J’ai vu que le roborock renvoie les données des consommables, est-il possible de les ajouter au plugin pour générer des alertes?
[2020-03-25 19:45:06][DEBUG] : Send to jeedom : {u'devices': {u'wifi_192.168.0.50': {'ip': u'192.168.0.50', 'model': u'vacuum', u'get_status': {u'msg_ver': 8, u'clean_area': 96, u'battery': 100, u'error_code': 'Tout va bien', u'dnd_enabled': 0, u'fan_power': 100, u'state': 'En charge', u'map_present': 1, u'in_cleaning': 0, u'clean_time': '1:35:08s', u'msg_seq': 362}, u'get_consumable': {u'sensor_dirty_time': 569083, u'main_brush_work_time': 569083, u'side_brush_work_time': 569083, u'filter_work_time': 569083}}}}
[2020-03-25 19:45:06][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2020-03-25 19:45:06][DEBUG] : Status Array ( [ip] => 192.168.0.50 [model] => vacuum [get_status] => Array ( [msg_ver] => 8 [clean_area] => 96 [battery] => 100 [error_code] => Tout va bien [dnd_enabled] => 0 [fan_power] => 100 [state] => En charge [map_present] => 1 [in_cleaning] => 0 [clean_time] => 1:35:08s [msg_seq] => 362 ) [get_consumable] => Array ( [sensor_dirty_time] => 569083 [main_brush_work_time] => 569083 [side_brush_work_time] => 569083 [filter_work_time] => 569083 ) )
Les infos sont bien remises à 0 quand on fait le reset via l’appli (exemple mes sensor):
[2020-03-25 19:50:06][DEBUG] : Send to jeedom : {u'devices': {u'wifi_192.168.0.50': {'ip': u'192.168.0.50', 'model': u'vacuum', u'get_status': {u'msg_ver': 8, u'clean_area': 0, u'battery': 100, u'error_code': 'Tout va bien', u'dnd_enabled': 0, u'fan_power': 100, u'state': 'En charge', u'map_present': 1, u'in_cleaning': 0, u'clean_time': '0:00:00s', u'msg_seq': 392}, u'get_consumable': {u'sensor_dirty_time': 0, u'main_brush_work_time': 569083, u'side_brush_work_time': 569083, u'filter_work_time': 569083}}}}
[2020-03-25 19:50:06][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2020-03-25 19:50:06][DEBUG] : Status Array ( [ip] => 192.168.0.50 [model] => vacuum [get_status] => Array ( [msg_ver] => 8 [clean_area] => 0 [battery] => 100 [error_code] => Tout va bien [dnd_enabled] => 0 [fan_power] => 100 [state] => En charge [map_present] => 1 [in_cleaning] => 0 [clean_time] => 0:00:00s [msg_seq] => 392 ) [get_consumable] => Array ( [sensor_dirty_time] => 0 [main_brush_work_time] => 569083 [side_brush_work_time] => 569083 [filter_work_time] => 569083 ) )
J’avoue que je n’ai pas fouillé plus que ça, les consommables sont peut-être différent par modèle ce qui complexifierait beaucoup pour pas grand chose.
Question subsidiaire: l’api permet de faire ce reset? Si oui ce serait encore mieux (sinon par script et variable de valeur au dernier changement il y a moyen de s’en sortir sans).
Merci d’avance pour la réponse (que ce soit oui ou non, je ne me rend pas compte de la complexité derrière
