3692|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3693|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3694|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] decode_slice_header error
3695|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] no frame!
3696|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3697|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3698|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] decode_slice_header error
3699|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] no frame!
3700|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3701|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3702|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] decode_slice_header error
3703|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] no frame!
3704|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3705|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3706|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] decode_slice_header error
3707|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] no frame!
3708|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3709|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3710|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] decode_slice_header error
3711|[9/23/2024, 10:07:04 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] no frame!
3712|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3713|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3714|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] decode_slice_header error
3715|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] no frame!
3716|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3717|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3718|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] decode_slice_header error
3719|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] no frame!
3720|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3721|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3722|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] decode_slice_header error
3723|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] no frame!
3724|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3725|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] non-existing PPS 0 referenced
3726|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] decode_slice_header error
3727|[9/23/2024, 10:07:05 PM] [Camera-ffmpeg] [Foscam C2M] [h264 @ 0x5587966540] [error] no frame!
D’après les logs, il y a des erreurs dans le flux… j’avais une foscam c2 par le passé et j’avais remarqué aussi des erreurs, je suis passé sur une autre marque au final.
je vois aussi un mot de passe qui contient @ essayez d’éviter pour voir si c’est pas mieux.
je vois aussi une erreur dans votre ffmpeg : Unknown encoder 'libfdk_aac' il semblerait que celui-ci ne supporte pas ce codec.
pouvez-vous repasser les logs en debug et puis ouvrir debuginfo. Ensuite me fournir le log « homebridge » qui aura analysé justement la partie ffmpeg.
cet import est sur base du nombre d’image FPS que vous avez renseigné dans le plugin caméra, donc forcément s’il n’est pas bon, il ne sera pas bon non plus dans homebridge. Vérifiez pour chacune des cameras les FPS natifs des flux que vous avez renseigné (on peut le voir probablement dans vlc ou même sur la boite ou l’interface web de la camera ou l’app de celle-ci).
idem pour les résolutions
(en utilisant les memes fps et résolution, vous minimiserez l’impact performance sur votre petit rpi, car il ne faudra pas faire de rééchantionage)
