J’ai un soucis ce matin, mes capteurs fonctionnent bien et remontent bien les infos, mais l’ensemble de mes actionneurs est KO et ne réponds plus
Pas de message d’erreur particulier et malgré un reboot du plugin
snif
snif
des log svp
[2021-04-01 10:41:30][DEBUG] : {"00212EFFFF04290A":{"attr":{"colorcapabilities":0,"ctmax":65279,"ctmin":0,"id":"13","lastannounced":"2021-04-01T02:11:27Z","lastseen":"2021-04-01T08:41Z","manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E27 WS opal 980lm","name":"Lu Entree","swversion":"2.3.050","type":"Color temperature light","uniqueid":"90:fd:9f:ff:fe:cf:f7:e6-01"},"e":"changed","id":"13","r":"lights","t":"event","uniqueid":"90:fd:9f:ff:fe:cf:f7:e6-01"}}
[2021-04-01 10:41:30][DEBUG] : Something received and no value updated, performing sync to create commands if needed
[2021-04-01 10:41:30][DEBUG] : 127.0.0.1:8484/api/A293C230E2/sensors type : POST
[2021-04-01 10:41:30][DEBUG] : {"00212EFFFF04290A":{"e":"changed","id":"13","r":"lights","state":{"alert":null,"bri":3,"colormode":"ct","ct":370,"on":true,"reachable":true},"t":"event","uniqueid":"90:fd:9f:ff:fe:cf:f7:e6-01"}}
[2021-04-01 10:41:30][DEBUG] : {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"02413ca60885cfb99a2ea4551244aba2","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":false,"daylight":true,"lastupdated":"2021-04-01T08:12:29.449","status":160,"sunrise":"2021-04-01T05:29:25","sunset":"2021-04-01T18:21:51"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:04:29:0a-01"},"13":{"config":{"battery":98,"duration":90,"on":true,"reachable":true,"temperature":0},"ep":1,"etag":"801ddf622dbeba0b66e106b19f15538a","lastseen":"2021-04-01T08:33Z","manufacturername":"LUMI","modelid":"lumi.sensor_motion","name":"DT Mi Entree","state":{"lastupdated":"2021-04-01T06:05:11.319","presence":false},"type":"ZHAPresence","uniqueid":"00:15:8d:00:01:db:37:5e-01-0406"},"15":{"config":{"battery":98,"on":true,"reachable":true,"temperature":2300},"ep":1,"etag":"cada3c3e238be4eea4bec5db101b64e2","lastseen":"2021-04-01T08:34Z","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"DT Entree Porte","state":{"lastupdated":"2021-04-01T08:34:34.541","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:34:71:e1-01-0006"},"17":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2200},"ep":1,"etag":"a5c251521e1e269592fd3d132f27c56a","lastseen":"2021-04-01T07:12Z","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"DT Mi Salon Baie AV","state":{"lastupdated":"2021-04-01T07:52:11.285","open":false},"type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:0b:7e:16-01-0006"},"18":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2500},"ep":1,"etag":"4b43f4aba4a33a504745fe2685891087","lastseen":"2021-04-01T07:12Z","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"DT Mi Salon Baie Cote","state":{"lastupdated":"2021-04-01T04:46:32.398","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:04:38:9f-01-0006"},"19":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2300},"ep":1,"etag":"8f0763a30b005e24f0b0f522300ceb01","lastseen":"2021-04-01T07:12Z","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"DT Mi Salon Baie AR","state":{"lastupdated":"2021-04-01T07:16:50.138","open":false},"type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:45:d4:87-01-0006"},"20":{"config":{"battery":100,"on":true,"reachable":false,"temperature":1800},"ep":1,"etag":"c3ca17c9cdfc481af578d0b02e7f3c2c","lastseen":null,"manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"DT Mi Buanderie Porte","state":{"lastupdated":"2021-03-07T10:56:13.857","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:04:55:2e-01-0006"},"21":{"config":{"battery":100,"on":true,"reachable":false,"temperature":1900},"ep":1,"etag":"97b64ac932de32919af8b9be94d61f6f","lastseen":null,"manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"DT Mi Buanderie Fen AR","state":{"lastupdated":"2021-02-21T01:38:27.023","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:04:39:85-01-0006"},"22":{"config":{"battery":98,"on":true,"reachable":true,"temperature":2800},"ep":1,"etag":"96e33662e9b57c7aa72546f0329f40b7","lastseen":"2021-04-01T07:12Z","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"DT Mi Cuisine Fen D","state":{"lastupdated":"2021-03-31T18:12:05.552","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:04:53:cd-01-0006"},"23":{"config":{"on":true,"reachable":true},"ep":1,"etag":"ac006df75987fc7e4cbaff755672e175","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","modelid":"Cable outlet","name":"Power 23","state":{"lastupdated":"2021-03-31T16:46:35.265","power":0},"type":"ZHAPower","uniqueid":"00:04:74:00:00:0d:59:8c-01-0b04"},"24":{"config":{"mode":"auto","on":true,"reachable":false},"ep":1,"etag":"2e2b8a7813468c8969d834af5f9f8621","lastseen":null,"manufacturername":"Legrand","modelid":"Cable outlet","name":"Thermostat 