Ton réseau Macvlan est toujours présent sur ton syno ?
ifconfig
ifconfig
Voilà
root@mon-serveur:~# ifconfig
docker0 Link encap:Ethernet HWaddr 02:42:CC:37:21:73
inet addr:172.17.0.1 Bcast:172.17.255.255 Mask:255.255.0.0
inet6 addr: fe80::42:ccff:fe37:2173/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2123 errors:0 dropped:0 overruns:0 frame:0
TX packets:4725 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:87229 (85.1 KiB) TX bytes:666513 (650.8 KiB)
docker46c Link encap:Ethernet HWaddr D6:01:AF:11:65:C5
inet6 addr: fe80::d401:afff:fe11:65c5/64 Scope:Link
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:1929 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:493050 (481.4 KiB)
dockerf5a Link encap:Ethernet HWaddr CE:D3:F6:DA:94:F9
inet6 addr: fe80::ccd3:f6ff:feda:94f9/64 Scope:Link
TX packets:4731 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:116951 (114.2 KiB) TX bytes:666981 (651.3 KiB)
eth0 Link encap:Ethernet HWaddr 00:24:81:7D:85:6F
inet6 addr: fe80::224:81ff:fe7d:856f/64 Scope:Link
RX packets:929545 errors:0 dropped:0 overruns:0 frame:0
TX packets:293986 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:791526777 (754.8 MiB) TX bytes:47652744 (45.4 MiB)
Interrupt:18 memory 0xfe9e0000-fea00000
eth1 Link encap:Ethernet HWaddr 00:24:81:7D:85:6F
RX packets:1611289 errors:0 dropped:0 overruns:0 frame:0
TX packets:1017629 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:661133099 (630.5 MiB) TX bytes:219340986 (209.1 MiB)
Interrupt:19 memory 0xfe980000-fe9a0000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:104579 errors:0 dropped:0 overruns:0 frame:0
TX packets:104579 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:28884062 (27.5 MiB) TX bytes:28884062 (27.5 MiB)
macvlan-b Link encap:Ethernet HWaddr 00:01:02:03:04:05
inet addr:192.168.1.241 Bcast:0.0.0.0 Mask:255.255.255.255
inet6 addr: fe80::201:2ff:fe03:405/64 Scope:Link
inet6 addr: 2a01:e34:ee62:17c0:201:2ff:fe03:405/64 Scope:Global
RX packets:356790 errors:0 dropped:0 overruns:0 frame:0
TX packets:19600 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:61027736 (58.2 MiB) TX bytes:3092763 (2.9 MiB)
ovs_bond0 Link encap:Ethernet HWaddr 00:24:81:7D:85:6F
inet addr:192.168.1.194 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: 2a01:e34:ee62:17c0:224:81ff:fe7d:856f/64 Scope:Global
RX packets:2120542 errors:0 dropped:0 overruns:0 frame:0
TX packets:1282124 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1403798046 (1.3 GiB) TX bytes:259430271 (247.4 MiB)
Tu as bien cliqué sur lancer le demon de l’antenne ?
