Lorsque je lance le démon j’ai les erreurs suivantes :
[2021-01-10 19:16:50][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2021-01-10 19:16:54][INFO] : Lancement démon deconz : /usr/bin/python3 /var/www/html/plugins/deconz/resources/deconzd/deconzd.py --loglevel debug --socketport 55088 --callback http://127.0.0.1:80/plugins/deconz/core/php/jeeDeconz.php --apikey ..... --cycle 0 --pid /tmp/jeedom/deconz/deamon.pid
File "/var/www/html/plugins/deconz/resources/deconzd/deconzd.py", line 32, in <module>
from websocket import create_connection
ModuleNotFoundError: No module named 'websocket'
[2021-01-10 19:17:24][ERROR] : Impossible de lancer le démon deconz, vérifiez le port
J’installe ce module illico
#pip install websocket
Le démarrage du démon a réussi, mais ca ne va visiblement pas jusqu’au bout :
[2021-01-10 19:57:46.283][DEBUG] : Starting WebSocket for on ip nascc67b6 and port 32443
[2021-01-10 20:57:55][DEBUG] : nascc67b6:32770/api/F90D234FD0/sensors type : POST
[2021-01-10 20:57:55][DEBUG] : {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"b6d68567cd8d80938d4ee98e493f840d","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":true,"daylight":false,"lastupdated":"2021-01-10T18:20:25.481","status":230,"sunrise":"2021-01-10T07:27:43","sunset":"2021-01-10T16:37:59"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:06:ac:35-01"},"2":{"config":{"battery":74,"displayflipped":null,"heatsetpoint":2200,"locked":null,"mountingmode":true,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"640090b157df4b5ae5187048fb77e605","lastseen":"2021-01-10T19:57Z","manufacturername":"Danfoss","modelid":"eTRV0100","name":"Thermostat Danfoss Ally","state":{"errorcode":null,"lastupdated":"2021-01-10T19:40:45.133","mountingmodeactive":false,"on":false,"temperature":2467,"valve":0,"windowopen":"Closed"},"type":"ZHAThermostat","uniqueid":"cc:cc:cc:ff:fe:4e:01:db-01-0201"},"3":{"config":{"battery":74,"on":true,"reachable":true},"ep":1,"etag":"9b1f2fe8460510b007cca04b173c0ae4","lastseen":"2021-01-10T19:57Z","manufacturername":"Danfoss","modelid":"eTRV0100","name":"Thermostat Danfoss Ally","state":{"lastset":"2021-01-04T16:35:59Z","lastupdated":"2021-01-10T14:43:02.384","localtime":"2021-01-10T15:42:56","utc":"2021-01-10T14:42:56Z"},"type":"ZHATime","uniqueid":"cc:cc:cc:ff:fe:4e:01:db-01-000a"}}
[2021-01-10 20:57:55][DEBUG] : nascc67b6:32770/api/F90D234FD0/lights type : POST
[2021-01-10 20:57:55][DEBUG] : {"1":{"etag":"b3c7068bad1bdc658e9a4e3f74e6e914","hascolor":false,"lastannounced":null,"lastseen":"2021-01-10T19:57Z","manufacturername":"dresden elektronik","modelid":"ConBee II","name":"Configuration tool 1","state":{"reachable":true},"swversion":"0x26680700","type":"Configuration tool","uniqueid":"00:21:2e:ff:ff:06:ac:35-01"}}
[2021-01-10 19:58:24.081][DEBUG] : Signal 15 caught, exiting...
[2021-01-10 19:58:24.081][DEBUG] : Shutdown
[2021-01-10 19:58:24.081][DEBUG] : Removing PID file /tmp/jeedom/deconz/deamon.pid
[2021-01-10 19:58:24.309][DEBUG] : LoopNetServer Thread stopped
[2021-01-10 19:58:24.331][DEBUG] : Exit 0
Après la lecture de Capteurs xiaomi (via deconz) reçu par jeedom mais pas mis à jour (encore...) - #57 par altoinou, j’ai désactivé la gestion auto du démon ainsi que forcer les fuseaux horaires et le comportement est plus fiable et je vois le dialogue entre la gateway et jeedom … enfin !!