24","state":{"lastupdated":"none"},"type":"ZHAThermostat","uniqueid":"00:04:74:00:00:0d:59:8c-01-fc40"},"25":{"config":{"battery":90,"on":true,"reachable":false},"ep":1,"etag":"f15daac893239ebaffa7a55e092ed78a","lastseen":null,"manufacturername":"Legrand","mode":1,"modelid":"Shutters central remote switch","name":"BT VR Bureau","state":{"buttonevent":2002,"lastupdated":"2021-03-27T18:11:17.095"},"swversion":"001e","type":"ZHASwitch","uniqueid":"00:04:74:00:00:af:48:ac-01-0102"},"26":{"config":{"battery":90,"group":"4","on":true,"reachable":true},"ep":1,"etag":"ad2ca3c13dd8f017e5a9a567d90adb79","lastseen":"2021-04-01T08:24Z","manufacturername":"Legrand","mode":1,"modelid":"Remote switch","name":"BT Garage","state":{"buttonevent":2002,"lastupdated":"2021-04-01T08:24:01.429"},"swversion":"001e","type":"ZHASwitch","uniqueid":"00:04:74:00:00:b0:3c:38-01-0006"},"27":{"config":{"on":true,"reachable":true},"ep":1,"etag":"8d90efd1050e6932c83546e6a24c6116","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","modelid":"Connected outlet","name":"Power 27","state":{"lastupdated":"2021-03-31T16:48:54.194","power":0},"type":"ZHAPower","uniqueid":"00:04:74:00:00:0b:ef:75-01-0b04"},"28":{"config":{"on":true,"reachable":true},"ep":1,"etag":"f55a0de23b74cfafd6e9d345c38981a5","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","modelid":"Connected outlet","name":"Power 28","state":{"lastupdated":"2021-03-31T16:57:22.031","power":0},"type":"ZHAPower","uniqueid":"00:04:74:00:00:0b:ef:4f-01-0b04"},"29":{"config":{"battery":100,"group":"5","on":true,"reachable":true},"ep":1,"etag":"b87946ccb9b9508eb5aaa956f946a001","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","mode":1,"modelid":"Double gangs remote switch","name":"BT LEG4 1 Entree","state":{"buttonevent":2002,"lastupdated":"2021-04-01T05:19:22.135"},"swversion":"0006","type":"ZHASwitch","uniqueid":"00:04:74:00:00:92:dc:d3-01-0006"},"30":{"config":{"group":"6","on":true,"reachable":false},"ep":2,"etag":"3c0f4ab0c9ba83960e10b2e982cd7f01","lastseen":null,"manufacturername":"Legrand","mode":1,"modelid":"Double gangs remote switch","name":"BT LEG4 1 Entree","state":{"buttonevent":4002,"lastupdated":"2021-03-31T06:06:17.843"},"swversion":"0006","type":"ZHASwitch","uniqueid":"00:04:74:00:00:92:dc:d3-02-0006"},"31":{"config":{"battery":90,"on":true,"reachable":true},"ep":1,"etag":"5562b01aeef00105bcc9587bbb0e8e2d","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","mode":1,"modelid":"Shutters central remote switch","name":"BT VR SdB 1ER","state":{"buttonevent":1002,"lastupdated":"2021-04-01T05:44:46.117"},"swversion":"001e","type":"ZHASwitch","uniqueid":"00:04:74:00:00:af:d7:42-01-0102"},"32":{"config":{"battery":90,"on":true,"reachable":true},"ep":1,"etag":"7ae4878c2ef7150ceb78ea22c1fbf0cc","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","mode":1,"modelid":"Shutters central remote switch","name":"BT VR Ch Invitee","state":{"buttonevent":1002,"lastupdated":"2021-04-01T05:44:26.647"},"swversion":"001e","type":"ZHASwitch","uniqueid":"00:04:74:00:00:af:d7:3f-01-0102"},"33":{"config":{"battery":null,"on":true,"reachable":true},"ep":1,"etag":"4db878b5e3064c2d7c7e36ba17602489","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","mode":1,"modelid":"Shutters central remote switch","name":"BT VR Parents","state":{"buttonevent":1002,"lastupdated":"2021-04-01T05:21:37.248"},"swversion":"001e","type":"ZHASwitch","uniqueid":"00:04:74:00:00:af:d7:3b-01-0102"},"34":{"config":{"battery":100,"on":true,"reachable":false},"ep":1,"etag":"93113064af76084b3ab84d8423f85aeb","lastseen":null,"manufacturername":"Legrand","mode":1,"modelid":"Shutters central remote switch","name":"BT VR Salon","state":{"buttonevent":1002,"lastupdated":"2021-03-27T07:35:29.451"},"swversion":"001e","type":"ZHASwitch","uniqueid":"00:04:74:00:00:af:d7:3d-01-0102"},"35":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"d410d03f358b442a5d0ece7bab953f7b","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","mode":1,"modelid":"Shutters central remote switch","name":"BT VR Olivia","state":{"buttonevent":1002,"lastupdated":"2021-04-01T05:17:54.571"},"swversion":"001e","type":"ZHASwitch","uniqueid":"00:04:74:00:00:af:d7:3e-01-0102"},"36":{"config":{"battery":null,"on":true,"reachable":true},"ep":1,"etag":"2aa830f50557b1820edf514bfa353c2e","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","mode":1,"modelid":"Shutters central remote switch","name":"BT VR Erwan","state":{"buttonevent":1002,"lastupdated":"2021-04-01T05:44:42.145"},"swversion":"001e","type":"ZHASwitch","uniqueid":"00:04:74:00:00:af:d7:43-01-0102"},"37":{"config":{"battery":null,"on":true,"reachable":true},"ep":1,"etag":"a68ef24b22ea308ed86db890049dc9f3","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","mode":1,"modelid":"Shutters central remote switch","name":"BT VR Cuisine","state":{"buttonevent":1002,"lastupdated":"2021-04-01T05:48:34.408"},"swversion":"001e","type":"ZHASwitch","uniqueid":"00:04:74:00:00:af:d7:3a-01-0102"},"38":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"69d60667889d9e082cbe326693ce1ea1","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","mode":1,"modelid":"Shutters