_type]= null
[2024-09-28 17:07:11] INFO : | event[serv11][1][exec_id]= "2beeb905-434f-4298-9798-b1c2d1d11f0a"
[2024-09-28 17:07:11] INFO : | event[serv11][1][old_state]= "INITIALIZED"
[2024-09-28 17:07:11] INFO : | event[serv11][1][new_state]= "IN_PROGRESS"
comme vous le voyez sur les logs il y a rien qui se passe entre 17:08:03 et 17:07:11
Merci d’avance
Informations Jeedom
Core : 4.4.17 (master)
DNS Jeedom : non
Plugin : SomfyUnified
Version : 2024-09-24 21:49:37 (stable)
Statut Démon : Démarré - (2024-09-28 17:05:31)