J’attend quelques jours pour verifier que cela fonctionne et je désactiverai soit les fuseaux soit la gestion auto pour voir lequel m’a posé tant de soucis …
[2021-01-10 21:59:16][DEBUG] : {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"b6d68567cd8d80938d4ee98e493f840d","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":true,"daylight":false,"lastupdated":"2021-01-10T18:20:25.481","status":230,"sunrise":"2021-01-10T07:27:43","sunset":"2021-01-10T16:37:59"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:06:ac:35-01"},"2":{"config":{"battery":73,"displayflipped":null,"heatsetpoint":2200,"locked":null,"mountingmode":true,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"2dac3921607c8599ba8ef64cf7d74b46","lastseen":"2021-01-10T20:59Z","manufacturername":"Danfoss","modelid":"eTRV0100","name":"Thermostat Danfoss Ally","state":{"errorcode":null,"lastupdated":"2021-01-10T20:51:45.112","mountingmodeactive":false,"on":false,"temperature":2315,"valve":0,"windowopen":"Closed"},"type":"ZHAThermostat","uniqueid":"cc:cc:cc:ff:fe:4e:01:db-01-0201"},"3":{"config":{"batter...
[2021-01-10 22:00:17][DEBUG] : {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"b6d68567cd8d80938d4ee98e493f840d","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":true,"daylight":false,"lastupdated":"2021-01-10T18:20:25.481","status":230,"sunrise":"2021-01-10T07:27:43","sunset":"2021-01-10T16:37:59"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:06:ac:35-01"},"2":{"config":{"battery":73,"displayflipped":null,"heatsetpoint":2200,"locked":null,"mountingmode":true,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"2dac3921607c8599ba8ef64cf7d74b46","lastseen":"2021-01-10T21:00Z","manufacturername":"Danfoss","modelid":"eTRV0100","name":"Thermostat Danfoss Ally","state":{"errorcode":null,"lastupdated":"2021-01-10T20:51:45.112","mountingmodeactive":false,"on":false,"temperature":2315,"valve":0,"windowopen":"Closed"},"type":"ZHAThermostat","uniqueid":"cc:cc:cc:ff:fe:4e:01:db-01-0201"},"3":{"config":{"batter...
[2021-01-10 22:01:17][DEBUG] : {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"b6d68567cd8d80938d4ee98e493f840d","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":true,"daylight":false,"lastupdated":"2021-01-10T18:20:25.481","status":230,"sunrise":"2021-01-10T07:27:43","sunset":"2021-01-10T16:37:59"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:06:ac:35-01"},"2":{"config":{"battery":73,"displayflipped":null,"heatsetpoint":2200,"locked":null,"mountingmode":true,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"2dac3921607c8599ba8ef64cf7d74b46","lastseen":"2021-01-10T21:01Z","manufacturername":"Danfoss","modelid":"eTRV0100","name":"Thermostat Danfoss Ally","state":{"errorcode":null,"lastupdated":"2021-01-10T20:51:45.112","mountingmodeactive":false,"on":false,"temperature":2315,"valve":0,"windowopen":"Closed"},"type":"ZHAThermostat","uniqueid":"cc:cc:cc:ff:fe:4e:01:db-01-0201"},"3":{"config":{"batter...
[2021-01-10 22:02:18][DEBUG] : {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"b6d68567cd8d80938d4ee98e493f840d","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":true,"daylight":false,"lastupdated":"2021-01-10T18:20:25.481","status":230,"sunrise":"2021-01-10T07:27:43","sunset":"2021-01-10T16:37:59"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:06:ac:35-01"},"2":{"config":{"battery":73,"displayflipped":null,"heatsetpoint":2200,"locked":null,"mountingmode":true,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"2dac3921607c8599ba8ef64cf7d74b46","lastseen":"2021-01-10T21:02Z","manufacturername":"Danfoss","modelid":"eTRV0100","name":"Thermostat Danfoss Ally","state":{"errorcode":null,"lastupdated":"2021-01-10T20:51:45.112","mountingmodeactive":false,"on":false,"temperature":2315,"valve":0,"windowopen":"Closed"},"type":"ZHAThermostat","uniqueid":"cc:cc:cc:ff:fe:4e:01:db-01-0201"},"3":{"config":{"batter...
