Configuration réseau interne NOK
Je suis débutant sur RPI4 et Jeedom 4.1.25
Je bloque sur ce message.
Pas de solutions sur les forums:
Mes plugins ZIgbee et ESP ne fonctionnent pas
Que dit ta config pour reseau externe ? Déjà as tu un accès externe.
Non je n’ai pas d 'accés externe
Même message pour l’externe : NOK
Mais pas sûr que ce soit ça qui bloque les plugin. Regarde plutôt les log en mode debug
J’ai trouvé ce Log
Mais pour moi perso, c’est compliqué de l’interpréter!!
 sudo apt-get update && sudo apt-get install yarn
Reading package lists...
Building dependency tree...
Reading state information...
  nodejs
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
0 upgraded, 1 newly installed, 0 to remove and 92 not upgraded.
Need to get 0 B/22.8 MB of archives.
After this operation, 114 MB of additional disk space will be used.
Selecting previously unselected package nodejs.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 67672 files and directories currently installed.)
Preparing to unpack .../nodejs_14.17.6-deb-1nodesource1_armhf.deb ...
Unpacking nodejs (14.17.6-deb-1nodesource1) ...
Setting up nodejs (14.17.6-deb-1nodesource1) ...
Processing triggers for man-db (2.8.5-2) ...
Version actuelle : v14.17.6
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
added 48 packages from 58 contributors and audited 48 packages in 6.68s
2 packages are looking for funding
  run `npm fund` for details
found 0 vulnerabilities
Bonsoir
Essai cette commande en ssh sur ton compte utilisateur (pas en root)
sudo ln -s `which node` `which node`js
Puis relance les dépendances
Bonne soirée
Je pense qu’on va oublier tout ce qui a été dit précédemment et repartir sur la base: décrivez le problème.
Parce que:
  • le titre du sujet c’est « connection interne NOK »
  • Vous parlez d’un message d’erreur qu’on ne voit pas, aucune capture, rien.
  • L’un pose une question sur l’accès externe?!?
  • puis vous donnez un log d’install mais on ne sait même pas de quoi…
Bref j’ai rarement vu un sujet aller dans tous les sens comme ça.
Donc je répète:
  • décrivez le problème,
  • montrez le log ou la capture d’écran illustrant le problème.
  • donnez une capture d’écran de la page santé jeedom
Plus d’info: Comment nous aider à vous aider - ou Comment poser une bonne question?
3 « J'aime »