central remote switch","name":"BT VR SDB RDC","state":{"buttonevent":1002,"lastupdated":"2021-04-01T05:43:33.836"},"swversion":"001e","type":"ZHASwitch","uniqueid":"00:04:74:00:00:af:d7:40-01-0102"},"4":{"config":{"battery":85,"on":true,"reachable":true,"temperature":2600},"ep":1,"etag":"bcb3700d3694ba8d571e758c62ad0e03","lastseen":"2021-04-01T07:12Z","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"DT Mi Entree SSol","state":{"lastupdated":"2021-04-01T06:10:33.457","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:04:38:e0-01-0006"},"40":{"config":{"battery":null,"group":"19","on":true,"reachable":false},"ep":1,"etag":"27c322e4f5e4f2fed389df23551b3417","lastseen":null,"manufacturername":"Legrand","mode":1,"modelid":"Remote toggle switch","name":"BT Sonnette SSOL","state":{"buttonevent":null,"lastupdated":"none"},"swversion":"0020","type":"ZHASwitch","uniqueid":"00:04:74:00:00:0f:3c:0b-01-0006"},"41":{"config":{"battery":null,"group":"22","on":true,"reachable":false},"ep":1,"etag":"df5a72d0f4d48c8818f83bdc98ac41bb","lastseen":null,"manufacturername":"Legrand","mode":1,"modelid":"Remote toggle switch","name":"BT Sonnette Entree","state":{"buttonevent":null,"lastupdated":"none"},"swversion":"0020","type":"ZHASwitch","uniqueid":"00:04:74:00:00:0f:3c:26-01-0006"},"43":{"config":{"alert":"none","battery":16,"group":"24","on":true,"reachable":true},"ep":1,"etag":"3ebcf2a0007c3d0159a3526028e45f9c","lastseen":"2021-04-01T07:12Z","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"BT IKEA SALON","state":{"buttonevent":1002,"lastupdated":"2021-03-31T19:53:08.286"},"swversion":"2.3.014","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:ab:e4:ca-01-1000"},"44":{"config":{"alert":"none","battery":74,"group":"25","on":true,"reachable":true},"ep":1,"etag":"627b61f374b289b2231ba39d6f878c0d","lastseen":"2021-04-01T07:12Z","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"BT IKEA OLIVIA","state":{"buttonevent":1002,"lastupdated":"2021-04-01T05:17:54.744"},"swversion":"2.3.014","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:b7:d6:34-01-1000"},"45":{"config":{"battery":85,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"1424ec4c09e760d28d26b9dea7f592b3","lastseen":"2021-04-01T07:12Z","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temperature 45","state":{"lastupdated":"2021-03-31T16:35:46.911","temperature":173},"swversion":"20161129","type":"ZHATemperature","uniqueid":"00:15:8d:00:02:75:38:f6-01-0402"},"46":{"config":{"battery":85,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"49e25a31083d7eea430e380e76942ba3","lastseen":"2021-04-01T07:12Z","manufacturername":"LUMI","modelid":"lumi.weather","name":"Humidity 46","state":{"humidity":5469,"lastupdated":"2021-03-31T16:35:46.924"},"swversion":"20161129","type":"ZHAHumidity","uniqueid":"00:15:8d:00:02:75:38:f6-01-0405"},"47":{"config":{"battery":85,"on":true,"reachable":true},"ep":1,"etag":"0a8e0a512f5c5117f78baba456ed883b","lastseen":"2021-04-01T07:12Z","manufacturername":"LUMI","modelid":"lumi.weather","name":"Pressure 47","state":{"lastupdated":"2021-03-31T16:35:46.959","pressure":983},"swversion":"20161129","type":"ZHAPressure","uniqueid":"00:15:8d:00:02:75:38:f6-01-0403"},"48":{"config":{"battery":100,"offset":0,"on":true,"reachable":false},"ep":1,"etag":"0bbc37c8b527506f6b4337e4674f3bfd","lastseen":null,"manufacturername":"LUMI","modelid":"lumi.weather","name":"Temperature 48","state":{"lastupdated":"2021-02-13T07:24:01.585","temperature":1107},"swversion":"20161129","type":"ZHATemperature","uniqueid":"00:15:8d:00:02:78:69:3b-01-0402"},"49":{"config":{"battery":100,"offset":0,"on":true,"reachable":false},"ep":1,"etag":"39d7bfb42996043679179dcaf19ca064","lastseen":null,"manufacturername":"LUMI","modelid":"lumi.weather","name":"Humidity 49","state":{"humidity":5613,"lastupdated":"2021-02-13T07:24:01.591"},"swversion":"20161129","type":"ZHAHumidity","uniqueid":"00:15:8d:00:02:78:69:3b-01-0405"},"50":{"config":{"battery":100,"on":true,"reachable":false},"ep":1,"etag":"b46cf0802f9767bf12452d4e6b99102f","lastseen":null,"manufacturername":"LUMI","modelid":"lumi.weather","name":"Pressure 50","state":{"lastupdated":"2021-02-13T07:24:01.597","pressure":993},"swversion":"20161129","type":"ZHAPressure","uniqueid":"00:15:8d:00:02:78:69:3b-01-0403"},"51":{"config":{"battery":100,"enrolled":3,"on":true,"pending":[],"reachable":true,"temperature":2300},"ep":1,"etag":"5477298ce37df7ae3a1601c2492e0087","lastseen":"2021-04-01T08:41Z","manufacturername":"LUMI","modelid":"lumi.sensor_smoke","name":"Fire 51","state":{"fire":false,"lastupdated":"2021-02-28T22:27:42.338","lowbattery":false,"tampered":false},"swversion":"20170314","type":"ZHAFire","uniqueid":"00:15:8d:00:02:b0:aa:31-01-0500"},"52":{"config":{"alert":"none","battery":87,"group":"26","on":true,"reachable":false},"ep":1,"etag":"33c19e0fbb5f82325e97b827c053986a","lastseen":null,"manufacturername":"IKEA