Je viens de le faire ; voilà les log :
[2020-10-21 21:41:09][INFO] : Lancement du démon distant
[2020-10-21 21:41:09][INFO] : Arret du démon distant
[2020-10-21 21:41:09][INFO] : Commande par SSH fuser -k 55008/tcp >> /dev/null 2>&1 & sur 192.168.1.241
[2020-10-21 21:41:14][INFO] : Lancement du démon distant /usr/bin/python3 /home/blea/blead/resources/blead/blead.py --loglevel debug --device hci0 --socketport 55008 --sockethost "" --callback http://192.168.1.243/plugins/blea/core/php/jeeBlea.php --apikey GU7JZWxYa8fA1MQtSd2tITb3HTGDjg2J --daemonname "Clé Bluetooth" --noseeninterval 4 --scaninterval 29 --scanmode passive >> /tmp/blea 2>&1 &
[2020-10-21 21:41:14][INFO] : Commande par SSH /usr/bin/python3 /home/blea/blead/resources/blead/blead.py --loglevel debug --device hci0 --socketport 55008 --sockethost "" --callback http://192.168.1.243/plugins/blea/core/php/jeeBlea.php --apikey GU7JZWxYa8fA1MQtSd2tITb3HTGDjg2J --daemonname "Clé Bluetooth" --noseeninterval 4 --scaninterval 29 --scanmode passive >> /tmp/blea 2>&1 & sur 192.168.1.241
[2020-10-21 21:41:31][INFO] : Suppression de la log /var/www/html/plugins/blea/core/class/../../../../log/blea_Clé-Bluetooth
[2020-10-21 21:41:31][INFO] : Récupération de la log distante
[2020-10-21 21:41:31][INFO] : Récupération de fichier depuis 192.168.1.241
[2020-10-21 21:41:32][INFO] : Commande par SSH cat /dev/null > /tmp/blea sur 192.168.1.241
[2020-10-21 21:45:03][INFO] : Suppression de la log /var/www/html/plugins/blea/core/class/../../../../log/blea_Clé-Bluetooth
[2020-10-21 21:45:03][INFO] : Récupération de la log distante
[2020-10-21 21:45:03][INFO] : Récupération de fichier depuis 192.168.1.241
[2020-10-21 21:45:03][INFO] : Commande par SSH cat /dev/null > /tmp/blea sur 192.168.1.241
Je sèche désolé
Tout est ok dans ce que j’ai affiché?
Dans « configuration - > port de la clé Bluetooth », je devrais trouver ma clé, c’est bien ça?
Non car comme j’ai dit plus haut si tu installes ta clé en mode antenne (autre container) cela ne sera pas visible dans la config du plug-in qui ne concerne que les clés branchées en local sur jeedom
Comment je sais que mon antenne est ok alors (dans cette configuration) ?
Juste en lançant un scan?
Dans l’écran des antennes, elle passera au vert si elle répond.
exemple:
Je viens de remarquer que quand je lance le demon de l’antenne, j’ai cette log :
2020-10-22 12:28:50.736][INFO] : GLOBAL------Start blead
[2020-10-22 12:28:50.736][INFO] : GLOBAL------Log level : debug
[2020-10-22 12:28:50.736][INFO] : GLOBAL------Socket port : 55008
[2020-10-22 12:28:50.736][INFO] : GLOBAL------Socket host :
[2020-10-22 12:28:50.736][INFO] : GLOBAL------Device : hci0
[2020-10-22 12:28:50.736][INFO] : GLOBAL------PID file : /tmp/blead.pid
[2020-10-22 12:28:50.736][INFO] : GLOBAL------Apikey : GU7JZWxYa8fA1MQtSd2tITb3HTGDjg2J
[2020-10-22 12:28:50.736][INFO] : GLOBAL------Callback : http://192.168.1.243/plugins/blea/core/php/jeeBlea.php
[2020-10-22 12:28:50.737][INFO] : GLOBAL------Cycle : 0.3
[2020-10-22 12:28:50.737][INFO] : GLOBAL------Scan interval : 29
[2020-10-22 12:28:50.737][INFO] : GLOBAL------Number for no seen : 4
[2020-10-22 12:28:50.737][INFO] : GLOBAL------Scan Mode : passive
[2020-10-22 12:28:50.779][INFO] : LOADER------Import de la configuration devices.amazfitgtr
[2020-10-22 12:28:50.780][INFO] : LOADER------Import de la configuration devices.awoxmesh
[2020-10-22 12:28:50.886][INFO] : LOADER------Import de la configuration devices.beagle
