suite à des soucis rencontrés avec mon jeedom sur rpi, j’ai décidé de passer sur un pc avec proxmox et une debian, qui heberge mon jeedom.
J’ai donc fait une sauvegarde, installé mon jeedom, et chargé ma sauvegarde.
Seulement ma clé ConbeeII n’est pas vue sous jeedom.
dans ma debian 10 :
root@Jeedom:~# GCFFlasher_internal -l
GCFFlasher V3_17 (c) dresden elektronik ingenieurtechnik gmbh
Path | Vendor | Product | Serial | Type
/dev/ttyACM1 | 0x1CF1 | 0x0030 | DE2140512 | ConBee II
l’installation de deconz local :
* Installation deconz *
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:2 http://ftp.u-strasbg.fr/debian buster InRelease
Hit:3 http://ftp.u-strasbg.fr/debian buster-updates InRelease
Reading package lists...
Building dependency tree...
Reading state information...
libqt5serialport5 libqt5websockets5
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 97.9 kB of archives.
After this operation, 359 kB of additional disk space will be used.
Get:1 http://ftp.u-strasbg.fr/debian buster/main amd64 libqt5serialport5 amd64 5.11.3-2 [35.0 kB]
Get:2 http://ftp.u-strasbg.fr/debian buster/main amd64 libqt5websockets5 amd64 5.11.3-5 [62.8 kB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 97.9 kB in 0s (786 kB/s)
Selecting previously unselected package libqt5serialport5:amd64.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 58986 files and directories currently installed.)
Preparing to unpack .../libqt5serialport5_5.11.3-2_amd64.deb ...
Unpacking libqt5serialport5:amd64 (5.11.3-2) ...
Selecting previously unselected package libqt5websockets5:amd64.
Preparing to unpack .../libqt5websockets5_5.11.3-5_amd64.deb ...
Unpacking libqt5websockets5:amd64 (5.11.3-5) ...
Setting up libqt5serialport5:amd64 (5.11.3-2) ...
Setting up libqt5websockets5:amd64 (5.11.3-5) ...
Processing triggers for libc-bin (2.28-10) ...
Suggested packages:
sqlite3-doc
sqlite3
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 940 kB of archives.
After this operation, 2695 kB of additional disk space will be used.
Get:1 http://ftp.u-strasbg.fr/debian buster/main amd64 sqlite3 amd64 3.27.2-3+deb10u1 [940 kB]
Fetched 940 kB in 0s (5065 kB/s)
Selecting previously unselected package sqlite3.
(Reading database ... 58998 files and directories currently installed.)
Preparing to unpack .../sqlite3_3.27.2-3+deb10u1_amd64.deb ...
Unpacking sqlite3 (3.27.2-3+deb10u1) ...
Setting up sqlite3 (3.27.2-3+deb10u1) ...
Processing triggers for man-db (2.8.5-2) ...
It's x86_64 arch
--2022-01-31 23:02:58-- http://phoscon.de/apt/deconz.pub.key
Resolving phoscon.de (phoscon.de)... 144.76.96.194
Connecting to phoscon.de (phoscon.de)|144.76.96.194|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1692 (1.7K) [application/octet-stream]
Saving to: 'STDOUT'
0K . 100% 248M=0s
2022-01-31 23:02:58 (248 MB/s) - written to stdout [1692/1692]
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
Get:4 http://phoscon.de/apt/deconz buster InRelease [2869 B]
Get:5 http://phoscon.de/apt/deconz buster/main amd64 Packages [732 B]
Fetched 3601 B in 0s (8260 B/s)
The following additional packages will be installed:
libqt5sql5 libqt5sql5-sqlite
deconz libqt5sql5 libqt5sql5-sqlite
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 7114 kB of archives.
After this operation, 41.6 MB of additional disk space will be used.
Get:1 http://ftp.u-strasbg.fr/debian buster/main amd64 libqt5sql5 amd64 5.11.3+dfsg1-1+deb10u4 [145 kB]
Get:2 http://phoscon.de/apt/deconz buster/main amd64 deconz amd64 2.13.04-debian-buster-stable [6897 kB]
Get:3 http://ftp.u-strasbg.fr/debian buster/main amd64 libqt5sql5-sqlite amd64 5.11.3+dfsg1-1+deb10u4 [71.9 kB]
Fetched 7114 kB in 0s (20.6 MB/s)
Selecting previously unselected package libqt5sql5:amd64.
(Reading database ... 59006 files and directories currently installed.)
Preparing to unpack .../libqt5sql5_5.11.3+dfsg1-1+deb10u4_amd64.deb ...
Unpacking libqt5sql5:amd64 (5.11.3+dfsg1-1+deb10u4) ...
Selecting previously unselected package libqt5sql5-sqlite:amd64.
Preparing to unpack .../libqt5sql5-sqlite_5.11.3+dfsg1-1+deb10u4_amd64.deb ...
Unpacking libqt5sql5-sqlite:amd64 (5.11.3+dfsg1-1+deb10u4) ...
