Debian 12
Core Alpha 4.4
1 seul plugin openvpn et rien d’autre !
Aller dans Menu configuration onglet OS / DB
Cliquer sur vérification générale :
0000|[START CONSISTENCY]
0001|[START CHECK AND FIX DB]
0002|[END CHECK AND FIX DB]
0003|Check jeedom package...
0004|OK
0005|Check jeedom database...OK
0006|Check crons...
0007|Check filesystem right...
0008|OK
0009|Flush cache widget...
0010|Check jeedom object...PHP Fatal error: Uncaught TypeError: flock(): Argument #1 ($stream) must be of type resource, bool given in /var/www/html/core/class/event.class.php:56
0011|Stack trace:
0012|#0 /var/www/html/core/class/event.class.php(56): flock()
0013|#1 /var/www/html/core/class/jeeObject.class.php(773): event::adds()
0014|#2 /var/www/html/install/consistency.php(406): jeeObject->save()
0015|#3 {main}
0016|thrown in /var/www/html/core/class/event.class.php on line 56
Sur ma vm avec deb11 core alpha 4.4 copie de ma prod passée en alpha, mise à jour ce matin quand je fais la même chose j’ai cela :
0003|Check jeedom package...OK
0004|Check jeedom database...OK
0005|Check crons...
0006|Check filesystem right...OK
0007|Flush cache widget...
0008|Check jeedom object...OK
0009|Check jeedom cmd...OK
0010|Set cache hour...OK
0011|Check composer...
0012|Need to install composer...PHP Warning: copy(): SSL operation failed with code 1. OpenSSL Error messages:
0013|error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed in Command line code on line 1
0014|PHP Warning: copy(): Failed to enable crypto in Command line code on line 1
0015|PHP Warning: copy(https://getcomposer.org/installer): failed to open stream: operation failed in Command line code on line 1
0016|PHP Warning: hash_file(composer-setup.php): failed to open stream: No such file or directory in Command line code on line 1
0017|PHP Warning: unlink(composer-setup.php): No such file or directory in Command line code on line 1
0018|PHP Warning: unlink(composer-setup.php): No such file or directory in Command line code on line 1
0019|rm: cannot remove '/usr/local/bin/composer': No such file or directory
0020|mv: cannot stat 'composer.phar': No such file or directory
0021|Begin installation of composer
0022|Installer corrupt
0023|Could not open input file: composer-setup.php
0024|End installation of composer
0025|OK
0026|Check nodejs...Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
0027|Hit:2 http://deb.debian.org/debian bullseye InRelease
0028|Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
0029|Get:4 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
0030|Fetched 4586 B in 1s (4987 B/s)
0031|Reading package lists...
0032|Reading package lists...
0033|Building dependency tree...
0034|Reading state information...
0035|apt-utils is already the newest version (2.2.4).
0036|build-essential is already the newest version (12.9).
0037|git is already the newest version (1:2.30.2-1+deb11u2).
0038|lsb-release is already the newest version (11.1.0).
0039|The following packages were automatically installed and are no longer required:
0040|libre2-9 linux-image-5.10.0-22-amd64 linux-image-5.10.0-23-amd64
0041|Use 'sudo apt autoremove' to remove them.
0042|0 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
0043|[Check Version NodeJS actuelle : v16.20.2 : [ OK ]
0044|[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
0045|OK
0046|[END CONSISTENCY]
On voit aussi des petits soucis…
