Bonjour, j’espère avoir choisi la bonne rubrique.
J’ai cette erreur dans les logs :
Date et heure Source Description Action Occurrences
2026-01-01 12:36:27 jeedom Erreur sur jeedom::cron() : Object of class DateTime could not be converted to string Log jeedom
2026-01-01 12:36:27 scenario Erreur sur scenario::check() : Object of class DateTime could not be converted to string Log scenario
2026-01-01 12:35:30 scenario Erreur sur scenario::check() : Object of class DateTime could not be converted to string Log scenario
2026-01-01 12:35:30 jeedom Erreur sur jeedom::cron() : Object of class DateTime could not be converted to string Log jeedom
2026-01-01 12:34:27 scenario Erreur sur scenario::check() : Object of class DateTime could not be converted to string Log scenario
2026-01-01 12:34:27 jeedom Erreur sur jeedom::cron() : Object of class DateTime could not be converted to string Log jeedom
2026-01-01 12:33:27 scenario Erreur sur scenario::check() : Object of class DateTime could not be converted to string Log scenario
2026-01-01 12:33:27 jeedom Erreur sur jeedom::cron() : Object of class DateTime could not be converted to string Log jeedom
2026-01-01 12:32:27 jeedom Erreur sur jeedom::cron() : Object of class DateTime could not be converted to string Log jeedom
2026-01-01 12:32:27 scenario Erreur sur scenario::check() : Object of class DateTime could not be converted to string Log scenario
2026-01-01 12:31:28 scenario Erreur sur scenario::check() : Object of class DateTime could not be converted to string Log scenario
Comment savoir d’où ça vient. Sans doute d’un scénario, mais lequel ?
