Deamon ne demarre pas
Bonjour.
Je viens d’installer un nouveau Jeedom et impossible de lancer le deamon du plugin TTSCAST.
Page Santé :
Logs d’installation des dépendances :
[2024-12-29 16:18:23] **********************
[2024-12-29 16:18:23] * Check Script Params *
[2024-12-29 16:18:23] ** Force System Updates :: NO **
[2024-12-29 16:18:23] ** Force Reinit PyEnv :: NO **
[2024-12-29 16:18:23] ** Force Reinit Venv :: YES **
[2024-12-29 16:18:23] * Check PyEnv Dir *
[2024-12-29 16:18:23] ** PyEnv Directory (None) :: /opt/pyenv **
[2024-12-29 16:18:23] ** Check PyEnv :: Done **
[2024-12-29 16:18:23] ***********************
[2024-12-29 16:18:23] * Check Old PyEnv Dir *
[2024-12-29 16:18:23] ** PyEnv Old Directory (None) :: /var/www/html/plugins/ttscast/resources/pyenv **
[2024-12-29 16:18:23] ** Venv Update :: Not Needed **
[2024-12-29 16:18:23] ** Check Old PyEnv :: Done **
[2024-12-29 16:18:23] * Update apt-get *
[2024-12-29 16:18:23] ** Clean apt-get :: Done **
[2024-12-29 16:18:24] Hit:1 http://deb.debian.org/debian bookworm InRelease
[2024-12-29 16:18:24] Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
[2024-12-29 16:18:24] Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
[2024-12-29 16:18:24] Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
[2024-12-29 16:18:24] Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
[2024-12-29 16:18:28] Reading package lists...
[2024-12-29 16:18:28] ** Update apt-get :: Done **
[2024-12-29 16:18:28] ****************************
[2024-12-29 16:18:28] * Simulate apt-get upgrade *
[2024-12-29 16:18:29] Building dependency tree...
[2024-12-29 16:18:29] Reading state information...
[2024-12-29 16:18:30] Calculating upgrade...
[2024-12-29 16:18:31] 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[2024-12-29 16:18:31] ** Upgrade Simulation :: Done **
[2024-12-29 16:18:31] ****************************************
[2024-12-29 16:18:31] * Install apt-get packages for Python3 *
[2024-12-29 16:18:31] Reading package lists...
[2024-12-29 16:18:32] Building dependency tree...
[2024-12-29 16:18:32] Reading state information...
[2024-12-29 16:18:33] python3 is already the newest version (3.11.2-1+b1).
[2024-12-29 16:18:33] python3-requests is already the newest version (2.28.1+dfsg-1).
[2024-12-29 16:18:33] python3-pip is already the newest version (23.0.1+dfsg-1+rpt1).
[2024-12-29 16:18:33] python3-setuptools is already the newest version (66.1.1-1).
[2024-12-29 16:18:33] python3-dev is already the newest version (3.11.2-1+b1).
[2024-12-29 16:18:33] python3-venv is already the newest version (3.11.2-1+b1).
[2024-12-29 16:18:33] 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[2024-12-29 16:18:33] ** Install packages for Python3 :: Done **
[2024-12-29 16:18:33] ***************************
[2024-12-29 16:18:33] * Check Python3.x Version *
[2024-12-29 16:18:33] Python3.x Version :: 3.11
[2024-12-29 16:18:33] ** Check Python3 Version :: Done **
[2024-12-29 16:18:33] * PyEnv Environment *
[2024-12-29 16:18:33] ** PyEnv not required (Python >= 3.11) **
[2024-12-29 16:18:33] * Create Python3.11 venv *
[2024-12-29 16:18:55] ** Create Python3.11 Venv :: Done **
[2024-12-29 16:18:55] *****************************
[2024-12-29 16:18:55] * Install Python3 libraries *
[2024-12-29 16:18:57] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
[2024-12-29 16:18:57] Requirement already satisfied: pip in ./venv/lib/python3.11/site-packages (24.3.1)
[2024-12-29 16:18:58] Collecting wheel
[2024-12-29 16:18:58]   Using cached https://www.piwheels.org/simple/wheel/wheel-0.45.1-py3-none-any.whl (72 kB)
[2024-12-29 16:18:58] Installing collected packages: wheel
[2024-12-29 16:18:58] Successfully installed wheel-0.45.1
[2024-12-29 16:18:58] ** Install Pip / Wheel :: Done **
[2024-12-29 16:18:59] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
[2024-12-29 16:19:00] Collecting PyChromecast==14.0.4 (from -r /var/www/html/plugins/ttscast/resources/requirements.txt (line 1))
[2024-12-29 16:19:00]   Using cached https://www.piwheels.org/simple/pychromecast/PyChromecast-14.0.4-py2.py3-none-any.whl (76 kB)
[2024-12-29 16:19:00] Collecting google-cloud-texttospeech==2.18.0 (from -r /var/www/html/plugins/ttscast/resources/requirements.txt (line 2))