of Sweden","mode":1,"modelid":"TRADFRI on\/off switch","name":"TRADFRI on\/off switch ","state":{"buttonevent":2003,"lastupdated":"2021-02-06T17:59:18.945"},"swversion":"2.2.010","type":"ZHASwitch","uniqueid":"00:0d:6f:ff:fe:f3:41:49-01-1000"},"53":{"config":{"on":true,"reachable":true},"ep":1,"etag":"14faafa44c7f08eca0a76f997ab04219","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","modelid":"Contactor","name":"Power 53","state":{"lastupdated":"2021-04-01T08:03:32.349","power":0},"type":"ZHAPower","uniqueid":"00:04:74:00:00:83:81:b5-01-0b04"},"54":{"config":{"battery":80,"group":"27","on":true,"reachable":true},"ep":1,"etag":"0d7220399c7651d6037c460cab78cf27","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","mode":1,"modelid":"Remote switch","name":"BT LU SDB RDC","state":{"buttonevent":2002,"lastupdated":"2021-04-01T05:43:34.425"},"swversion":"001e","type":"ZHASwitch","uniqueid":"00:04:74:00:00:b0:9f:25-01-0006"},"55":{"config":{"battery":100,"group":"28","on":true,"reachable":false},"ep":1,"etag":"56fb4c9f8c9179aad4bc104371c11074","lastseen":null,"manufacturername":"Legrand","mode":1,"modelid":"Double gangs remote switch","name":"Double gangs remote switch 55","state":{"buttonevent":1002,"lastupdated":"2021-03-22T06:33:19.580"},"swversion":"0006","type":"ZHASwitch","uniqueid":"00:04:74:00:00:92:dd:17-01-0006"},"56":{"config":{"group":"29","on":true,"reachable":false},"ep":2,"etag":"50a5aae6b1fb9d1fb14895d903ba25aa","lastseen":null,"manufacturername":"Legrand","mode":1,"modelid":"Double gangs remote switch","name":"Double gangs remote switch 56","state":{"buttonevent":4002,"lastupdated":"2021-03-29T05:45:55.733"},"swversion":"0006","type":"ZHASwitch","uniqueid":"00:04:74:00:00:92:dd:17-02-0006"},"57":{"config":{"battery":100,"group":"30","on":true,"reachable":false},"ep":1,"etag":"d468aa77ab88ae5c9487a5351d0fabc4","lastseen":null,"manufacturername":"Legrand","mode":1,"modelid":"Double gangs remote switch","name":"Double gangs remote switch 57","state":{"buttonevent":1002,"lastupdated":"2021-03-30T05:24:41.023"},"swversion":"0006","type":"ZHASwitch","uniqueid":"00:04:74:00:00:92:dc:f6-01-0006"},"58":{"config":{"group":"31","on":true,"reachable":false},"ep":2,"etag":"a0955095c9604e256050e4e6d74193c6","lastseen":null,"manufacturername":"Legrand","mode":1,"modelid":"Double gangs remote switch","name":"Double gangs remote switch 58","state":{"buttonevent":3002,"lastupdated":"2021-03-19T11:11:55.467"},"swversion":"0006","type":"ZHASwitch","uniqueid":"00:04:74:00:00:92:dc:f6-02-0006"},"59":{"config":{"group":null,"on":true,"reachable":false},"ep":1,"etag":"b6acb1b4a1a6c6c1fcf828f27d21c6c8","lastseen":null,"manufacturername":"Legrand","mode":1,"modelid":"Teleruptor","name":"Switch 59","state":{"buttonevent":null,"lastupdated":"none"},"type":"ZHASwitch","uniqueid":"00:04:74:00:00:83:73:9d-01-0006"},"6":{"config":{"battery":98,"on":true,"reachable":true,"temperature":1800},"ep":1,"etag":"02594c2ad8451b332be9601a0db9268a","lastseen":"2021-04-01T08:24Z","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"DT Mi Garage","state":{"lastupdated":"2021-04-01T08:24:17.640","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:05:b2:f1-01-0006"},"60":{"config":{"on":true,"reachable":true},"ep":1,"etag":"5cb7a90b90dd65f743c98613a460a357","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","modelid":"Teleruptor","name":"Power 60","state":{"lastupdated":"2021-04-01T08:03:49.441","power":0},"type":"ZHAPower","uniqueid":"00:04:74:00:00:83:73:9d-01-0b04"},"61":{"config":{"on":true,"reachable":true},"ep":1,"etag":"c2ecb756e73606841a5160c3b321e796","lastseen":"2021-04-01T08:39Z","manufacturername":"Legrand","modelid":"Teleruptor","name":"Power 61","state":{"lastupdated":"2021-04-01T08:34:31.597","power":0},"type":"ZHAPower","uniqueid":"00:04:74:00:00:83:a0:8b-01-0b04"},"62":{"config":{"on":true,"reachable":true},"ep":1,"etag":"d2acc126072c3e56e39abae198ac1ad0","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","modelid":"Cable outlet","name":"Power 62","state":{"lastupdated":"2021-03-31T16:47:23.764","power":0},"type":"ZHAPower","uniqueid":"00:04:74:00:00:10:02:fa-01-0b04"},"63":{"config":{"mode":null,"on":true,"reachable":false},"ep":1,"etag":"04b642fc8300d977ea37c70779a82c65","lastseen":null,"manufacturername":"Legrand","modelid":"Cable outlet","name":"Thermostat 63","state":{"lastupdated":"none"},"type":"ZHAThermostat","uniqueid":"00:04:74:00:00:10:02:fa-01-fc40"},"64":{"config":{"battery":100,"on":true,"reachable":false},"ep":1,"etag":"9a409e901ceefd19a259a422e6f8fd67","lastseen":null,"manufacturername":"Legrand","mode":1,"modelid":"Shutters central remote switch","name":"Shutters central remote switch 