J’ai installé le plugin Zigbee Beta mais impossible de lancer le Daemon car l’installation des Dépendances n’aboutit pas.
La configuration:
- Linux odroidc2 5.9.6-meson64 #20.08.22 SMP PREEMPT Sun Nov 8 12:50:14 CET 2020 aarch64 GNU/Linux [10.6]
- Jeedom 4.1.15 sur la Smart en Debian Buster, installé en utilisant le tuto de Akenad ([RTEX] Odroid-C2 - eMMC - Armbian Buster Kernel 5.3 - Jeedom V4)
- Clé ZIGATE
Voici la configuration du plugin.
et voci le log:
Launch install of zigbee dependancy
Hit:1 http://security.debian.org buster/updates InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 http://deb.debian.org/debian buster-backports InRelease
Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
Hit:6 https://minio.k-space.ee/armbian/apt buster InRelease
Reading package lists...
Skipping serial as it is not installed.
Building dependency tree...
Reading state information...
Package 'python3-serial' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
python3-pip is already the newest version (18.1-5).
python3-setuptools is already the newest version (40.8.0-1).
python3 is already the newest version (3.7.3-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.21.0-1).
Requirement already up-to-date: pyserial in /usr/local/lib/python3.7/dist-packages (3.4)
Collecting zigpy
Using cached https://files.pythonhosted.org/packages/4d/92/19912a0e2cd973a5626538cf1cfecb4e6cc83c7d9efaabc7830c825b4a2b/zigpy-0.27.0-py3-none-any.whl
Requirement already satisfied, skipping upgrade: aiosqlite in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.16.0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.12.0)
Collecting aiohttp (from zigpy)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy) (1.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy) (3.9.9)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite->zigpy) (3.7.4.3)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (3.0.1)
Collecting multidict<7.0,>=4.5 (from aiohttp->zigpy)
Using cached https://files.pythonhosted.org/packages/da/e6/50c7f52781f45c2b37c77e962c30a3944a9e79a46ea92956e826c24d3432/multidict-5.0.2.tar.gz
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Collecting yarl<2.0,>=1.0 (from aiohttp->zigpy)
Using cached https://files.pythonhosted.org/packages/97/e7/af7219a0fe240e8ef6bb555341a63c43045c21ab0392b4435e754b716fa1/yarl-1.6.3.tar.gz
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (20.3.0)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy) (3.0.4)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy) (2.6)
Building wheels for collected packages: multidict, yarl
Running setup.py bdist_wheel for multidict: started
Running setup.py bdist_wheel for multidict: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-dtrbhrrn/multidict/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-filuy8qt --python-tag cp37:
* Accellerated build *
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.7
creating build/lib.linux-aarch64-3.7/multidict
copying multidict/_multidict_py.py -> build/lib.linux-aarch64-3.7/multidict
copying multidict/_multidict_base.py -> build/lib.linux-aarch64-3.7/multidict
copying multidict/_compat.py -> build/lib.linux-aarch64-3.7/multidict
copying multidict/_abc.py -> build/lib.linux-aarch64-3.7/multidict
copying multidict/__init__.py -> build/lib.linux-aarch64-3.7/multidict
running egg_info
writing multidict.egg-info/PKG-INFO
writing dependency_links to multidict.egg-info/dependency_links.txt
writing top-level names to multidict.egg-info/top_level.txt
reading manifest file 'multidict.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files found matching 'multidict/_multidict.html'
warning: no previously-included files found matching 'multidict/*.so'
warning: no previously-included files found matching 'multidict/*.pyd'
no previously-included directories found matching 'docs/_build'
writing manifest file 'multidict.egg-info/SOURCES.txt'