[2024-12-29 16:19:00]   Using cached https://www.piwheels.org/simple/google-cloud-texttospeech/google_cloud_texttospeech-2.18.0-py2.py3-none-any.whl (161 kB)
[2024-12-29 16:19:00] Collecting gTTS==2.5.3 (from -r /var/www/html/plugins/ttscast/resources/requirements.txt (line 3))
[2024-12-29 16:19:01]   Using cached https://www.piwheels.org/simple/gtts/gTTS-2.5.3-py3-none-any.whl (29 kB)
[2024-12-29 16:19:02] Collecting protobuf>=4.25.1 (from PyChromecast==14.0.4->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 1))
[2024-12-29 16:19:02]   Using cached protobuf-5.29.2-cp38-abi3-manylinux2014_aarch64.whl.metadata (592 bytes)
[2024-12-29 16:19:06] Collecting zeroconf>=0.25.1 (from PyChromecast==14.0.4->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 1))
[2024-12-29 16:19:06]   Using cached zeroconf-0.136.2-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (6.0 kB)
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))': /simple/casttube/
[2024-12-29 16:19:06] Collecting casttube>=0.2.0 (from PyChromecast==14.0.4->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 1))
[2024-12-29 16:19:06]   Using cached https://www.piwheels.org/simple/casttube/casttube-0.2.1-py3-none-any.whl (6.5 kB)
[2024-12-29 16:19:07] Collecting google-api-core!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1 (from google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-cloud-texttospeech==2.18.0->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 2))
[2024-12-29 16:19:08]   Using cached https://www.piwheels.org/simple/google-api-core/google_api_core-2.24.0-py3-none-any.whl (158 kB)
[2024-12-29 16:19:08] Collecting google-auth!=2.24.0,!=2.25.0,<3.0.0dev,>=2.14.1 (from google-cloud-texttospeech==2.18.0->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 2))
[2024-12-29 16:19:08]   Using cached https://www.piwheels.org/simple/google-auth/google_auth-2.37.0-py2.py3-none-any.whl (209 kB)
[2024-12-29 16:19:09] Collecting proto-plus<2.0.0dev,>=1.22.3 (from google-cloud-texttospeech==2.18.0->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 2))
[2024-12-29 16:19:09]   Using cached https://www.piwheels.org/simple/proto-plus/proto_plus-1.25.0-py3-none-any.whl (50 kB)
[2024-12-29 16:19:09] Collecting requests<3,>=2.27 (from gTTS==2.5.3->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 3))
[2024-12-29 16:19:09]   Using cached https://www.piwheels.org/simple/requests/requests-2.32.3-py3-none-any.whl (64 kB)
[2024-12-29 16:19:09] Collecting click<8.2,>=7.1 (from gTTS==2.5.3->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 3))
[2024-12-29 16:19:09]   Using cached https://www.piwheels.org/simple/click/click-8.1.8-py3-none-any.whl (98 kB)
[2024-12-29 16:19:10] Collecting googleapis-common-protos<2.0.dev0,>=1.56.2 (from google-api-core!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-cloud-texttospeech==2.18.0->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 2))
[2024-12-29 16:19:10]   Using cached https://www.piwheels.org/simple/googleapis-common-protos/googleapis_common_protos-1.66.0-py2.py3-none-any.whl (221 kB)
[2024-12-29 16:19:13] Collecting grpcio<2.0dev,>=1.33.2 (from google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-cloud-texttospeech==2.18.0->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 2))
[2024-12-29 16:19:13]   Using cached grpcio-1.68.1-cp311-cp311-manylinux_2_17_aarch64.whl.metadata (3.9 kB)
[2024-12-29 16:19:13] Collecting grpcio-status<2.0.dev0,>=1.33.2 (from google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-cloud-texttospeech==2.18.0->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 2))
[2024-12-29 16:19:13]   Using cached https://www.piwheels.org/simple/grpcio-status/grpcio_status-1.68.1-py3-none-any.whl (14 kB)
[2024-12-29 16:19:14] Collecting cachetools<6.0,>=2.0.0 (from google-auth!=2.24.0,!=2.25.0,<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.18.0->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 2))
[2024-12-29 16:19:14]   Using cached https://www.piwheels.org/simple/cachetools/cachetools-5.5.0-py3-none-any.whl (9.5 kB)
[2024-12-29 16:19:14] Collecting pyasn1-modules>=0.2.1 (from google-auth!=2.24.0,!=2.25.0,<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.18.0->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 2))
[2024-12-29 16:19:14]   Using cached https://www.piwheels.org/simple/pyasn1-modules/pyasn1_modules-0.4.1-py3-none-any.whl (181 kB)