64","state":{"buttonevent":2002,"lastupdated":"2021-03-28T18:15:55.666"},"type":"ZHASwitch","uniqueid":"00:04:74:00:00:af:d7:3c-01-0102"},"65":{"config":{"on":true,"reachable":true},"ep":1,"etag":"723e9c465bba5e429ee9ddfca1c7a6f1","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","modelid":"Teleruptor","name":"Power 65","state":{"lastupdated":"2021-04-01T08:00:18.654","power":0},"type":"ZHAPower","uniqueid":"00:04:74:00:00:83:a0:90-01-0b04"},"66":{"config":{"on":true,"reachable":true},"ep":1,"etag":"093dda7294a03a949ded729bbaf34849","lastseen":"2021-04-01T07:12Z","manufacturername":"Legrand","modelid":"Teleruptor","name":"Power 66","state":{"lastupdated":"2021-04-01T08:03:34.311","power":0},"type":"ZHAPower","uniqueid":"00:04:74:00:00:83:a0:8e-01-0b04"},"67":{"config":{"battery":90,"group":"35","on":true,"reachable":true},"ep":1,"etag":"6e02c4b77883eea1259bc886c7bc43ae","lastseen":"2021-04-01T08:15Z","manufacturername":"Legrand","mode":1,"modelid":"Double gangs remote switch","name":"Double gangs remote switch 67","state":{"buttonevent":2002,"lastupdated":"2021-04-01T08:15:27.746"},"swversion":"0006","type":"ZHASwitch","uniqueid":"00:04:74:00:00:92:dd:15-01-0006"},"68":{"config":{"group":"36","on":true,"reachable":true},"ep":2,"etag":"da6a1b543a8bee4f48f1956fff880032","lastseen":"2021-04-01T08:15Z","manufacturername":"Legrand","mode":1,"modelid":"Double gangs remote switch","name":"Double gangs remote switch 68","state":{"buttonevent":3002,"lastupdated":"2021-03-19T16:29:34.096"},"swversion":"0006","type":"ZHASwitch","uniqueid":"00:04:74:00:00:92:dd:15-02-0006"},"69":{"config":{"battery":100,"on":true,"reachable":false},"ep":1,"etag":"8b97b1e742fa351ce549b59838dc494a","lastseen":null,"manufacturername":"Legrand","mode":1,"modelid":"Shutters central remote switch","name":"Shutters central remote switch 69","state":{"buttonevent":1002,"lastupdated":"2021-03-27T18:11:47.732"},"swversion":"002a","type":"ZHASwitch","uniqueid":"00:04:74:00:00:c1:0d:b3-01-0102"},"7":{"config":{"alert":"none","battery":47,"delay":266,"duration":60,"group":"56767","on":true,"reachable":true},"ep":1,"etag":"453744edc90435c142d176773c4482df","lastseen":"2021-04-01T08:23Z","manufacturername":"IKEA of Sweden","modelid":"TRADFRI motion sensor","name":"DT Ikea Entree SSol","state":{"dark":false,"lastupdated":"2021-04-01T08:24:55.482","presence":false},"swversion":"1.2.214","type":"ZHAPresence","uniqueid":"00:0b:57:ff:fe:32:80:5f-01-0006"}}
[2021-04-01 10:41:30][DEBUG] : 127.0.0.1:8484/api/A293C230E2/lights type : POST
[2021-04-01 10:41:30][DEBUG] : {"1":{"etag":"15c7888de1777c4c291a9966eaf32dab","hascolor":false,"lastannounced":null,"lastseen":"2021-04-01T08:41Z","manufacturername":"dresden elektronik","modelid":"ConBee II","name":"Configuration tool 1","state":{"reachable":true},"swversion":"0x26670700","type":"Configuration tool","uniqueid":"00:21:2e:ff:ff:04:29:0a-01"},"13":{"colorcapabilities":0,"ctmax":65279,"ctmin":0,"etag":"67fc23a2d4210015becbd8d40268a3e4","hascolor":true,"lastannounced":"2021-04-01T02:11:27Z","lastseen":"2021-04-01T08:41Z","manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E27 WS opal 980lm","name":"Lu Entree","state":{"alert":"none","bri":3,"colormode":"ct","ct":370,"on":true,"reachable":true},"swversion":"2.3.050","type":"Color temperature light","uniqueid":"90:fd:9f:ff:fe:cf:f7:e6-01"},"14":{"colorcapabilities":8,"etag":"d6d320847c582ee97a73369633d2119c","hascolor":true,"lastannounced":"2021-02-13T09:32:07Z","lastseen":"2021-03-31T17:03Z","manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E27 CWS opal 600lm","name":"Lu Salon Piano","state":{"alert":"none","bri":254,"colormode":"xy","effect":"none","hue":0,"on":false,"reachable":false,"sat":0,"xy":[0.459,0.383]},"swversion":"1.3.013","type":"Color light","uniqueid":"00:0d:6f:ff:fe:24:d7:b1-01"},"15":{"colorcapabilities":0,"ctmax":65279,"ctmin":0,"etag":"cd0bd3c217357468c5fa15ed5e496be1","hascolor":true,"lastannounced":"2021-03-21T10:29:09Z","lastseen":"2021-03-31T17:03Z","manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E27 WS opal 980lm","name":"Lu Olivia","state":{"alert":"none","bri":179,"colormode":"ct","ct":370,"on":false,"reachable":false},"swversion":"2.3.050","type":"Color temperature light","uniqueid":"90:fd:9f:ff:fe:d1:83:4f-01"},"16":{"etag":"eaff79643175afd3f8e3d1c73016259a","hascolor":false,"lastannounced":"2021-03-21T10:29:54Z","lastseen":"2021-03-25T18:40Z","manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E14 W op\/ch 400lm","name":"Lu Olivia 2","state":{"alert":"none","bri":53,"on":false,"reachable":false},"swversion":"1.2.214","type":"Dimmable light","uniqueid":"08:6b:d7:ff:fe:00:46:05-01"},"17":{"colorcapabilities":0,"ctmax":65279,"ctmin":0,"etag":"566b15ec52076f12f09734e9160d69cb","hascolor":true,"lastannounced":"2021-03-20T19:51:22Z","lastseen":"2021-04-01T08:35Z","manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E27 WS\ufffdopal 980lm","name":"Lu Salon Chevet","state":{"alert":"none","bri":168,"colormode":"ct","ct":400,"on":false,"reachable":true},"swversion":"2.3.050","type":"Color temperature