[2020-10-22 12:28:50.887][INFO] : LOADER------Import de la configuration devices.beewismartdoor
[2020-10-22 12:28:50.888][INFO] : LOADER------Import de la configuration devices.blpnr
[2020-10-22 12:28:50.904][INFO] : LOADER------Import de la configuration devices.divoompixoo
[2020-10-22 12:28:52.252][INFO] : LOADER------Import de la configuration devices.divoomtimeboxmini
[2020-10-22 12:28:52.329][INFO] : LOADER------Import de la configuration devices.dotti
[2020-10-22 12:28:52.341][INFO] : LOADER------Import de la configuration devices.dreamscreen
[2020-10-22 12:28:52.342][INFO] : LOADER------Import de la configuration devices.fitbit
[2020-10-22 12:28:52.342][INFO] : LOADER------Import de la configuration devices.gigaset
[2020-10-22 12:28:52.343][INFO] : LOADER------Import de la configuration devices.hector
[2020-10-22 12:28:52.343][INFO] : LOADER------Import de la configuration devices.itag
[2020-10-22 12:28:52.360][INFO] : LOADER------Import de la configuration devices.jinlin
[2020-10-22 12:28:52.360][INFO] : LOADER------Import de la configuration devices.kst1
[2020-10-22 12:28:52.361][INFO] : LOADER------Import de la configuration devices.logiswitch
[2020-10-22 12:28:52.361][INFO] : LOADER------Import de la configuration devices.lywsd02
[2020-10-22 12:28:52.362][INFO] : LOADER------Import de la configuration devices.meyerdom2analog
[2020-10-22 12:28:52.362][INFO] : LOADER------Import de la configuration devices.meyerdom4contacts
[2020-10-22 12:28:52.363][INFO] : LOADER------Import de la configuration devices.meyerdomcontactvocal
[2020-10-22 12:28:52.364][INFO] : LOADER------Import de la configuration devices.miband
[2020-10-22 12:28:52.364][INFO] : LOADER------Import de la configuration devices.miband2
[2020-10-22 12:28:52.384][INFO] : LOADER------Import de la configuration devices.miband3
[2020-10-22 12:28:52.385][INFO] : LOADER------Import de la configuration devices.miband4
[2020-10-22 12:28:52.386][INFO] : LOADER------Import de la configuration devices.miflora
[2020-10-22 12:28:52.400][INFO] : LOADER------Import de la configuration devices.miscale
[2020-10-22 12:28:52.445][INFO] : LOADER------Import de la configuration devices.miscale2
[2020-10-22 12:28:52.451][INFO] : LOADER------Import de la configuration devices.myfox
[2020-10-22 12:28:52.451][INFO] : LOADER------Import de la configuration devices.niu
[2020-10-22 12:28:52.452][INFO] : LOADER------Import de la configuration devices.noke
[2020-10-22 12:28:52.453][INFO] : LOADER------Import de la configuration devices.nut
[2020-10-22 12:28:52.453][INFO] : LOADER------Import de la configuration devices.parrotplant
[2020-10-22 12:28:52.454][INFO] : LOADER------Import de la configuration devices.pixoo
[2020-10-22 12:28:52.455][INFO] : LOADER------Import de la configuration devices.pixoo.divoom_image
[2020-10-22 12:28:52.455][INFO] : LOADER------Import de la configuration devices.pixoo.messages
[2020-10-22 12:28:52.455][INFO] : LOADER------Import de la configuration devices.pixoo.timebox
[2020-10-22 12:28:52.455][INFO] : LOADER------Import de la configuration devices.pixoo.timeboximage
[2020-10-22 12:28:52.455][INFO] : LOADER------Import de la configuration devices.playbulb
[2020-10-22 12:28:52.456][INFO] : LOADER------Import de la configuration devices.ropot
[2020-10-22 12:28:52.457][INFO] : LOADER------Import de la configuration devices.ruuvi
[2020-10-22 12:28:52.457][INFO] : LOADER------Import de la configuration devices.smartplug
