Cron_execution
Le log cron_execution parle beaucoup trop.
Le plugin fonctionne correctement et les log du plugin sont vides
3533|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3534|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3535|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3536|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3537|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3538|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3539|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3540|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3541|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3542|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3543|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3544|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3545|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3546|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3547|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3548|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3549|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3550|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3553|PHP Notice:  Undefined variable: localGatewayURL in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 14
3554|PHP Notice:  Undefined variable: localAPIToken in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 14
3555|PHP Notice:  Undefined variable: localGatewayURL in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 14
3556|PHP Notice:  Undefined variable: localAPIToken in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 14
3557|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3558|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3559|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3560|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3561|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3562|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3563|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3564|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3565|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3566|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3567|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3568|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3569|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3570|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3571|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3572|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3573|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3574|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3575|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3576|PHP Notice:  Undefined variable: localGatewayURL in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 14
3577|PHP Notice:  Undefined variable: localAPIToken in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 14
3578|PHP Notice:  Undefined variable: localGatewayURL in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 14
3579|PHP Notice:  Undefined variable: localAPIToken in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 14
3580|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3581|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3582|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3583|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3584|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3585|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3586|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3587|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3588|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3589|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3590|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3591|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3592|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3593|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3594|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3595|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3596|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3597|PHP Notice:  Undefined variable: localGatewayURL in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 14
3598|PHP Notice:  Undefined variable: localAPIToken in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 14
3599|PHP Notice:  Undefined variable: localGatewayURL in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 14
3600|PHP Notice:  Undefined variable: localAPIToken in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 14
3601|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3602|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3603|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3604|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3605|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3606|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3607|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3608|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3609|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3610|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3611|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
3612|PHP Warning:  "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
Informations Jeedom
Core : 4.4.20 (master)
DNS Jeedom : non
Plugin : SomfyUnified
Version : 2025-12-22 22:09:31 (stable)
Statut Démon : Démarré - (2026-01-06 13:55:26)
Merci de ce retour.
Je connais ce PHP warning (qui n’est qu’un warning) mais bizarre, je ne reproduis pas chez moi.
Le log cron_execution est vide.
Est-ce qu’il y a un paramètrage Jeedom qui pourrait expliquer cela ?
La ligne 36 du code fait 1km le long :face_with_thermometer:
Oui et alors ?
Je connais mon code.
La question est plutot: comment se fait-il que vous avez une remontée de tels warning dans votre log ?
Si il était en mode ligne on verrait peut être d’où cela provient….
Mais puisque je vous ai dit que je connaissais mon code.
Je sais très bien d’ou provient ce warning, je n’ai besoin d’aucune intervention.
Ok et il est provoqué par quoi ?
Je fais quoi ?
Je cherche pas, je laisse comme cela ?
Il n’existe aucun paramètre jeedom qui contrôle cela.
C’est juste un abus de syntaxe à corriger avant que ca ne deviennent bloquant: pas de continue dans un switch mais break ou continue xx
edit: je précise que mon intervention ici voulait surtout répondre à la question citée.
De mon point de vue, cette erreur (non bloquante pour l’instant effectivement), n’impacte pas la qualité du plugin (que je ne connais pas) ni la réputation du développeur; il ne faut donc certainement pas y voir un signe que c’est un mauvais plugin.
voir également ma réponse:
pour ceux qui savent ce qu’ils font :
vous recherchez
public static function cron()
dans la fonction
if (is_object($cmd)):
vous remplacez continue par continue 2
si vous avec transformer le code voir Ligne 8268
cela vous évitera d’avoir un log toutes les minutes
la dernière maj du plugin a largement contribuer à diminuer les causeries dans le log cron_execution
il reste cependant cela :
0647|PHP Notice:  Undefined index: extension2 in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
0648|PHP Notice:  Undefined index: extension2 in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
0649|PHP Notice:  Undefined index: extension2 in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
0650|PHP Notice:  Undefined index: extension2 in /var/www/html/plugins/SomfyUnified/core/class/SomfyUnified.class.php on line 36
0651|PHP Notice:  Undefined variable: localGatewayURL in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 385
0652|PHP Notice:  Undefined variable: localAPIToken in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 387
0653|PHP Notice:  Undefined variable: localGatewayURL in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 385
0654|PHP Notice:  Undefined variable: localAPIToken in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 387
0655|PHP Notice:  Undefined variable: localGatewayURL in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 385
0656|PHP Notice:  Undefined variable: localAPIToken in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 387
0657|PHP Notice:  Undefined variable: localGatewayURL in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 385
0658|PHP Notice:  Undefined variable: localAPIToken in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 387
0659|PHP Notice:  Undefined variable: localGatewayURL in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 385
0660|PHP Notice:  Undefined variable: localAPIToken in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 387
0661|PHP Notice:  Undefined variable: localGatewayURL in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 385
0662|PHP Notice:  Undefined variable: localAPIToken in /var/www/html/plugins/SomfyUnified/core/class/unifiedAPI/UnifiedAPI.class.php on line 387