light","uniqueid":"00:0b:57:ff:fe:bf:26:1b-01"},"18":{"colorcapabilities":0,"ctmax":65279,"ctmin":0,"etag":"1c1e6a1ccdfdef78f134daa0d9cbb38d","hascolor":true,"lastannounced":"2021-02-13T09:32:07Z","lastseen":"2021-03-31T17:03Z","manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E27 WS\ufffdopal 980lm","name":"Lu GW SONETTE SSOL","state":{"alert":"none","bri":143,"colormode":"ct","ct":370,"on":false,"reachable":true},"swversion":"2.3.050","type":"Color temperature light","uniqueid":"00:0b:57:ff:fe:9d:b6:24-01"},"19":{"etag":"ecd7541842a21d41fbbfd31356c3c458","hascolor":false,"lastannounced":"2021-02-16T08:18:08Z","lastseen":"2021-04-01T08:03Z","manufacturername":"Legrand","modelid":"Teleruptor","name":"On\/Off plug-in unit 19","state":{"alert":"none","on":false,"reachable":true},"swversion":"0035","type":"On\/Off plug-in unit","uniqueid":"00:04:74:00:00:83:73:9d-01"},"2":{"colorcapabilities":16,"ctmax":454,"ctmin":250,"etag":"041f873faa9fdaf510403663a12b2c34","hascolor":true,"lastannounced":"2021-03-31T21:02:30Z","lastseen":"2021-04-01T08:32Z","manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E27 WS opal 980lm","name":"Lu GW SONETTE ENTREE","state":{"alert":"none","bri":254,"colormode":"ct","ct":370,"on":false,"reachable":true},"swversion":"1.2.217","type":"Color temperature light","uniqueid":"00:0b:57:ff:fe:c0:80:6b-01"},"20":{"etag":"029d47c07f8b31ba018db4a4ba056b55","hascolor":false,"lastannounced":"2021-03-13T23:26:12Z","lastseen":"2021-04-01T08:39Z","manufacturername":"Legrand","modelid":"Teleruptor","name":"On\/Off plug-in unit 20","state":{"alert":"none","on":false,"reachable":true},"swversion":"0025","type":"On\/Off plug-in unit","uniqueid":"00:04:74:00:00:83:a0:8b-01"},"21":{"etag":"610553a1096bba6b333a589724107114","hascolor":false,"lastannounced":"2021-02-28T10:28:36Z","lastseen":"2021-04-01T08:03Z","manufacturername":"Legrand","modelid":"Contactor","name":"On\/Off plug-in unit 21","state":{"alert":"none","on":false,"reachable":true},"swversion":"0025","type":"On\/Off plug-in unit","uniqueid":"00:04:74:00:00:83:81:b5-01"},"22":{"etag":"0090f52f7bb97c4fab928b9e121ec5e3","hascolor":false,"lastannounced":"2021-04-01T03:24:07Z","lastseen":"2021-04-01T03:24Z","manufacturername":"Legrand","modelid":"Cable outlet","name":"Level control switch 22","state":{"alert":"none","on":false,"reachable":true},"swversion":"0008","type":"Level control switch","uniqueid":"00:04:74:00:00:10:02:fa-01"},"23":{"etag":"eded00d829435c21833ede443ccee6c3","hascolor":false,"lastannounced":"2021-03-13T15:25:30Z","lastseen":"2021-04-01T08:35Z","manufacturername":"Legrand","modelid":"Teleruptor","name":"On\/Off plug-in unit 23","state":{"alert":"none","on":false,"reachable":true},"swversion":"0025","type":"On\/Off plug-in unit","uniqueid":"00:04:74:00:00:83:a0:90-01"},"24":{"etag":"1e81347e8a014b24a174093cf1f12828","hascolor":false,"lastannounced":"2021-03-20T22:07:51Z","lastseen":"2021-04-01T08:40Z","manufacturername":"Legrand","modelid":"Teleruptor","name":"On\/Off plug-in unit 24","state":{"alert":"none","on":false,"reachable":true},"swversion":"0025","type":"On\/Off plug-in unit","uniqueid":"00:04:74:00:00:83:a0:8e-01"},"3":{"colorcapabilities":8,"etag":"a0c53ef9919fbea28d572e3d3e4b1dd2","hascolor":true,"lastannounced":"2021-03-21T10:20:38Z","lastseen":"2021-04-01T08:37Z","manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E27 CWS opal 600lm","name":"Chevet Parents","state":{"alert":"none","bri":151,"colormode":"xy","effect":"1","hue":0,"on":false,"reachable":true,"sat":0,"xy":[0.458,0.41]},"swversion":"1.3.002","type":"Color light","uniqueid":"90:fd:9f:ff:fe:de:9a:b7-01"},"4":{"colorcapabilities":31,"ctmax":500,"ctmin":153,"etag":"5bee0a4c76fa08d10a27a56d9d9be30f","hascolor":true,"lastannounced":"2020-12-02T12:55:39Z","lastseen":"2021-04-01T08:15Z","manufacturername":"Philips","modelid":"LLC020","name":"Extended color light 4","state":{"alert":"none","bri":2,"colormode":"hs","ct":451,"effect":"none","hue":5942,"on":false,"reachable":true,"sat":166,"xy":[0.5046,0.3914]},"swversion":"5.38.3.19141","type":"Extended color light","uniqueid":"00:17:88:01:01:15:2d:6c-0b"},"5":{"etag":"5bb623774f08905b7ea1843ee5698c03","hascolor":false,"lastannounced":"2021-03-06T09:18:56Z","lastseen":"2021-03-31T16:50Z","manufacturername":"Legrand","modelid":"Cable outlet","name":"Radiateur Parents","state":{"alert":"none","on":true,"reachable":true},"swversion":"0008","type":"Level control switch","uniqueid":"00:04:74:00:00:0d:59:8c-01"},"6":{"etag":"20e47788e0933d7c5084c69a5d4269db","hascolor":false,"lastannounced":"2021-03-31T10:02:21Z","lastseen":"2021-04-01T08:39Z","manufacturername":"Legrand","modelid":"Connected outlet","name":"Prise SdB 1ER","state":{"alert":"none","on":true,"reachable":true},"swversion":"016","type":"On\/Off plug-in unit","uniqueid":"00:04:74:00:00:0b:ef:75-01"},"7":{"etag":"31bcdf037321c6c0de7ab36f3608a40f","hascolor":false,"lastannounced":"2021-03-31T12:48:27Z","lastseen":"2021-04-01T08:34Z","manufacturername":"Legrand","modelid":"Connected