Merci pour le suivi rapide.
J’ai mis à jour la beta et lancé 3 fois la commande, hélas sans amélioration
[2026-02-18 16:33:11] DEBUG Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=airzone function=pre_update callInstallFunction=1
[2026-02-18 16:33:35] DEBUG Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=airzone function=post_plugin_install callInstallFunction=1
[2026-02-18 16:33:36] INFO Début d'activation du plugin
[2026-02-18 16:33:37] INFO Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2026-02-18 16:33:37] DEBUG Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=airzone function=update callInstallFunction=1
[2026-02-18 16:34:12] INFO Requete demandée : info 1 5
[2026-02-18 16:34:12] DEBUG REPONSE REQUETE : SUCCESS : {
"data": [{
"systemID": 1,
"zoneID": 5,
"name": "Parents",
"thermos_type": 4,
"thermos_firmware": "3.76",
"thermos_radio": 1,
"battery": 59,
"coverage": 56,
"on": 1,
"double_sp": 0,
"coolsetpoint": 19,
"coolmaxtemp": 25,
"coolmintemp": 15,
"heatsetpoint": 19,
"heatmaxtemp": 25,
"heatmintemp": 15,
"maxTemp": 25,
"minTemp": 15,
"setpoint": 19,
"roomTemp": 21.4,
"sleep": 0,
"temp_step": 0.5,
"mode": 3,
"speed": 0,
"coldStage": 1,
"heatStage": 1,
"coldStages": 1,
"heatStages": 1,
"humidity": 61,
"units": 0,
"errors": [],
"air_demand": 0,
"floor_demand": 0,
"cold_demand": 0,
"heat_demand": 0,
"aq_mode": 2,
"aq_quality": 0,
"aq_thrlow": 12,
"aq_thrhigh": 50,
"heatangle": 0,
"coldangle": 0,
"master_zoneID": 4,
"eco_adapt": "off",
"antifreeze": 0,
"window_external_source": 0
[2026-02-18 16:34:12] INFO ||┌──Rafraichissement des commandes pour Ch Parents
[2026-02-18 16:34:12] INFO ||┌──Données recues {"systemID":1,"zoneID":5,"name":"Parents","thermos_type":4,"thermos_firmware":"3.76","thermos_radio":1,"battery":59,"coverage":56,"on":1,"double_sp":0,"coolsetpoint":19,"coolmaxtemp":25,"coolmintemp":15,"heatsetpoint":19,"heatmaxtemp":25,"heatmintemp":15,"maxTemp":25,"minTemp":15,"setpoint":19,"roomTemp":21.4,"sleep":0,"temp_step":0.5,"mode":3,"speed":0,"coldStage":1,"heatStage":1,"coldStages":1,"heatStages":1,"humidity":61,"units":0,"errors":[],"air_demand":0,"floor_demand":0,"cold_demand":0,"heat_demand":0,"aq_mode":2,"aq_quality":0,"aq_thrlow":12,"aq_thrhigh":50,"heatangle":0,"coldangle":0,"master_zoneID":4,"eco_adapt":"off","antifreeze":0,"window_external_source":0}
[2026-02-18 16:34:12] INFO ||┌──UPDATE DATA INFO
[2026-02-18 16:34:12] DEBUG ||──SKYP KEY : systemID
[2026-02-18 16:34:12] DEBUG ||──SKYP KEY : zoneID
[2026-02-18 16:34:12] DEBUG ||──SKYP KEY : name
[2026-02-18 16:34:12] DEBUG ||──SKYP KEY : thermos_type
[2026-02-18 16:34:12] DEBUG ||──SKYP KEY : thermos_firmware
[2026-02-18 16:34:12] DEBUG ||──SKYP KEY : thermos_radio
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : battery
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : coverage
[2026-02-18 16:34:12] INFO |||──Données rafraichies - CMD : on VALEUR 1
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : double_sp
[2026-02-18 16:34:12] INFO |||──Données rafraichies - CMD : coolsetpoint VALEUR 19
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : coolmaxtemp
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : coolmintemp
[2026-02-18 16:34:12] INFO |||──Données rafraichies - CMD : heatsetpoint VALEUR 19
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : heatmaxtemp
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : heatmintemp
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : maxTemp
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : minTemp
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : setpoint
[2026-02-18 16:34:12] INFO |||──Données rafraichies - CMD : roomTemp VALEUR 21.4
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : sleep
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : temp_step
[2026-02-18 16:34:12] INFO |||──Données rafraichies - CMD : mode VALEUR 3
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : speed
[2026-02-18 16:34:12] INFO |||──Données rafraichies - CMD : coldStage VALEUR 1
[2026-02-18 16:34:12] INFO |||──Données rafraichies - CMD : heatStage VALEUR 1
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : coldStages
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : heatStages
[2026-02-18 16:34:12] INFO |||──Données rafraichies - CMD : humidity VALEUR 61
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : units
[2026-02-18 16:34:12] INFO |||──Données rafraichies - CMD : errors VALEUR
[2026-02-18 16:34:12] INFO |||──Données rafraichies - CMD : air_demand VALEUR 0
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : floor_demand
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : cold_demand
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : heat_demand
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : aq_mode
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : aq_quality
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : aq_thrlow
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : aq_thrhigh
