Décalage volet prop
Alors sans les retours d’états, volet fermé avant le test.
Sans HomeKit :
[2020-12-11 19:02:37][INFO] : [Appartement][Grand Volet Prop][Timeout] Temps d'attente: 8357906.1031342 < 27750000, Nous attendons
[2020-12-11 19:02:57][INFO] : [Appartement][Grand Volet Prop][Timeout] Execution du stop
[2020-12-11 19:02:57][DEBUG] : [Appartement][Grand Volet Prop] Execution de la commande [Appartement][Grand volet][Stop]
[2020-12-11 19:02:57][DEBUG] : [Appartement][Grand Volet Prop] Mise a jours manuel de la hauteur
[2020-12-11 19:02:57][DEBUG] : [Appartement][Grand Volet Prop] Temps de mouvement du volet de 27811100µs
[2020-12-11 19:02:57][DEBUG] : [Appartement][Grand Volet Prop] Suppression du temps de decollement
[2020-12-11 19:02:57][DEBUG] : [Appartement][Grand Volet Prop] Mouvement du volet de 100%
[2020-12-11 19:02:57][DEBUG] : [Appartement][Grand Volet Prop] Le volet est a 100%
[12/11/2020, 6:02:30 PM] [Jeedom Delta] [INFO] [Maj reçue de Jeedom] commande:829 value:0
[12/11/2020, 6:02:30 PM] [Jeedom Delta] [INFO] [[Modification Cache Jeedom: Grand volet>État(FLAP_STATE) de  vers 0 dans {"id":"829","logicalId":"3","generic_type":"FLAP_STATE","eqType":"Freebox_OS","name":"État","order":"2","type":"info","subType":"binary","eqLogic_id":"68","isVisible":1,"alert":[],"currentValue":"","display":{"invertBinary":0},"configuration":{"phpType":"integer"}}
[12/11/2020, 6:02:58 PM] [Jeedom Delta] [INFO] [Maj reçue de Jeedom] commande:829 value:
[12/11/2020, 6:02:58 PM] [Jeedom Delta] [INFO] [[Modification Cache Jeedom: Grand volet>État(FLAP_STATE) de 0 vers  dans {"id":"829","logicalId":"3","generic_type":"FLAP_STATE","eqType":"Freebox_OS","name":"État","order":"2","type":"info","subType":"binary","eqLogic_id":"68","isVisible":1,"alert":[],"currentValue":0,"display":{"invertBinary":0},"configuration":{"phpType":"integer"}}
[12/11/2020, 6:02:58 PM] [Jeedom Delta] [INFO] [Maj reçue de Jeedom] commande:881 value:100
[12/11/2020, 6:02:58 PM] [Jeedom Delta] [INFO] [[Modification Cache Jeedom: Grand Volet Prop>Hauteur(FLAP_STATE) de 0 vers 100 dans {"id":"881","logicalId":"hauteur","generic_type":"FLAP_STATE","eqType":"voletProp","name":"Hauteur","order":"1","type":"info","subType":"numeric","eqLogic_id":"75","isVisible":1,"alert":[],"currentValue":0,"configuration":{"phpType":"double"}}
[12/11/2020, 6:02:58 PM] [Jeedom Delta] [DEBUG] ---------update Blinds Value(refresh): 100 % soit 100  /  100
[12/11/2020, 6:02:58 PM] [Jeedom Delta] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Hauteur" (881) Envoi valeur: 100 dans Current Position
[12/11/2020, 6:02:58 PM] [Jeedom Delta] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Hauteur" (881) Envoi valeur: 100 dans Target Position
Avec HomeKit :
[2020-12-11 19:08:51][DEBUG] : [Appartement][Grand Volet Prop] Ajout du temps de décollement
[2020-12-11 19:08:51][DEBUG] : [Appartement][Grand Volet Prop] Temps d'action 24772500µs
[2020-12-11 19:08:51][DEBUG] : [Appartement][Grand Volet Prop] Nous allons monter le volet de 99%
[2020-12-11 19:09:01][INFO] : [Appartement][Grand Volet Prop][Timeout] Temps d'attente: 10245972.156525 < 27750000, Nous attendons
[2020-12-11 19:09:16][DEBUG] : [Appartement][Grand Volet Prop] Temps de mouvement du volet de 24833540µs