outlet","name":"Prise Salon","state":{"alert":"none","on":true,"reachable":true},"swversion":"016","type":"On\/Off plug-in unit","uniqueid":"00:04:74:00:00:0b:ef:4f-01"},"8":{"etag":"6b098f5409456f361d47a682ec6f48ae","hascolor":false,"lastannounced":"2021-02-07T10:27:56Z","lastseen":"2021-04-01T08:37Z","manufacturername":"Legrand","modelid":"Dimmer switch w\/o neutral","name":"Lumiere Erwan","state":{"alert":"none","bri":0,"on":false,"reachable":true},"swversion":"0026","type":"Dimmable light","uniqueid":"00:04:74:00:00:9c:d3:1b-01"},"9":{"etag":"de932a8317c9ce2401a9c91c688f0ee9","hascolor":false,"lastannounced":"2021-03-31T02:27:34Z","lastseen":"2021-04-01T08:40Z","manufacturername":"Legrand","modelid":"Dimmer switch w\/o neutral","name":"Dimmable light 9","state":{"alert":"none","bri":139,"on":false,"reachable":true},"swversion":"0026","type":"Dimmable light","uniqueid":"00:04:74:00:00:9c:dc:9e-01"}}
[2021-04-01 10:41:54][DEBUG] : 127.0.0.1:8484/api/A293C230E2/lights/23 type : POST
[2021-04-01 10:41:54][DEBUG] : 127.0.0.1:8484/api/A293C230E2/sensors/65 type : POST
[2021-04-01 10:42:02][DEBUG] : Execute commande : lights/23/state whith parameters : {"on":true}
[2021-04-01 10:42:02][DEBUG] : 127.0.0.1:8484/api/A293C230E2/lights/23/state type : PUT
[2021-04-01 10:42:02][DEBUG] : {"00212EFFFF04290A":{"e":"changed","id":"23","r":"lights","state":{"alert":null,"on":true,"reachable":true},"t":"event","uniqueid":"00:04:74:00:00:83:a0:90-01"}}
[2021-04-01 10:42:03][DEBUG] : Execute commande : lights/23/state whith parameters : {"on":false}
10:43:42:082 enqueue event config/localtime for /config/
10:43:42:082 APS-DATA.request id: 195, addrmode: 0x03, addr: 0x00047400009cdc9e, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0x01 queue: 0 len: 5 tx.options 0x00
10:43:42:494 Node 0x00047400000BEF75 is known by 0 neighbors, last seen -1 s
10:43:42:975 Node 0x00047400000BEF4F is known by 0 neighbors, last seen -1 s
10:43:43:082 enqueue event config/localtime for /config/
10:43:43:153 Poll APS confirm 195 status: 0xE1
10:43:43:153 drop item attr/modelid
10:43:43:153 drop item attr/swversion
10:43:43:153 drop item state/bri
10:43:43:153 0x00047400009CDC9E error APSDE-DATA.confirm: 0xE1 on task
10:43:43:153 Erase task req-id: 195, type: 19 zcl seqno: 128 send time 1, profileId: 0x0104, clusterId: 0x0006
10:43:43:153 APS-DATA.confirm id: 195, status: 0xE1
10:43:43:153 unhandled APS-DATA.confirm id: 195 status 0xE1
10:43:43:454 Node 0x000474000092DCD3 is known by 0 neighbors, last seen -1 s
10:43:43:735 poll node 00:04:74:00:00:83:a0:8b-01
10:43:43:735 Poll light node On/Off plug-in unit 20
10:43:43:783 read attributes of 0x000474000083A08B cluster: 0x0006: [ 10:43:43:783 0x0000 10:43:43:783 ]
10:43:43:783 add task 170 type 19 to 0x000474000083A08B cluster 0x0006 req.id 203
10:43:43:783 Poll APS request 203 to 0x000474000083A08B cluster: 0x0006
10:43:43:852 MAC Poll 0x02 0x7EF7, life time: 4294967295 sec, dev timeout: 4294967295 sec
10:43:43:852 read attributes of 0x00158D0002B0AA31 cluster: 0x0500: [ 10:43:43:852 0x0000 10:43:43:852 0x0010 10:43:43:852 ]
10:43:43:852 add task 172 type 19 to 0x00158D0002B0AA31 cluster 0x0500 req.id 205
10:43:43:882 APS-DATA.request id: 203, addrmode: 0x03, addr: 0x000474000083a08b, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0x01 queue: 0 len: 5 tx.options 0x00
10:43:43:934 Node 0x0004740000AFD742 is known by 0 neighbors, last seen -1 s
10:43:43:983 APS-DATA.request id: 205, addrmode: 0x03, addr: 0x00158d0002b0aa31, profile: 0x0104, cluster: 0x0500, ep: 0x01 -> 0x01 queue: 1 len: 7 tx.options 0x00
10:43:44:083 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
10:43:44:083 enqueue event config/localtime for /config/
10:43:44:414 Node 0x0004740000AFD73F is known by 0 neighbors, last seen -1 s
10:43:44:894 Node 0x0004740000AFD73D is known by 0 neighbors, last seen -1 s
10:43:44:959 Poll APS confirm 203 status: 0xE1
10:43:44:959 drop item attr/modelid
10:43:44:959 drop
item attr/swversion
10:43:44:959 0x000474000083A08B error APSDE-DATA.confirm: 0xE1 on task
10:43:44:959 Erase task req-id: 203, type: 19 zcl seqno: 129 send time 1, profileId: 0x0104, clusterId: 0x0006
10:43:44:959 APS-DATA.confirm id: 203, status: 0xE1
10:43:44:959 unhandled APS-DATA.confirm id: 203 status 0xE1
10:43:45:083 enqueue event config/localtime for /config/
10:43:45:374 Node 0x0004740000AFD73B is known by 0 neighbors, last seen -1 s
10:43:45:583 poll node 00:04:74:00:00:83:81:b5-01
10:43:45:583 Poll light node On/Off plug-in unit 21
10:43:45:614 Mgmt_Lqi_req zdpSeq: 15 to 0x00212EFFFF04290A start index 10
10:43:45:614 APS-DATA.request id: 213, addrmode: 0x03, addr: 0x00212effff04290a, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 1 len: 2 tx.options 0x00
10:43:45:620 APS-DATA.confirm id: 213, status: 0x00 SUCCESS
10:43:45:620 APS-DATA.confirm request id: 213 -> confirmed, timeout 27795328
