Salut @lunarok
Quelques message d’erreur dans les traces apaches
[Sun Feb 09 18:06:15.477053 2020] [php7:notice] [pid 1113] [client 192.168.1.49:49890] PHP Notice: Uninitialized string offset: 1 in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 1234, referer: https://xxxxxxxxxxxxx.ddns.net/index.php?v=d&p=dashboard&object_id=1
[Sun Feb 09 18:06:15.479641 2020] [php7:notice] [pid 1113] [client 192.168.1.49:49890] PHP Notice: Uninitialized string offset: 3 in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 1234, referer: https://xxxxxxxxxxxxx.ddns.net/index.php?v=d&p=dashboard&object_id=1
[Sun Feb 09 18:06:15.479837 2020] [php7:notice] [pid 1113] [client 192.168.1.49:49890] PHP Notice: Uninitialized string offset: 4 in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 1234, referer: https://xxxxxxxxxxxxx.ddns.net/index.php?v=d&p=dashboard&object_id=1
[Sun Feb 09 18:06:15.479904 2020] [php7:warn] [pid 1113] [client 192.168.1.49:49890] PHP Warning: mktime() expects parameter 1 to be int, string given in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 1234, referer: https://xxxxxxxxxxxxx.ddns.net/index.php?v=d&p=dashboard&object_id=1
[Sun Feb 09 18:06:15.480014 2020] [php7:notice] [pid 1113] [client 192.168.1.49:49890] PHP Notice: Uninitialized string offset: 1 in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 1235, referer: https://xxxxxxxxxxxxx.ddns.net/index.php?v=d&p=dashboard&object_id=1
[Sun Feb 09 18:06:15.481038 2020] [php7:notice] [pid 1113] [client 192.168.1.49:49890] PHP Notice: Uninitialized string offset: 3 in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 1235, referer: https://xxxxxxxxxxxxx.ddns.net/index.php?v=d&p=dashboard&object_id=1
[Sun Feb 09 18:06:15.481137 2020] [php7:notice] [pid 1113] [client 192.168.1.49:49890] PHP Notice: Uninitialized string offset: 4 in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 1235, referer: https://xxxxxxxxxxxxx.ddns.net/index.php?v=d&p=dashboard&object_id=1
[Sun Feb 09 18:06:15.481184 2020] [php7:warn] [pid 1113] [client 192.168.1.49:49890] PHP Warning: mktime() expects parameter 1 to be int, string given in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 1235, referer: https://xxxxxxxxxxxxx.ddns.net/index.php?v=d&p=dashboard&object_id=1
J’ai un suivi sur la pluie à 1h et 2 vigicrue
$heure est vide au démarrage ?
$heure = substr_replace($echeance->execCmd(),':',-2,0);
[2020-02-09 18:17:21][ERROR] : Pollen geoloc non configuré.
[2020-02-09 18:17:21][INFO] : VigilanceMeteo de type 'pluie1h' mise a jour pour la ville 'xxxxxxxxxxxxx'
[2020-02-09 18:17:21][DEBUG] : Valeur niveau: 531
[2020-02-09 18:17:22][DEBUG] : Valeur débit: 432311
[2020-02-09 18:17:22][DEBUG] : Valeur niveau: 1181
[2020-02-09 18:17:22][DEBUG] : Valeur débit: 701
[2020-02-09 18:17:22][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=vigilancemeteo function=remove callInstallFunction=1
[2020-02-09 18:17:23][INFO] : Début d'activation du plugin
[2020-02-09 18:17:24][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2020-02-09 18:17:24][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=vigilancemeteo function=install callInstallFunction=1
[2020-02-09 18:17:52][ERROR] : Heure--->:
[2020-02-09 18:20:06][INFO] : VigilanceMeteo de type 'pluie1h' mise a jour pour la ville 'xxxxxxxxxxxxx'
[2020-02-09 18:20:31][ERROR] : 1825 Heure--->18:25
[2020-02-09 18:20:50][ERROR] : 1825 Heure--->18:25
A moins d’être tout seul une nouvelle fois à avoir ce souci