Selecting previously unselected package deconz.
Preparing to unpack .../deconz_2.13.04-debian-buster-stable_amd64.deb ...
tput: unknown terminal "unknown"
Unpacking deconz (2.13.04-debian-buster-stable) ...
Setting up libqt5sql5:amd64 (5.11.3+dfsg1-1+deb10u4) ...
Setting up deconz (2.13.04-debian-buster-stable) ...
Setting up libqt5sql5-sqlite:amd64 (5.11.3+dfsg1-1+deb10u4) ...
Processing triggers for mime-support (3.62) ...
* Installation terminée *
et les dependances :
* Installation des dépendances *
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Hit:3 http://phoscon.de/apt/deconz buster InRelease
Hit:4 http://ftp.u-strasbg.fr/debian buster-updates InRelease
python3-pip is already the newest version (18.1-5).
python3-setuptools is already the newest version (40.8.0-1).
python3-setuptools set to manually installed.
Skipping websocket-client as it is not installed.
Skipping websocket as it is not installed.
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (40.8.0)
Requirement already satisfied: wheel in /usr/lib/python3/dist-packages (0.32.3)
Collecting serial
Downloading https://files.pythonhosted.org/packages/1f/51/6a260c498162c37d0759f3759b7647a10d8d30caba1cfc9aa4b5b1f0d08b/serial-0.0.97-py2.py3-none-any.whl (40kB)
Collecting iso8601>=0.1.12 (from serial)
Downloading https://files.pythonhosted.org/packages/df/e5/589bc81d410139ec4e4f37d9af5a50987566abf6d087b3c4fbed708109a9/iso8601-1.0.2-py3-none-any.whl
Collecting pyyaml>=3.13 (from serial)
Downloading https://files.pythonhosted.org/packages/eb/5f/6e6fe6904e1a9c67bc2ca5629a69e7a5a0b17f079da838bab98a1e548b25/PyYAML-6.0-cp37-cp37m-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_12_x86_64.manylinux2010_x86_64.whl (596kB)
Collecting future>=0.17.1 (from serial)
Using cached https://files.pythonhosted.org/packages/45/0b/38b06fd9b92dc2b68d58b75f900e97884c45bedd2ff83203d933cf5851c9/future-0.18.2.tar.gz
Building wheels for collected packages: future
Running setup.py bdist_wheel for future: started
Running setup.py bdist_wheel for future: finished with status 'done'
Stored in directory: /root/.cache/pip/wheels/8b/99/a0/81daf51dcd359a9377b110a8a886b3895921802d2fc1b2397e
Successfully built future
Installing collected packages: iso8601, pyyaml, future, serial
Successfully installed future-0.18.2 iso8601-1.0.2 pyyaml-6.0 serial-0.0.97
Collecting pyudev
Downloading https://files.pythonhosted.org/packages/12/d7/e9054fc2ead034144c7838aec5cb74a5d5f66e2aa88bd6bab78f2415e4b0/pyudev-0.23.1-py3-none-any.whl (63kB)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from pyudev) (1.12.0)
Installing collected packages: pyudev
Successfully installed pyudev-0.23.1
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.21.0)
Requirement already satisfied: serial in /usr/local/lib/python3.7/dist-packages (0.0.97)
Requirement already satisfied: iso8601>=0.1.12 in /usr/local/lib/python3.7/dist-packages (from serial) (1.0.2)
Requirement already satisfied: pyyaml>=3.13 in /usr/local/lib/python3.7/dist-packages (from serial) (6.0)
Requirement already satisfied: future>=0.17.1 in /usr/local/lib/python3.7/dist-packages (from serial) (0.18.2)
Requirement already satisfied: pyudev in /usr/local/lib/python3.7/dist-packages (0.23.1)
Collecting websocket-client
Downloading https://files.pythonhosted.org/packages/88/03/cd5aa2c97356b7eee484a2b63fe850076ecb82fdeda82979a234b62a9a37/websocket_client-1.2.3-py3-none-any.whl (53kB)
Installing collected packages: websocket-client
Successfully installed websocket-client-1.2.3
Le démon ne se lance pas. Lorsque je cherche la clé, je ne la trouve pas.
Voici les logs du deconz :
File "/var/www/html/plugins/deconz/resources/deconzd/deconzd.py", line 32, in <module>
from websocket import create_connection
ModuleNotFoundError: No module named 'websocket'
[2022-01-31 23:00:12][ERROR] : Impossible de lancer le démon deconz, vérifiez le port
Error: importing module from jeedom folder cannot import name 'collections_abc' from 'six.moves' (unknown location)
Autre info …
root@Jeedom:~# ps -aux | grep deconz; ps -aux | grep deCONZ
root 5583 0.0 0.0 6092 888 pts/0 R+ 23:25 0:00 grep deconz
root 5585 0.0 0.0 6092 892 pts/0 R+ 23:25 0:00 grep deCONZ
Merci pour tout indice !