10:43:45:622 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 117, rssi: 32
10:43:45:622 asdu: 0f000b0a010a2904ffff2e2100167e0b02008d1500882c120001ff
10:43:45:622 APS-DATA.indication request id: 213 -> finished
10:43:45:622 APS-DATA.request id: 213 erase from queue
10:43:45:623 ZDP status = 0x00 -> SUCCESS
10:43:45:623 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
10:43:45:623 ZDP Mgmt_Lqi_rsp zdpSeq: 15 from 0x00212EFFFF04290A total: 11, startIndex: 10, listCount: 1
10:43:45:623 * neighbor: 0x00158D00020B7E16 (0x2C88), LQI: 255, relation: 0x01 rxOnWHenIdle: 0
10:43:45:633 read attributes of 0x00047400008381B5 cluster: 0x0006: [ 10:43:45:633 0x0000 10:43:45:633 ]
10:43:45:633 add task 180 type 19 to 0x00047400008381B5 cluster 0x0006 req.id 215
10:43:45:633 Poll APS request 215 to 0x00047400008381B5 cluster: 0x0006
10:43:45:682 APS-DATA.request id: 215, addrmode: 0x03, addr: 0x00047400008381b5, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0x01 queue: 1 len: 5 tx.options 0x00
10:43:45:833 Poll APS confirm 215 status: 0xE1
10:43:45:833 drop item attr/modelid
10:43:45:833 drop item attr/swversion
10:43:45:833 0x00047400008381B5 error APSDE-DATA.confirm: 0xE1 on task
10:43:45:833 Erase task req-id: 215, type: 19 zcl seqno: 131 send time 0, profileId: 0x0104, clusterId: 0x0006
10:43:45:833 APS-DATA.confirm id: 215, status: 0xE1
10:43:45:833 unhandled APS-DATA.confirm id: 215 status 0xE1
10:43:45:854 Node 0x0004740000AFD73E is known by 0 neighbors, last seen -1 s
10:43:46:082 enqueue event config/localtime for /config/
10:43:46:334 Node 0x0004740000AFD743 is known by 0 neighbors, last seen -1 s
10:43:46:466 poll node 00:04:74:00:00:10:02:fa-01
10:43:46:466 Poll light node Level control switch 22
10:43:46:519 read attributes of 0x00047400001002FA cluster: 0x0006: [ 10:43:46:519 0x0000 10:43:46:519 ]
10:43:46:519 add task 184 type 19 to 0x00047400001002FA cluster 0x0006 req.id 219
10:43:46:519 Poll APS request 219 to 0x00047400001002FA cluster: 0x0006
10:43:46:583 APS-DATA.request id: 219, addrmode: 0x03, addr: 0x00047400001002fa, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0x01 queue: 1 len: 5 tx.options 0x00
10:43:46:815 Node 0x00047400009CD31B is known by 0 neighbors, last seen -1 s
10:43:47:082 enqueue event config/localtime for /config/
10:43:47:294 Node 0x00158D00027538F6 is known by 0 neighbors, last seen -1 s
10:43:47:374 ZDP skip fetch, node 0x47400001002FA has unconfirmed requests [1]
10:43:47:653 Poll APS confirm 219 status: 0xE1
10:43:47:653 drop item attr/modelid
10:43:47:653 drop item attr/swversion
10:43:47:653 0x00047400001002FA error APSDE-DATA.confirm: 0xE1 on task
10:43:47:653 Erase task req-id: 219, type: 19 zcl seqno: 132 send time 1, profileId: 0x0104, clusterId: 0x0006
10:43:47:653 APS-DATA.confirm id: 219, status: 0xE1
10:43:47:653 unhandled APS-DATA.confirm id: 219 status 0xE1
10:43:47:774 Node 0x0004740000AFD73A is known by 0 neighbors, last seen -1 s
10:43:48:082 enqueue event config/localtime for /config/
10:43:48:235 poll node 00:04:74:00:00:83:a0:90-01
10:43:48:235 Poll light node
Depuis phoscon le pilotage des actionneurs semble ok
la date de derniere com vide :
Problème suite à la derniere maj ?
Arrête et relance le démon Deconz. Tu dois avoir un problème de websocket
J’ai tout essayé, reboot, maj, changement de port usb, passage par deconz win
L’ensemble des capteurs ok, mais impossible d’actionner un actionneur
Puis énième je sais pas quoi reboot ou autres voir rien en fait… çà remarche …
Du coup me voilà inquiet
Problemes de connexions, rallonge USB ? pas de port usb 3.0 ? Pas de rajout de SSD ? d’autres clé USB ?
Ça marche avec Phoscon ou pas ?
Si oui avec phoscon et pas avec jeedom > probleme websocket.
Ca deconnait aussi sous windows ?
J’ai essayé en standalone sur un autre pi sans succès
websocket cad ?
En standalone, avec phoscon ?
Si ça ne marche pas non plus, le soucis est surement matériel.
Il te faut faire les tests sans jeedom, jeedom utilse 2 connexions avec deconz, une unidirectionnelle pour envoyer les commandes et une autre en websocket pour recevoir des infos.
Donc deja, on élimine jeedom, pour tester la connexion websocket (même si celle la impacte les capteurs et pas les actionneurs).
Si tu as fais les test sur autre raspberry ou un PC (avec phoscon). Tu avais deconz et phoscon sur la même machine, donc ça peut pas être un probleme réseau.
Dans tes logs (deconz pas jeedom), pas de probleme de déconnexion ou de canal, mais des erreurs de connexions, donc je partirais sur un probleme hardware.
Tu utilises une rallonge USB ? pas de port USB 3.0 ? pas de SSD nouvellement mit en place ?
Fais le test sur PC, tu auras l’interface graphique, plus facile pour voir le maillage ou les logs (deconz/help/log), mais n’oublies pas de faire un baclup/restoration de la base zigbee de la machine jeedom vers le PC (sinon tu pourras faire des tests, mais ton réseau sera vide)
