Aprés avoir essayé ma clé le CONBE 2 et le plugin Deconz sur un RPI j’ai voulu faire des essais sous docker
J’ai créé un conteneur de test avec un réseau macvlan
Installation des dépendances et Deconz local
une clé est reconnu
[2021-01-14 16:28:17][INFO] : Lancement démon deconz : /usr/bin/python3 /var/www/html/plugins/deconz/resources/deconzd/deconzd.py --loglevel debug --socketport 55088 --callback http://127.0.0.1:80/plugins/deconz/core/php/jeeDeconz.php --apikey HyHJ4ZvBvEyTeC9110RJEnSv5myhqOj3 --cycle 0 --pid /tmp/jeedom/deconz/deamon.pid
[2021-01-14 15:28:18.714][INFO] : Start deconzd
[2021-01-14 15:28:18.714][INFO] : Log level : debug
[2021-01-14 15:28:18.714][INFO] : Socket port : 55088
[2021-01-14 15:28:18.714][INFO] : Socket host : localhost
[2021-01-14 15:28:18.715][INFO] : PID file : /tmp/jeedom/deconz/deamon.pid
[2021-01-14 15:28:18.715][INFO] : Apikey : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[2021-01-14 15:28:18.715][INFO] : Callback : http://127.0.0.1:80/plugins/deconz/core/php/jeeDeconz.php
[2021-01-14 15:28:18.715][INFO] : Cycle : 0.0
[2021-01-14 15:28:18.715][DEBUG] : Writing PID 32069 to /tmp/jeedom/deconz/deamon.pid
[2021-01-14 15:28:18.716][DEBUG] : Init request module v2.25.1
[2021-01-14 15:28:18.724][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2021-01-14 15:28:18.738][DEBUG] : http://127.0.0.1:80 "GET /plugins/deconz/core/php/jeeDeconz.php?apikey=HyHJ4ZvBvEyTeC9110RJEnSv5myhqOj3 HTTP/1.1" 200 0
[2021-01-14 15:28:18.740][DEBUG] : Start listening...
[2021-01-14 15:28:18.741][DEBUG] : Socket interface started
[2021-01-14 15:28:18.742][DEBUG] : LoopNetServer Thread started
[2021-01-14 15:28:18.743][DEBUG] : Listening on: [localhost:55088]
[2021-01-14 15:28:18.743][INFO] : Local DeconZ found
[2021-01-14 15:28:18.743][INFO] : Launching local DeconZ
[2021-01-14 15:28:18.744][INFO] : Kill all deCONZ process
Usage:
kill [options] <pid> [...]
Options:
<pid> [...] send signal to every <pid> listed
-<signal>, -s, --signal <signal>
specify the <signal> to be sent
-l, --list=[<signal>] list all signal names, or convert one to a name
-L, --table list all signal names in a nice table
-h, --help display this help and exit
-V, --version output version information and exit
For more details see kill(1).
[2021-01-14 15:28:18.813][INFO] : Log level deconz deamon debug
[2021-01-14 15:28:18.814][INFO] : Opt deconz deamon ['sudo', 'deCONZ', '--auto-connect=1', '--dbg-error=1', '--http-port=8484', '--ws-port=20877', '--upnp=0', '-platform', 'minimal', '--dbg-aps=2', '--dbg-info=2', '--dbg-zcl=2', '--dbg-zdp=2', '--dbg-http=2']
[2021-01-14 15:28:18.818][INFO] : Launched DeconZ with pid 32160
[2021-01-14 15:28:18.819][DEBUG] : Start socket thread
[2021-01-14 15:28:24.194][DEBUG] : Client connected to [127.0.0.1:54295]
[2021-01-14 15:28:24.196][DEBUG] : Message read from socket: b'{"apikey":"xxxxxxxxxxxxxxxxxxxxxxxxxxxxx","cmd":"addgateway","gateways":[{"id":"undefined","name":"undefined","internalipaddress":"127.0.0.1","internalport":"8484","websocketport":"20877","apikey":"undefined","manageTimeZone":"0"}]}'
[2021-01-14 15:28:24.196][DEBUG] : Client disconnected from [127.0.0.1:54295]
[2021-01-14 15:28:24.197][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-14 15:28:24.197][DEBUG] : Closing All Websockets
[2021-01-14 15:28:25.199][DEBUG] : Add gateway : undefined
[2021-01-14 15:28:25.199][DEBUG] : Starting WebSocket for undefined on ip 127.0.0.1 and port 20877
[2021-01-14 16:28:34][DEBUG] : 127.0.0.1:8484/api/undefined/sensors type : POST
[2021-01-14 16:28:35][DEBUG] : 127.0.0.1:8484/api/undefined/lights type : POST
Par contre rien avec les commandes
https://phoscon.de/discover
http://phoscon.de/pwa/
erreur avec la commande
sudo GCFFlasher_internal -l
