Connexion Arduino R3 sur PC Jeedom pb librairies et pyserial
Impossible de faire fonctionner ma carte arduino Uno R3 sur une jeedom installée sur PC.
J’ai bien le démon ok, j’enregistre le sketch après avoir sauver/généré les commande
Le problème vient probablement des librairies arduino et autres pbs lors de la compilation que je mentionne ci-dessous.
Un coup de main car j’ai fait le tour de mes possibles ?!
In file included from C:\Users\Bibis\Downloads\JeedouinoUSB_16\JeedouinoUSB_16.ino:43:0:
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:36:1: error: expected unqualified-id before 'struct'
 struct EERef{
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:36:1: error: expected ')' before 'struct'
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:97:5: error: 'EERef' does not name a type; did you mean 'EERE'?
     EERef operator*()                   { return index; }
     EERE
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:119:5: error: 'EERef' does not name a type; did you mean 'EERE'?
     EERef operator[]( const int idx )    { return idx; }
     EERE
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h: In member function 'uint8_t EEPROMClass::read(int)':
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:120:51: error: 'EERef' was not declared in this scope
     uint8_t read( int idx )              { return EERef( idx ); }
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:120:51: note: suggested alternative: 'EERE'
                                                   EERE
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h: In member function 'void EEPROMClass::write(int, uint8_t)':
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:121:45: error: 'EERef' was not declared in this scope
     void write( int idx, uint8_t val )   { (EERef( idx )) = val; }
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:121:45: note: suggested alternative: 'EERE'
                                             EERE
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h: In member function 'void EEPROMClass::update(int, uint8_t)':
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:122:44: error: 'EERef' was not declared in this scope
     void update( int idx, uint8_t val )  { EERef( idx ).update( val ); }
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:122:44: note: suggested alternative: 'EERE'
                                            EERE
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h: In member function 'T& EEPROMClass::get(int, T&)':
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:133:71: error: no match for 'operator*' (operand type is 'EEPtr')
         for( int count = sizeof(T) ; count ; --count, ++e )  *ptr++ = *e;
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h: In member function 'const T& EEPROMClass::put(int, const T&)':
C:\Program Files (x86)\Arduinocc\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:140:63: error: no match for 'operator*' (operand type is 'EEPtr')
         for( int count = sizeof(T) ; count ; --count, ++e )  (*e).update( *ptr++ );
Plusieurs bibliothèque trouvées pour "DHT.h"
Utilisé : D:\OneDrive\Documents\Arduino\libraries\DHT
Non utilisé : D:\OneDrive\Documents\Arduino\libraries\DHT_sensor_library
Non utilisé : C:\Program Files (x86)\Arduinocc\libraries\DHT
Plusieurs bibliothèque trouvées pour "OneWire.h"
Utilisé : D:\OneDrive\Documents\Arduino\libraries\OneWire
Non utilisé : C:\Program Files (x86)\Arduinocc\libraries\OneWire
exit status 1
Erreur de compilation pour la carte Arduino Uno
Apparemment, ça serait un problème de la bibliothèque EEprom. Est-elle à jour ?
J’imagine que tu as généré le sketch avec Jeeduino ? Si c’est le cas, mais le tag dans ton post.
Ah, flute, qu’est ce que c’est un tag ?
MAJ faites, compilation terminée sans problème = est-ce à dire que le pb ne vient pas des bibliothèques ?
Voici le log jeeduino pig pio :
======= Start of apt -y --fix-broken install =======
Reading package lists…
Building dependency tree…
Reading state information…
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
======= Start of dpkg --configure -a --force-confdef =======
======= Start of apt autoremove =======
======= Start of Serial installation =======
python-pip is already the newest version (18.1-5).
python3-pip is already the newest version (18.1-5).
E: Invalid operation python-serial
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (21.3.1)
WARNING: Running pip as the ‹ root › user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: 12. Virtual Environments and Packages — Python 3.11.5 documentation
WARNING: Skipping serial as it is not installed.
Requirement already satisfied: pyserial in /usr/local/lib/python3.7/dist-packages (3.5)
======= End of Serial installation =======
Je vois également dans les logs :
2021-11-14 15:45:05 jeedouino Dépendances Serial introuvables. Imposssible de démarrer le démon.
2021-11-14 15:45:05 jeedouino Dépendances Serial introuvables. Veuillez les réinstaller.
Et du coup, j’installe l’affaire dans le plugin (mais j’utilise un PC, cependant) :
image|590x336
Je vérifie sous putty en python : :~# pip install pyserial
Pour autant, cela ne fonctionne toujours pas (!)…