[2020-12-11 19:09:16][DEBUG] : [Appartement][Grand Volet Prop] Suppression du temps de decollement
[2020-12-11 19:09:16][DEBUG] : [Appartement][Grand Volet Prop] Mouvement du volet de 88%
[2020-12-11 19:09:16][DEBUG] : [Appartement][Grand Volet Prop] Le volet est a 88%
[12/11/2020, 6:08:51 PM] [Jeedom Delta] [INFO] [Commande d'Homekit] Nom:Target Position(0000007C-0000-1000-8000-0026BB765291):0->100 					|||characteristic:{"_events":{},"_eventsCount":3,"displayName":"Target Position","UUID":"0000007C-0000-1000-8000-0026BB765291","iid":11,"value":0,"status":null,"eventOnlyCharacteristic":false,"subscriptions":3,"props":{"format":"uint8","unit":"percentage","minValue":0,"maxValue":100,"minStep":1,"perms":["pr","pw","ev"],"needsBinding":true}}
[12/11/2020, 6:08:53 PM] [Jeedom Delta] [INFO] [Maj reçue de Jeedom] commande:829 value:0
[12/11/2020, 6:08:53 PM] [Jeedom Delta] [INFO] [[Modification Cache Jeedom: Grand volet>État(FLAP_STATE) de  vers 0 dans {"id":"829","logicalId":"3","generic_type":"FLAP_STATE","eqType":"Freebox_OS","name":"État","order":"2","type":"info","subType":"binary","eqLogic_id":"68","isVisible":1,"alert":[],"currentValue":"","display":{"invertBinary":0},"configuration":{"phpType":"integer"}}
[12/11/2020, 6:09:16 PM] [Jeedom Delta] [INFO] [Commande T envoyée à Jeedom] cmdId:882 action:flapUp value: 99 response:[]
[12/11/2020, 6:09:17 PM] [Jeedom Delta] [INFO] [Maj reçue de Jeedom] commande:829 value:
[12/11/2020, 6:09:17 PM] [Jeedom Delta] [INFO] [[Modification Cache Jeedom: Grand volet>État(FLAP_STATE) de 0 vers  dans {"id":"829","logicalId":"3","generic_type":"FLAP_STATE","eqType":"Freebox_OS","name":"État","order":"2","type":"info","subType":"binary","eqLogic_id":"68","isVisible":1,"alert":[],"currentValue":0,"display":{"invertBinary":0},"configuration":{"phpType":"integer"}}
[12/11/2020, 6:09:17 PM] [Jeedom Delta] [INFO] [Maj reçue de Jeedom] commande:881 value:88
[12/11/2020, 6:09:17 PM] [Jeedom Delta] [INFO] [[Modification Cache Jeedom: Grand Volet Prop>Hauteur(FLAP_STATE) de 0 vers 88 dans {"id":"881","logicalId":"hauteur","generic_type":"FLAP_STATE","eqType":"voletProp","name":"Hauteur","order":"1","type":"info","subType":"numeric","eqLogic_id":"75","isVisible":1,"alert":[],"currentValue":0,"configuration":{"phpType":"double"}}
[12/11/2020, 6:09:17 PM] [Jeedom Delta] [DEBUG] ---------update Blinds Value(refresh): 88 % soit 88  /  100
[12/11/2020, 6:09:17 PM] [Jeedom Delta] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Hauteur" (881) Envoi valeur: 88 dans Current Position
[12/11/2020, 6:09:17 PM] [Jeedom Delta] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Hauteur" (881) Envoi valeur: 88 dans Target Position
Donc la clairement on a un flapup qui appuie sur la commande monter et puis une réponse de jeedom qui dit qu’on est à 88%… @mika-nt28 ?
@mika-nt28 pourquoi je reçois un flap_state vide ?
De mon côté une valeur numérique ne peut être une chaîne vide ""…
La je suis perdu completement
Si tu fait simplement un flapup du coup on vas attendre le timeout et c’est le plugin qui executera le stop
La je n’ai pas de log du up (il manque au plugin je pousse la correction)
On a pas dépassé le timeout et on a pas de stop
@Anthony78 tu n’as plus de retour d’etat la?