[2024-12-29 16:19:14] Collecting rsa<5,>=3.1.4 (from google-auth!=2.24.0,!=2.25.0,<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.18.0->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 2))
[2024-12-29 16:19:14]   Using cached https://www.piwheels.org/simple/rsa/rsa-4.9-py3-none-any.whl (34 kB)
[2024-12-29 16:19:15] Collecting charset-normalizer<4,>=2 (from requests<3,>=2.27->gTTS==2.5.3->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 3))
[2024-12-29 16:19:15]   Using cached charset_normalizer-3.4.1-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (35 kB)
[2024-12-29 16:19:15] Collecting idna<4,>=2.5 (from requests<3,>=2.27->gTTS==2.5.3->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 3))
[2024-12-29 16:19:15]   Using cached https://www.piwheels.org/simple/idna/idna-3.10-py3-none-any.whl (70 kB)
[2024-12-29 16:19:15] Collecting urllib3<3,>=1.21.1 (from requests<3,>=2.27->gTTS==2.5.3->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 3))
[2024-12-29 16:19:15]   Using cached https://www.piwheels.org/simple/urllib3/urllib3-2.3.0-py3-none-any.whl (128 kB)
[2024-12-29 16:19:15] Collecting certifi>=2017.4.17 (from requests<3,>=2.27->gTTS==2.5.3->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 3))
[2024-12-29 16:19:15]   Using cached https://www.piwheels.org/simple/certifi/certifi-2024.12.14-py3-none-any.whl (164 kB)
[2024-12-29 16:19:16] Collecting ifaddr>=0.1.7 (from zeroconf>=0.25.1->PyChromecast==14.0.4->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 1))
[2024-12-29 16:19:16]   Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
[2024-12-29 16:19:16] Collecting pyasn1<0.7.0,>=0.4.6 (from pyasn1-modules>=0.2.1->google-auth!=2.24.0,!=2.25.0,<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.18.0->-r /var/www/html/plugins/ttscast/resources/requirements.txt (line 2))
[2024-12-29 16:19:16]   Using cached https://www.piwheels.org/simple/pyasn1/pyasn1-0.6.1-py3-none-any.whl (83 kB)
[2024-12-29 16:19:16] Using cached protobuf-5.29.2-cp38-abi3-manylinux2014_aarch64.whl (319 kB)
[2024-12-29 16:19:16] Using cached zeroconf-0.136.2-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (11.3 MB)
[2024-12-29 16:19:16] Using cached charset_normalizer-3.4.1-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (139 kB)
[2024-12-29 16:19:16] Using cached grpcio-1.68.1-cp311-cp311-manylinux_2_17_aarch64.whl (5.7 MB)
[2024-12-29 16:19:17] Installing collected packages: ifaddr, zeroconf, urllib3, pyasn1, protobuf, idna, grpcio, click, charset-normalizer, certifi, cachetools, rsa, requests, pyasn1-modules, proto-plus, googleapis-common-protos, gTTS, grpcio-status, google-auth, casttube, PyChromecast, google-api-core, google-cloud-texttospeech
[2024-12-29 16:19:21] Successfully installed PyChromecast-14.0.4 cachetools-5.5.0 casttube-0.2.1 certifi-2024.12.14 charset-normalizer-3.4.1 click-8.1.8 gTTS-2.5.3 google-api-core-2.24.0 google-auth-2.37.0 google-cloud-texttospeech-2.18.0 googleapis-common-protos-1.66.0 grpcio-1.68.1 grpcio-status-1.68.1 idna-3.10 ifaddr-0.2.0 proto-plus-1.25.0 protobuf-5.29.2 pyasn1-0.6.1 pyasn1-modules-0.4.1 requests-2.32.3 rsa-4.9 urllib3-2.3.0 zeroconf-0.136.2
[2024-12-29 16:19:22] ** Install Python3 libraries :: Done **
[2024-12-29 16:19:22] ****************************
[2024-12-29 16:19:22] * Set Owner on Directories *
[2024-12-29 16:19:23] ** Set Owner for Venv Dir :: Done **
[2024-12-29 16:19:23] ****************
[2024-12-29 16:19:23] * Install DONE *
Logs ttscast_deamon :
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] Start Daemon
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] Plugin Version: 1.5.20
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] Log level: debug
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] Socket port: 55111
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] Socket host: localhost
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] CycleFactor: 1.0
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] CycleMain: 2.0
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] CycleComm: 0.5
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] CycleEvent: 0.5
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] PID file: /tmp/jeedom/ttscast/deamon.pid
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] ApiKey: ***