copying multidict/__init__.pyi -> build/lib.linux-aarch64-3.7/multidict
copying multidict/_multidict.c -> build/lib.linux-aarch64-3.7/multidict
copying multidict/py.typed -> build/lib.linux-aarch64-3.7/multidict
creating build/lib.linux-aarch64-3.7/multidict/_multilib
copying multidict/_multilib/defs.h -> build/lib.linux-aarch64-3.7/multidict/_multilib
copying multidict/_multilib/dict.h -> build/lib.linux-aarch64-3.7/multidict/_multilib
copying multidict/_multilib/istr.h -> build/lib.linux-aarch64-3.7/multidict/_multilib
copying multidict/_multilib/iter.h -> build/lib.linux-aarch64-3.7/multidict/_multilib
copying multidict/_multilib/pair_list.h -> build/lib.linux-aarch64-3.7/multidict/_multilib
copying multidict/_multilib/views.h -> build/lib.linux-aarch64-3.7/multidict/_multilib
running build_ext
building 'multidict._multidict' extension
creating build/temp.linux-aarch64-3.7
creating build/temp.linux-aarch64-3.7/multidict
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.7m -c multidict/_multidict.c -o build/temp.linux-aarch64-3.7/multidict/_multidict.o -O2 -std=c99 -Wall -Wsign-compare -Wconversion -fno-strict-aliasing -pedantic
multidict/_multidict.c:1:10: fatal error: Python.h: No such file or directory
#include "Python.h"
compilation terminated.
error: command 'aarch64-linux-gnu-gcc' failed with exit status 1
Failed building wheel for multidict
Running setup.py clean for multidict
Running setup.py bdist_wheel for yarl: started
Running setup.py bdist_wheel for yarl: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-dtrbhrrn/yarl/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-hnqhn8xm --python-tag cp37:
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.7/yarl
copying yarl/_url.py -> build/lib.linux-aarch64-3.7/yarl
copying yarl/_quoting_py.py -> build/lib.linux-aarch64-3.7/yarl
copying yarl/_quoting.py -> build/lib.linux-aarch64-3.7/yarl
copying yarl/__init__.py -> build/lib.linux-aarch64-3.7/yarl
running egg_info
writing yarl.egg-info/PKG-INFO
writing dependency_links to yarl.egg-info/dependency_links.txt
writing requirements to yarl.egg-info/requires.txt
writing top-level names to yarl.egg-info/top_level.txt
reading manifest file 'yarl.egg-info/SOURCES.txt'
warning: no previously-included files matching '*.cache' found anywhere in distribution
warning: no previously-included files found matching 'yarl/*.html'
warning: no previously-included files found matching 'yarl/*.so'
warning: no previously-included files found matching 'yarl/*.pyd'
writing manifest file 'yarl.egg-info/SOURCES.txt'
copying yarl/__init__.pyi -> build/lib.linux-aarch64-3.7/yarl
copying yarl/_quoting_c.c -> build/lib.linux-aarch64-3.7/yarl
copying yarl/_quoting_c.pyi -> build/lib.linux-aarch64-3.7/yarl
copying yarl/_quoting_c.pyx -> build/lib.linux-aarch64-3.7/yarl
copying yarl/py.typed -> build/lib.linux-aarch64-3.7/yarl
running build_ext
building 'yarl._quoting_c' extension
creating build/temp.linux-aarch64-3.7/yarl
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.7m -c yarl/_quoting_c.c -o build/temp.linux-aarch64-3.7/yarl/_quoting_c.o
yarl/_quoting_c.c:4:10: fatal error: Python.h: No such file or directory
#include "Python.h"
Failed building wheel for yarl
Running setup.py clean for yarl
Failed to build multidict yarl
Installing collected packages: multidict, yarl, aiohttp, zigpy
Running setup.py install for multidict: started
Running setup.py install for multidict: finished with status 'error'
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-cvyxhzkk/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
running egg_info
running build_ext
#include "Python.h"
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-dtrbhrrn/multidict/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-cvyxhzkk/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-dtrbhrrn/multidict/
Je ne trouve pas de solution, merci pour votre aide.
