Grace à @BAGGI_166, il a trouvé une commande pour donner une valeur initiale d’éclairage au démarrage du micro module.
Le produit concerné est : Schneider electric CCT5010-002W
voici les logs de la commande concerné :
[2023-03-21 19:47:55][DEBUG] : {"ieee":"90:fd:9f:ff:fe:cd:78:0f","attributes":[{"endpoint":3,"cluster":8,"cluster_type":"in","attributes":{"17":20},"manufacturer":null}]}
[2023-03-21 19:47:56][DEBUG] : {"devices":{"90:fd:9f:ff:fe:cd:78:0f":{"3":{"8":{"17":{"value":"20","cluster_name":"Level control"}}}}}}
[2023-03-21 19:47:56][DEBUG] : Search attribut for 90:fd:9f:ff:fe:cd:78:0f logicalId : 3::8::17 => 20 convert to 20
info brut : (C’est le on_level qui est concerné)
"ieee": "90:fd:9f:ff:fe:cd:78:0f",
"nwk": 21948,
"status": 2,
"lqi": "255",
"rssi": "-77",
"last_seen": "1679425214.89716",
"node_descriptor": "01:40:8e:5e:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 3,
"status": 1,
"device_type": 257,
"profile_id": 260,
"manufacturer": "Schneider Electric",
"model": "PUCK\/DIMMER\/1",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 2
"id": 2,
"name": "stack_version",
"value": 6
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "Schneider Electric"
"id": 5,
"name": "model",
"value": "PUCK\/DIMMER\/1"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "002.004.018 R"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": [
"id": 1,
"name": "current_scene",
"value": 0
"id": 2,
"name": "current_group",
"value": 0
"id": 3,
"name": "scene_valid",
"value": 0
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 8,
"name": "Level control",
"attributes": [
"id": 0,
"name": "current_level",
"value": 20
"id": 17,
"name": "on_level",
"value": 10
"id": 769,
"name": "Ballast",
"attributes": [
"id": 2,
"name": "ballast_status",
"value": 0
"id": 2821,
"name": "Diagnostic",
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4190,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"3": {
"profile_id": 260,
"device_type": 257,
"input_clusters": [
0,
3,
4,
5,
6,
8,
769,
2821
25
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
il faudrait donc rajouter cette commande .
merci a tous et à jeedom