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : heatangle
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : coldangle
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : master_zoneID
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : eco_adapt
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : antifreeze
[2026-02-18 16:34:12] DEBUG ||──CMD NON TROUVEE : window_external_source
[2026-02-18 16:34:12] INFO ||└──Fin Update Info
[2026-02-18 16:34:23] INFO Requete demandée : info 1 5
[2026-02-18 16:34:23] DEBUG REPONSE REQUETE : SUCCESS : {
"data": [{
"systemID": 1,
"zoneID": 5,
"name": "Parents",
"thermos_type": 4,
"thermos_radio": 1,
"battery": 59,
"coverage": 56,
"on": 1,
"double_sp": 0,
"coolsetpoint": 19,
"coolmaxtemp": 25,
"coolmintemp": 15,
"heatsetpoint": 19,
"heatmaxtemp": 25,
"heatmintemp": 15,
"maxTemp": 25,
"minTemp": 15,
"setpoint": 19,
"roomTemp": 21.4,
"sleep": 0,
"temp_step": 0.5,
"mode": 3,
"speed": 0,
"coldStage": 1,
"heatStage": 1,
"coldStages": 1,
"heatStages": 1,
"humidity": 61,
"units": 0,
"errors": [],
"air_demand": 0,
"floor_demand": 0,
"cold_demand": 0,
"heat_demand": 0,
"aq_mode": 2,
"aq_quality": 0,
"aq_thrlow": 12,
"aq_thrhigh": 50,
"heatangle": 0,
"coldangle": 0,
"master_zoneID": 4,
"eco_adapt": "off",
"antifreeze": 0,
[2026-02-18 16:34:23] INFO ||┌──Rafraichissement des commandes pour Ch Parents
[2026-02-18 16:34:23] INFO ||┌──Données recues {"systemID":1,"zoneID":5,"name":"Parents","thermos_type":4,"thermos_firmware":"3.76","thermos_radio":1,"battery":59,"coverage":56,"on":1,"double_sp":0,"coolsetpoint":19,"coolmaxtemp":25,"coolmintemp":15,"heatsetpoint":19,"heatmaxtemp":25,"heatmintemp":15,"maxTemp":25,"minTemp":15,"setpoint":19,"roomTemp":21.4,"sleep":0,"temp_step":0.5,"mode":3,"speed":0,"coldStage":1,"heatStage":1,"coldStages":1,"heatStages":1,"humidity":61,"units":0,"errors":[],"air_demand":0,"floor_demand":0,"cold_demand":0,"heat_demand":0,"aq_mode":2,"aq_quality":0,"aq_thrlow":12,"aq_thrhigh":50,"heatangle":0,"coldangle":0,"master_zoneID":4,"eco_adapt":"off","antifreeze":0,"window_external_source":0}
[2026-02-18 16:34:23] INFO ||┌──UPDATE DATA INFO
[2026-02-18 16:34:23] DEBUG ||──SKYP KEY : systemID
[2026-02-18 16:34:23] DEBUG ||──SKYP KEY : zoneID
[2026-02-18 16:34:23] DEBUG ||──SKYP KEY : name
[2026-02-18 16:34:23] DEBUG ||──SKYP KEY : thermos_type
[2026-02-18 16:34:23] DEBUG ||──SKYP KEY : thermos_firmware
[2026-02-18 16:34:23] DEBUG ||──SKYP KEY : thermos_radio
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : battery
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : coverage
[2026-02-18 16:34:23] INFO |||──Données rafraichies - CMD : on VALEUR 1
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : double_sp
[2026-02-18 16:34:23] INFO |||──Données rafraichies - CMD : coolsetpoint VALEUR 19
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : coolmaxtemp
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : coolmintemp
[2026-02-18 16:34:23] INFO |||──Données rafraichies - CMD : heatsetpoint VALEUR 19
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : heatmaxtemp
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : heatmintemp
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : maxTemp
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : minTemp
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : setpoint
[2026-02-18 16:34:23] INFO |||──Données rafraichies - CMD : roomTemp VALEUR 21.4
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : sleep
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : temp_step
[2026-02-18 16:34:23] INFO |||──Données rafraichies - CMD : mode VALEUR 3
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : speed
[2026-02-18 16:34:23] INFO |||──Données rafraichies - CMD : coldStage VALEUR 1
[2026-02-18 16:34:23] INFO |||──Données rafraichies - CMD : heatStage VALEUR 1
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : coldStages
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : heatStages
[2026-02-18 16:34:23] INFO |||──Données rafraichies - CMD : humidity VALEUR 61
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : units
[2026-02-18 16:34:23] INFO |||──Données rafraichies - CMD : errors VALEUR
[2026-02-18 16:34:23] INFO |||──Données rafraichies - CMD : air_demand VALEUR 0
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : floor_demand
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : cold_demand
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : heat_demand
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : aq_mode
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : aq_quality
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : aq_thrlow
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : aq_thrhigh
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : heatangle
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : coldangle
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : master_zoneID
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : eco_adapt