Oui J’ai retiré les deux retours d’états
Du coup, que dois-je faire de plus ?
Aucune idée
Question bête, mais s’il y a des modifs à faire, est-ce à toi de le faire ou à @nebz ?
Aucune idée
Question subsidiaire : quel est le type de volet ? Quelle connectique ?
Xav
Perso mon volet marche toujours malgré la mise à jour
J’avais le problème déjà avant la mise à jour donc ça ne vient pas de là. Le volet marche très bien via jeedom. J’ai un décalage d’ouverture en utilisant HomeKit.
Idem pour mon deuxième volet, la seule différence c’est que lui s’arrête à 93%
pour moi ca vient de là…
En tout cas on est d’accord que ça ne vient pas d’un mauvais parametrage de mon côté ?
aucune idée… ta question est trop dépendante du plugin voletprops
ta question <-> volet prop <-> homebridge
Espérons que ça vienne de là alors :crossed_fingers:
C’est peut-être le execCmd qui fait ça mais dans tous les cas vue que tu ne l’arrêt pas ce n’est pas le soucis.
Je n’ai pas fait attention dans les log homekite si la commande est exécuter plusieurs fois
La mise à jour d’aujourd’hui c’est uniquement l’ajout de log pour comprendre le problème
@Anthony78 peux tu refaire l’essai avec homekite et récupérer les log
sans HomeKit :
[2020-12-15 20:18:42][DEBUG] : [Appartement][Grand Volet Prop] Execution de la commande [Appartement][Grand volet][Haut]
[2020-12-15 20:18:53][INFO] : [Appartement][Grand Volet Prop][Timeout] Temps d'attente: 10367180.109024 < 27750000, Nous attendons
[2020-12-15 20:19:10][INFO] : [Appartement][Grand Volet Prop][Timeout] Execution du stop
[2020-12-15 20:19:10][DEBUG] : [Appartement][Grand Volet Prop] Execution de la commande [Appartement][Grand volet][Stop]
[2020-12-15 20:19:10][DEBUG] : [Appartement][Grand Volet Prop] Mise a jours manuel de la hauteur
[2020-12-15 20:19:10][DEBUG] : [Appartement][Grand Volet Prop] Temps de mouvement du volet de 27902247µs
[2020-12-15 20:19:10][DEBUG] : [Appartement][Grand Volet Prop] Mouvement du volet de 114%
[2020-12-15 20:19:10][DEBUG] : [Appartement][Grand Volet Prop] Le volet est a 100%
avec homekit :
[2020-12-15 20:20:22][DEBUG] : [Appartement][Grand Volet Prop] Ajout du temps de décollement
[2020-12-15 20:20:22][DEBUG] : [Appartement][Grand Volet Prop] Temps d'action 24772500µs
[2020-12-15 20:20:22][DEBUG] : [Appartement][Grand Volet Prop] Nous allons monter le volet de 99%
[2020-12-15 20:20:43][INFO] : [Appartement][Grand Volet Prop][Timeout] Temps d'attente: 20952353.000641 < 27750000, Nous attendons
[2020-12-15 20:20:47][DEBUG] : [Appartement][Grand Volet Prop] Temps de mouvement du volet de 24844597µs
[2020-12-15 20:20:47][DEBUG] : [Appartement][Grand Volet Prop] Suppression du temps de decollement
[2020-12-15 20:20:47][DEBUG] : [Appartement][Grand Volet Prop] Mouvement du volet de 88%
[2020-12-15 20:20:47][DEBUG] : [Appartement][Grand Volet Prop] Le volet est a 88%
Je n’ai toujours pas les log d’execution de l’ordre
De plus si vraiment on fait un flap up on doit pas avoir ses log car ce n’est pas du proprtionnel du coup.
Lorsque l’on a ses log on est forcement dans le proportionnel
@nebz a tu une idée de test qui peut aidé a comprendre car tu dis que tu envoie une montée et pas un prop alors que dans le log de mon plugin c’est certain c’est du prop.
@Anthony78 peux tu poster un screen de ta configuration Volet prop et homekit, il y a peut etre une erreur de conf
