### Checklist
- [ ] I am not using Home Assistant. Or: a developer has told …me to come here.
- [ ] I have checked the troubleshooting section and my problem is not described there.
- [ ] I have read the changelog and my problem is not mentioned there.
### Deploy method
Docker
### Z-Wave JS UI version
9.0.3.c37f5a4
### ZwaveJS version
12.0.2
### Describe the bug
I am running a docker instance on my QNAP NAS.
I have several containers utilizing almost 0% CPU utilization.
When I start the zwavejs container I have continuous spikes to my CPU from 10-60% which can be seen on my dockerd process.
The actual container is 0%.
The dockerd starts like this
container-station/dockerd -H tcp://0.0.0.0:2376 -H unix:///var/run/docker.sock --bridge=lxcbr0 --tlsverify --tlscacert=/etc/docker/tls/ca.pem --tlscert=/etc/docker/tls/server.pem --tlskey=/etc/docker/tls/server-key.pem --storage-driver=overlay2 --dns 10.0.3.1 --data-root=/var/lib/docker --exec-root=/var/run/docker --pidfile=/var/run/docker.pid -D --userland-proxy=false --config-file /share/CACHEDEV2_DATA/.qpkg/container-station/etc/docker.json
and the zvavejs docker-compose.yaml file is the following
version: '3.7'
services:
zwavejs2mqtt:
container_name: zwavejs2mqtt
image: zwavejs/zwavejs2mqtt:latest
restart: always
tty: true
stop_signal: SIGINT
environment:
- SESSION_SECRET=mysupersecretkey
- ZWAVEJS_EXTERNAL_CONFIG=/usr/src/app/store/.config-db
# Uncomment if you want logs time and dates to match your timezone instead of UTC
# Available at https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
#- TZ=America/New_York
- TZ=Asia/Nicosia
networks:
- zwave
devices:
# Do not use /dev/ttyUSBX serial devices, as those mappings can change over time.
# Instead, use the /dev/serial/by-id/X serial device for your Z-Wave stick.
- '/dev/ttyACM0:/dev/zwave'
volumes:
- /share/Container/container-station-data/lib/docker/volumes/zwavejs2mqtt/_data:/usr/src/app/store
ports:
- '8091:8091' # port for web interface
- '3000:3000' # port for Z-Wave JS websocket server
networks:
zwave:
volumes:
zwave-config:
Also
```json
"mqtt": {
"name": "Zwavejs2Mqtt",
"host": "localhost",
"port": 1883,
"qos": 1,
"prefix": "zwave",
"reconnectPeriod": 3000,
"retain": true,
"clean": true,
"auth": false,
"_ca": "",
"ca": "",
"_cert": "",
"cert": "",
"_key": "",
"key": "",
"disabled": true
"gateway": {
"type": 0,
"plugins": [],
"authEnabled": false,
"payloadType": 0,
"nodeNames": true,
"hassDiscovery": true,
"discoveryPrefix": "homeassistant",
"logEnabled": true,
"logLevel": "info",
"logToFile": true,
"values": [
"device": "134-129-2",
"value": {
"id": "128-0-level",
"commandClass": 128,
"commandClassName": "Battery",
"endpoint": 0,
"property": "level",
"propertyName": "level",
"type": "number",
"readable": true,
"writeable": false,
"label": "Battery level",
"stateless": false,
"commandClassVersion": 1,
"min": 0,
"max": 100,
"unit": "%",
"list": false,
"value": 100,
"lastUpdate": 1651141622750
"enablePoll": true,
"pollInterval": 3600
"device": "134-130-2",
"value": {
"endpoint": 0,
"type": "number",
"readable": true,
"writeable": false,
"stateless": false,
"min": 0,
"max": 100,
"unit": "%",
"list": false,
"value": 47,
"lastUpdate": 1651141622845
"enablePoll": true,
"jobs": [],
"https": false
"zwave": {
"port": "/dev/zwave",
"allowBootloaderOnly": false,
"commandsTimeout": 30,
"logLevel": "info",
"rf": {
"txPower": {
"powerlevel": 0,
"measured0dBm": 0
"region": 0
"logEnabled": true,
"securityKeys": {
"S2_Unauthenticated": "x",
"S2_AccessControl": "x",
"S2_Authenticated": "x",
"S0_Legacy": "x"
"deviceConfigPriorityDir": "/usr/src/app/store/config",
"logToFile": true,
"maxFiles": 7,
"serverEnabled": true,
"serverServiceDiscoveryDisabled": false,
"enableSoftReset": true,
"enableStatistics": true,
"serverPort": 3000,
"maxNodeEventsQueueSize": 100,
"higherReportsTimeout": false,
"disclaimerVersion": 1
"backup": {
"storeBackup": false,
"storeCron": "0 0 * * *",
"storeKeep": 7,
"nvmBackup": false,
"nvmBackupOnEvent": false,
"nvmCron": "0 0 * * *",
"nvmKeep": 7
This think is driving me nuts.
Your help will be appreciated.
### To Reproduce
Start zwavejs container
### Expected behavior
Low CPU
### Additional context
_No response_