[2020-10-22 12:28:52.491][INFO] : LOADER------Import de la configuration devices.tb05
[2020-10-22 12:28:52.491][INFO] : LOADER------Import de la configuration devices.ticatag
[2020-10-22 12:28:52.492][INFO] : LOADER------Import de la configuration devices.tile
[2020-10-22 12:28:52.493][INFO] : LOADER------Import de la configuration devices.timebox
[2020-10-22 12:28:52.494][INFO] : LOADER------Import de la configuration devices.timebox.divoom_image
[2020-10-22 12:28:52.504][INFO] : LOADER------Import de la configuration devices.timebox.messages
[2020-10-22 12:28:52.504][INFO] : LOADER------Import de la configuration devices.timebox.timebox
[2020-10-22 12:28:52.504][INFO] : LOADER------Import de la configuration devices.timebox.timeboximage
[2020-10-22 12:28:52.504][INFO] : LOADER------Import de la configuration devices.wistiki
[2020-10-22 12:28:52.505][INFO] : LOADER------Import de la configuration devices.xiaomiht
[2020-10-22 12:28:52.505][INFO] : LOADER------Import de la configuration devices.yeelight
[2020-10-22 12:28:52.506][INFO] : LOADER------Import de la configuration devices.yeelightcandela
[2020-10-22 12:28:52.726][DEBUG] : Writing PID 2925 to /tmp/blead.pid
[2020-10-22 12:28:52.728][DEBUG] : Init request module v2.12.4
[2020-10-22 12:28:52.771][DEBUG] : Starting new HTTP connection (1): 192.168.1.243
[2020-10-22 12:28:52.787][DEBUG] : http://192.168.1.243:80 "GET /plugins/blea/core/php/jeeBlea.php?apikey=GU7JZWxYa8fA1MQtSd2tITb3HTGDjg2J HTTP/1.1" 200 0
[2020-10-22 12:28:52.788][DEBUG] : Socket interface started
[2020-10-22 12:28:52.789][DEBUG] : LoopNetServer Thread started
[2020-10-22 12:28:52.789][INFO] : GLOBAL------Start listening...
[2020-10-22 12:28:52.789][INFO] : GLOBAL------Preparing Scanner...
[2020-10-22 12:28:52.789][DEBUG] : Listening on: [:55008]
[2020-10-22 12:28:52.789][DEBUG] : GLOBAL------Read Socket Thread Launched
[2020-10-22 12:28:52.789][DEBUG] : Send to jeedom : {'source': 'Cl\udcc3\udca9 Bluetooth', 'learn_mode': 0}
[2020-10-22 12:28:52.791][DEBUG] : Starting new HTTP connection (1): 192.168.1.243
[2020-10-22 12:28:52.792][DEBUG] : GLOBAL------Read Device Thread Launched
[2020-10-22 12:28:52.793][DEBUG] : GLOBAL------Heartbeat Thread Launched
[2020-10-22 12:28:52.793][DEBUG] : Send to jeedom : {'source': 'Cl\udcc3\udca9 Bluetooth', 'started': 1, 'version': '2.9'}
[2020-10-22 12:28:52.796][DEBUG] : Starting new HTTP connection (1): 192.168.1.243
[2020-10-22 12:28:52.802][DEBUG] : http://192.168.1.243:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=GU7JZWxYa8fA1MQtSd2tITb3HTGDjg2J HTTP/1.1" 200 0
[2020-10-22 12:28:52.804][DEBUG] : http://192.168.1.243:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=GU7JZWxYa8fA1MQtSd2tITb3HTGDjg2J HTTP/1.1" 200 0
Est-ce que ça apporte des infos intéressantes?
Ca semble fonctionner tout ca, on voit que ton antenne notifie avec succès son démarrage au plugin sur les 4 dernières lignes et aucune autre erreur
donc ton antenne doit être au vert là?
C’est resté au rouge.
MAIS après avoir parcouru d’autre forum, je viens de trouver « sudo hciconfig hci0 up » pour activer ma clé (c’est tout c** !!) et ça marche!
Et depuis 5 minutes, mon antenne reste bien au vert (active) et j’ai pu faire un scan.
Je pense pouvoir dire que c’est résolu!!!
Il faut encore que j’essaye de redémarrer mon Syno, pour voir si c’est toujours bon.
En tout cas, merci à vous trois de m’avoir aidé et d’avoir répondu à mes questions.
