Calibration module Volet roulant TS130F MOES
Tags: #<Tag:0x00007f752e0fd278>
Je n’arrive pas a trouver le moyen de calibrer le module volet roulant Zigbee 3 MOES « manufacturer »: « _TZ3000_1dd0d5yi », « model »: « TS130F », :
Quand j’essaye de le passer en mode calibration en essayant de lire l’attribut 61441 j’ai un : Erreur attribut 61441 : 134
J’arrive a lire l’attribut 61443 qui est a 100, quand je lui affecte 200, je n’ai pas de message d’erreur, mais il reste a 100…
Quelqu’un a deja reussi a calibrer ce modèle sans passer par le hub tuya ?
Merci d’avance
Tu peux poster le json de ton module?
Les infos pour la calibration se trouve dedans.
le voila :
    "ieee": "84:2e:14:ff:fe:15:d0:36",
    "nwk": 51668,
    "status": 2,
    "lqi": "196",
    "rssi": "-51",
    "last_seen": "1631459134.9073725",
    "node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 515,
            "profile_id": 260,
            "manufacturer": "_TZ3000_1dd0d5yi",
            "model": "TS130F",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 64
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_1dd0d5yi"
                            "id": 5,
                            "name": "model",
                            "value": "TS130F"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 258,
                    "name": "Window Covering",
                    "attributes": [
                            "id": 8,
                            "name": "current_position_lift_percentage",
                            "value": 0
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
    "signature": {
        "model": "TS130F",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 515,
                "input_clusters": [
                    0,
                    4,
                    5,
                    258,
                    6
                    25,
                    10
    "class": "zigpy.device"
Je me sens moins seul ! T’as le même souci que nous ! Il semblerait qu’il y a un souci avec les modules TS130F. J’ai pas encore regardé si le pb était coté jeedom ou zigpy.
De mon coté je suis avec la clé usb popp et le pluggin zigbee, mais le resultat semble le même…
Jimagine que tu as essayé de modifier lattribut de time (id 10)?
C’est le seul que je vois qui puisse agir sur le temps de monter descente.
Je vois pas sur ton json les attributs dont tu parles sur ton premier message
c’est un output, comment je fais pour le modifier ?
Les autres attribut je les ai pris sur le forum, car c’est indiqué pour ce modèle…
My bad j’ai lu trop vite effectivement tu ne peut pas modifier un output
Selon ton json je ne vois pas comment faire pour ta calibrition aucunes info n’est dispo dans ton json donc impossible en l’état.
Dsl
je confirme que la calibration possible avec Deconz Cf. https://community.jeedom.com/t/module-qs-zigbee-c01-ajout-nouvelle-version/66639/8 mais pas possible avec le plugin Zigbee. je précise je fais le test sur le même module.
ok merci, du coup une petite correction du plugin zigbee et ca devrait le faire…
Savez vous si le problème a été remonté a l’équipe du plugin zigbee/jeedom ?
Il y a eu de nombreuses mises à jour depuis l’ajout du module dans sa nouvelle version mais pas cette correction
Suite a échange avec l’équipe jeedom une correction a été faite et le calibrage est maintenant possible (en reglant l’attribut 61443) avec la version beta du pluggin pour l’instant.
problème clos.
Désolé cela ne fonctionne pas.
J’ai bien la version béta et j’ai reçu la maj de ce jour.
