Comme indiqué dans le titre, je commande mon alarme le deamon passe en Nok. Autrement les remontées d’infos de mes portes et fenêtres fonctionnent correctement.
C’est un pb nouveau car ca fonctionnait avant sans n’avoir rien touché aux réglages. Mon mdp tydom est ok.
0000|10/26/2022 19:26:20 - Sending command 1666808780454 to DeltaDore....
0001|10/26/2022 19:26:21 - An expected message has been received from DeltaDore 1666808780454
0002|10/26/2022 19:26:21 - Sending DeltaDore response to Jeedom, command : 'getinstant'...
0003|10/26/2022 19:26:21 - Command 'energyInstant ELEC_A' has been posted to Jeedom successfully!
0004|10/26/2022 19:26:25 - Sending command 1666808785453 to DeltaDore....
0005|10/26/2022 19:26:26 - An expected message has been received from DeltaDore 1666808785453
0006|10/26/2022 19:26:26 - Sending DeltaDore response to Jeedom, command : 'getinstant'...
0007|10/26/2022 19:26:26 - Command 'energyInstant ELEC_A' has been posted to Jeedom successfully!
0008|10/26/2022 19:26:30 - Sending command 1666808790452 to DeltaDore....
0009|10/26/2022 19:26:31 - An expected message has been received from DeltaDore 1666808790452
0010|10/26/2022 19:26:31 - Sending DeltaDore response to Jeedom, command : 'getinstant'...
0011|10/26/2022 19:26:31 - Command 'energyInstant ELEC_A' has been posted to Jeedom successfully!
0012|10/26/2022 19:26:35 - Sending command 1666808795452 to DeltaDore....
0013|10/26/2022 19:26:36 - An expected message has been received from DeltaDor
met bien les logs en debug et ci ca replante prend les log avant de redémarrer le daemon
il me semble que le fait de redémarrer le daemon efface les logs sur le plugin jeedore
0000|10/28/2022 16:23:13 - Websocket connection initialization....
0001|10/28/2022 16:23:13 - Connecting to '192.168.0.14'
0002|10/28/2022 16:23:13 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
0003|10/28/2022 16:23:13 - Jeedore Daemon connection has been closed...
0004|10/28/2022 16:23:13 - Connection to DeltaDore server has been closed...
0005|10/28/2022 16:23:18 - Stoping timer Info
0006|10/28/2022 16:23:18 - Stoping timer energyInstant ELEC_A
0007|10/28/2022 16:23:18 - Impossible to launch JeeDore Server
0008|10/28/2022 16:23:18 - Value cannot be null. (Parameter 'ids')
0009|10/28/2022 16:23:18 - Impossible to launch Jeedore daemon...
0010|10/28/2022 16:23:18 - Value cannot be null. (Parameter 'ids')
0011|10/28/2022 16:23:18 - Daemon has been stopped...
avec la tydom 2.0 ? J’ai l’impression que ca ne fonctionne plus depuis que j’ai installé MQTT manager pour la dernière plugin roomba. Est ce que de ton coté tu as ce plugin ?