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] ApiTTSKey: ***
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] Google Cloud ApiKey: noKey
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] VoiceRSS ApiKey: ***
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] App Disable Ding: False
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] Cmd Wait Timeout: 60
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] CallBack: http://127.0.0.1:80/plugins/ttscast/core/php/jeettscast.php
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] Jeedom WebSrvCache: http://192.168.1.74/plugins/ttscast/data/cache/
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] Jeedom WebSrvMedia: http://192.168.1.74/plugins/ttscast/data/media/
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] Jeedom WebSrvImages: http://192.168.1.74/plugins/ttscast/data/images/
[2024-12-29 16:21:02][INFO] : [DAEMON][MAIN] Jeedom WebSrvJeeTTS: http://192.168.1.74/core/api/
[2024-12-29 16:21:02][DEBUG] : [DAEMON][UTILS] Writing PID 8830 to /tmp/jeedom/ttscast/deamon.pid
[2024-12-29 16:21:02][INFO] : [DAEMON][COM] Init request module v2.32.3
[2024-12-29 16:21:02][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2024-12-29 16:21:02][DEBUG] : http://127.0.0.1:80 "GET /plugins/ttscast/core/php/jeettscast.php?apikey=e7vxhuhljV6NiLSJ1147vkwRDpMpOHsIxH8svGgvYURLCKzXW64D1FAaGkBp2KRe HTTP/1.1" 403 199
[2024-12-29 16:21:02][ERROR] : [DAEMON][COM][TEST] Callback result as a unknown error: 'Response' object has no attribute 'status'. Please check your network configuration page
[2024-12-29 16:21:02][ERROR] : [DAEMON][JEEDOMCOM] sendToJeedom :: Network communication ERROR (Daemon to Jeedom)
[2024-12-29 16:21:02][INFO] : [DAEMON] Shutdown :: Begin...
[2024-12-29 16:21:02][INFO] : [DAEMON] Shutdown :: Devices Disconnect :: Begin...
[2024-12-29 16:21:02][INFO] : [DAEMON] Shutdown :: Devices Disconnect :: OK
[2024-12-29 16:21:02][INFO] : [DAEMON] Shutdown :: Browser Stop :: OK
[2024-12-29 16:21:02][INFO] : [DAEMON] Shutdown :: ZeroConf Close :: OK
[2024-12-29 16:21:02][DEBUG] : [DAEMON] Removing PID file /tmp/jeedom/ttscast/deamon.pid
[2024-12-29 16:21:02][INFO] : [DAEMON] Shutdown :: Exit 0
La clé API TTS est bien là et active :
J’ai aussi testé ça (vu sur un post ou vous avez répondu à un problème similaire):
http://:80/plugins/ttscast/core/php/jeettscast.php?apikey=xxxxx&test=1
En remplaçant xxx par ma clé API et j’ai le retour :
peut être à voir, vérifier, nous montrer
Voilà la page de config network :
Pourquoi masquer l’IP sur la capture ? :thinking:
Surtout après le log fournit
vielle habitude :sweat_smile:
Ca ne sert à rien de masquer une IP privée !
C’est bizarre, d’après les logs, on dirait que l’accès au fichier php est refusé, alors que chez d’autres cela fonctionne. Et j’ai également un Debian 12 sur lequel le plugin est installé et il fonctionne sans rien modifier :thinking:
Tu as fait des modifs au niveau apache par exemple pour cette installation de jeedom? Ou une autre modif liée à la sécurité?
Pour tester chez toi, voir si cela viendrait de là, via l’éditeur de fichier inclus dans jeedom, tu peux modifier le fichier .htaccess qui se trouve dans le répertoire : plugins/ttscast/core/php :
Avant :
Order allow,deny
Deny from all
Après :
Order allow,deny
Allow from 127.0.0.1
Deny from all
Et me dire ensuite si c’est mieux ?
Si ce n’est pas mieux, ce n’est pas idéal, mais tu peux tester de supprimer ce fichier .htaccess et retester à nouveau ensuite.
PS : Désolé, je n’ai pas de PC à dispo où je me trouve cette semaine, du coup aucun moyen de tester…
TiTidom.
Merci pour ta réponse.
Pour répondre à ta question, je n’ai fait aucune modification sur Apache j’ai installé l’OS debian sur mon Pi4 et j’ai installé Jeedom en suivant le tuto trouvé sur le Forum.
J’ai testé l’ajout de la ligne dans le fichier .htaccess et j’ai relancé mon Deamon mais cela n’a rien donné. Toujours la même erreur.
J’ai ensuite supprimé le fichier et relancé mon deamon et là tout est passé à OK :
Dans le logs ttcast_deamon il voit mes périphériques maintenant Google donc je pense que c’est bon. :crossed_fingers:
Je vais tester demain et on verra bien et je te tiens au courant.
Je viens de faire mes tests et tout fonctionne.
Merci pour ton aide :wink:
