Subitement apres plus d’un ans de fonctionnement le #plugin-gsh ne fonctionne plus
J’ai recement migrer sur le DNS et mise a jours la configuration j’ai bien retrouvé le fonctionnement, mais depuis quelque jours plus rien
J’ai tenté une installation de dependance car j’ai vue qu’il y avait des discution sur la mise a jours de nodejs et elle n’arrive pas jusqu’au bout
* Installation des dépendances *
Hit:1 http://deb.debian.org/debian buster InRelease
Get:2 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Get:3 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
Get:5 http://security.debian.org/debian-security buster/updates/main Sources [187 kB]
Get:6 http://security.debian.org/debian-security buster/updates/main amd64 Packages [291 kB]
Get:7 http://security.debian.org/debian-security buster/updates/main Translation-en [151 kB]
Fetched 746 kB in 2s (302 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.6).
git is already the newest version (1:2.20.1-2+deb10u3).
lsb-release is already the newest version (10.2019051400).
apt-utils is already the newest version (1.8.2.3).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[Check Version NodeJS actuelle : v14.17.0 : [ OK ]
│ npm update check failed │
│ Try running with sudo or get access │
│ to the local update config store via │
│ sudo chown -R $USER:$(id -gn $USER) /var/www/.config │
[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
npm : Depends: nodejs (>= 6.11~) but it is not going to be installed
Depends: node-abbrev (>= 1.1.1~) but it is not going to be installed
Depends: node-ansi-regex (>= 3.0~) but it is not going to be installed
Depends: node-ansistyles (>= 0.1.3~) but it is not going to be installed
Depends: node-aproba (>= 1.2~) but it is not going to be installed
Depends: node-archy (>= 1.0~) but it is not going to be installed
Depends: node-cacache (>= 10.0.4~) but it is not going to be installed
Depends: node-bluebird (>= 3.5.1~) but it is not going to be installed
Depends: node-call-limit (>= 1.1~) but it is not going to be installed
Depends: node-chownr (>= 1.0.1~) but it is not going to be installed
Depends: node-config-chain (>= 1.1.11~) but it is not going to be installed
Depends: node-detect-indent (>= 5.0~) but it is not going to be installed
Depends: node-detect-newline (>= 2.1~) but it is not going to be installed
Depends: node-editor (>= 1.0~) but it is not going to be installed
Depends: node-fs-vacuum (>= 1.2.10~) but it is not going to be installed
Depends: node-fs-write-stream-atomic (>= 1.0.10~) but it is not going to be installed
Depends: node-glob (>= 7.1.2~) but it is not going to be installed
Depends: node-graceful-fs (>= 4.1.11~) but it is not going to be installed
Depends: node-has-unicode (>= 2.0.1~) but it is not going to be installed
Depends: node-hosted-git-info (>= 2.6~) but it is not going to be installed
Depends: node-iferr (>= 0.1.5~) but it is not going to be installed
Depends: node-inflight (>= 1.0.6~) but it is not going to be installed
Depends: node-inherits (>= 2.0.3~) but it is not going to be installed
Depends: node-ini (>= 1.3.5~) but it is not going to be installed
Depends: node-npm-package-arg but it is not going to be installed
Depends: node-promzard but it is not going to be installed
Depends: node-jsonstream (>= 1.3.2~) but it is not going to be installed
Depends: node-json-parse-better-errors (>= 1.0.1~) but it is not going to be installed
Depends: node-lazy-property (>= 1.0~) but it is not going to be installed
Depends: node-libnpx (>= 10.0.1~) but it is not going to be installed
Depends: node-lockfile (>= 1.0.3~) but it is not going to be installed
Depends: node-lru-cache (>= 4.1.1~) but it is not going to be installed
Depends: node-mississippi (>= 3.0~) but it is not going to be installed
Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed
Depends: node-move-concurrently (>= 1.0.1~) but it is not going to be installed
Depends: node-nopt but it is not going to be installed
Depends: node-normalize-package-data (>= 2.4~) but it is not going to be installed
Depends: node-gyp (>= 3.6.2~) but it is not going to be installed
Depends: node-resolve-from (>= 4.0~) but it is not going to be installed
Depends: node-encoding but it is not going to be installed
Depends: node-errno but it is not going to be installed
Depends: node-npmlog (>= 4.1.2~) but it is not going to be installed
Depends: node-once (>= 1.4~) but it is not going to be installed
Depends: node-opener (>= 1.4.3~) but it is not going to be installed
Depends: node-osenv (>= 0.1.5~) but it is not going to be installed
Depends: node-path-is-inside (>= 1.0.2~) but it is not going to be installed
Depends: node-promise-inflight (>= 1.0.1~) but it is not going to be installed
Depends: node-ansi but it is not going to be installed
Depends: node-qw (>= 1.0.1~) but it is not going to be installed
Depends: node-read (>= 1.0.7~) but it is not going to be installed
Depends: node-read-package-json (>= 2.0.13~) but it is not going to be installed
Depends: node-request (>= 2.83~) but it is not going to be installed
Depends: node-retry (>= 0.10.1~) but it is not going to be installed
Depends: node-rimraf (>= 2.6.2~) but it is not going to be installed
Depends: node-safe-buffer (>= 5.1.1~) but it is not going to be installed
Depends: node-semver (>= 5.5~) but it is not going to be installed
Depends: node-sha (>= 2.0.1~) but it is not going to be installed
Depends: node-slide (>= 1.1.6~) but it is not going to be installed
Depends: node-sorted-object (>= 2.0.1~) but it is not going to be installed
Depends: node-from2 but it is not going to be installed
Depends: node-stream-iterate but it is not going to be installed
Depends: node-ssri (>= 5.2.4~) but it is not going to be installed
Depends: node-strip-ansi (>= 4.0~) but it is not going to be installed
Depends: node-tar (>= 4.4~) but it is not going to be installed
Depends: node-text-table (>= 0.2~) but it is not going to be installed
Depends: node-uid-number (>= 0.0.6~) but it is not going to be installed
Depends: node-unique-filename (>= 1.1~) but it is not going to be installed
Depends: node-unpipe (>= 1.0~) but it is not going to be installed
Depends: node-boxen (>= 1.2.1~) but it is not going to be installed
Depends: node-import-lazy but it is not going to be installed
Depends: node-is-npm (>= 1.0~) but it is not going to be installed
Depends: node-latest-version (>= 3.0~) but it is not going to be installed
Depends: node-semver-diff (>= 2.0~) but it is not going to be installed
Depends: node-xdg-basedir (>= 3.0~) but it is not going to be installed
Depends: node-validate-npm-package-name (>= 3.0~) but it is not going to be installed
Depends: node-which (>= 1.3~) but it is not going to be installed
Depends: node-wrappy (>= 1.0.2~) but it is not going to be installed
Depends: node-write-file-atomic (>= 2.3~) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
audited 65 packages in 2.255s
found 2 vulnerabilities (1 low, 1 high)
run `npm audit fix` to fix them, or `npm audit` for details
* Installation terminée *
Dans le log gshd j’ai cette erreur
throw er; // Unhandled 'error' event
Error: bind EADDRINUSE 0.0.0.0:3311
at dgram.js:352:20
at processTicksAndRejections (internal/process/task_queues.js:83:21)
Emitted 'error' event on Socket instance at:
at dgram.js:354:14
at processTicksAndRejections (internal/process/task_queues.js:83:21) {
errno: -98,
code: 'EADDRINUSE',
syscall: 'bind',
address: '0.0.0.0',
port: 3311