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : antifreeze
[2026-02-18 16:34:23] DEBUG ||──CMD NON TROUVEE : window_external_source
[2026-02-18 16:34:23] INFO ||└──Fin Update Info
[2026-02-18 16:35:02] INFO Requete demandée : info 1 5
[2026-02-18 16:35:03] DEBUG REPONSE REQUETE : SUCCESS : {
"data": [{
"systemID": 1,
"zoneID": 5,
"name": "Parents",
"thermos_type": 4,
"thermos_radio": 1,
"battery": 59,
"coverage": 56,
"on": 1,
"double_sp": 0,
"coolsetpoint": 19,
"coolmaxtemp": 25,
"coolmintemp": 15,
"heatsetpoint": 19,
"heatmaxtemp": 25,
"heatmintemp": 15,
"maxTemp": 25,
"minTemp": 15,
"setpoint": 19,
"roomTemp": 21.4,
"sleep": 0,
"temp_step": 0.5,
"mode": 3,
"speed": 0,
"coldStage": 1,
"heatStage": 1,
"coldStages": 1,
"heatStages": 1,
"humidity": 61,
"units": 0,
"errors": [],
"air_demand": 0,
"floor_demand": 0,
"cold_demand": 0,
"heat_demand": 0,
"aq_mode": 2,
"aq_quality": 0,
"aq_thrlow": 12,
"aq_thrhigh": 50,
"heatangle": 0,
"coldangle": 0,
"master_zoneID": 4,
"eco_adapt": "off",
"antifreeze": 0,
[2026-02-18 16:35:03] INFO ||┌──Rafraichissement des commandes pour Ch Parents
[2026-02-18 16:35:03] INFO ||┌──Données recues {"systemID":1,"zoneID":5,"name":"Parents","thermos_type":4,"thermos_firmware":"3.76","thermos_radio":1,"battery":59,"coverage":56,"on":1,"double_sp":0,"coolsetpoint":19,"coolmaxtemp":25,"coolmintemp":15,"heatsetpoint":19,"heatmaxtemp":25,"heatmintemp":15,"maxTemp":25,"minTemp":15,"setpoint":19,"roomTemp":21.4,"sleep":0,"temp_step":0.5,"mode":3,"speed":0,"coldStage":1,"heatStage":1,"coldStages":1,"heatStages":1,"humidity":61,"units":0,"errors":[],"air_demand":0,"floor_demand":0,"cold_demand":0,"heat_demand":0,"aq_mode":2,"aq_quality":0,"aq_thrlow":12,"aq_thrhigh":50,"heatangle":0,"coldangle":0,"master_zoneID":4,"eco_adapt":"off","antifreeze":0,"window_external_source":0}
[2026-02-18 16:35:03] INFO ||┌──UPDATE DATA INFO
[2026-02-18 16:35:03] DEBUG ||──SKYP KEY : systemID
[2026-02-18 16:35:03] DEBUG ||──SKYP KEY : zoneID
[2026-02-18 16:35:03] DEBUG ||──SKYP KEY : name
[2026-02-18 16:35:03] DEBUG ||──SKYP KEY : thermos_type
[2026-02-18 16:35:03] DEBUG ||──SKYP KEY : thermos_firmware
[2026-02-18 16:35:03] DEBUG ||──SKYP KEY : thermos_radio
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : battery
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : coverage
[2026-02-18 16:35:03] INFO |||──Données rafraichies - CMD : on VALEUR 1
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : double_sp
[2026-02-18 16:35:03] INFO |||──Données rafraichies - CMD : coolsetpoint VALEUR 19
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : coolmaxtemp
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : coolmintemp
[2026-02-18 16:35:03] INFO |||──Données rafraichies - CMD : heatsetpoint VALEUR 19
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : heatmaxtemp
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : heatmintemp
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : maxTemp
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : minTemp
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : setpoint
[2026-02-18 16:35:03] INFO |||──Données rafraichies - CMD : roomTemp VALEUR 21.4
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : sleep
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : temp_step
[2026-02-18 16:35:03] INFO |||──Données rafraichies - CMD : mode VALEUR 3
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : speed
[2026-02-18 16:35:03] INFO |||──Données rafraichies - CMD : coldStage VALEUR 1
[2026-02-18 16:35:03] INFO |||──Données rafraichies - CMD : heatStage VALEUR 1
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : coldStages
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : heatStages
[2026-02-18 16:35:03] INFO |||──Données rafraichies - CMD : humidity VALEUR 61
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : units
[2026-02-18 16:35:03] INFO |||──Données rafraichies - CMD : errors VALEUR
[2026-02-18 16:35:03] INFO |||──Données rafraichies - CMD : air_demand VALEUR 0
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : floor_demand
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : cold_demand
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : heat_demand
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : aq_mode
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : aq_quality
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : aq_thrlow
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : aq_thrhigh
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : heatangle
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : coldangle
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : master_zoneID
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : eco_adapt
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : antifreeze
[2026-02-18 16:35:03] DEBUG ||──CMD NON TROUVEE : window_external_source
[2026-02-18 16:35:03] INFO ||└──Fin Update Info
Je suis dispo en MP si besoin.
