Je viens d’installer la bêta de ce matin (1.1.7) et : j’ai 3 anomalies :
1°) L’image pour mon TH16 n’apparaît pas :
2°) les commandes On, Off, Vitesse 1 2 3 du ventilateur de mon IFan02 ne marche plus.
voici les logs du Ewejee_node :
(node:17664) UnhandledPromiseRejectionWarning: TypeError: Cannot set property 'switches' of undefined
at /var/www/html/plugins/ewejee/core/js/newserver.js:317:43
at /var/www/html/plugins/ewejee/core/js/newserver.js:334:14
at Layer.handle [as handle_request] (/var/www/html/plugins/ewejee/core/js/node_modules/express/lib/router/layer.js:95:5)
at next (/var/www/html/plugins/ewejee/core/js/node_modules/express/lib/router/route.js:137:13)
at Route.dispatch (/var/www/html/plugins/ewejee/core/js/node_modules/express/lib/router/route.js:112:3)
at /var/www/html/plugins/ewejee/core/js/node_modules/express/lib/router/index.js:281:22
at param (/var/www/html/plugins/ewejee/core/js/node_modules/express/lib/router/index.js:354:14)
at param (/var/www/html/plugins/ewejee/core/js/node_modules/express/lib/router/index.js:365:14)
at Function.process_params (/var/www/html/plugins/ewejee/core/js/node_modules/express/lib/router/index.js:410:3)
at next (/var/www/html/plugins/ewejee/core/js/node_modules/express/lib/router/index.js:275:10)
at expressInit (/var/www/html/plugins/ewejee/core/js/node_modules/express/lib/middleware/init.js:40:5)
at trim_prefix (/var/www/html/plugins/ewejee/core/js/node_modules/express/lib/router/index.js:317:13)
at /var/www/html/plugins/ewejee/core/js/node_modules/express/lib/router/index.js:284:7
at Function.process_params (/var/www/html/plugins/ewejee/core/js/node_modules/express/lib/router/index.js:335:12)
at query (/var/www/html/plugins/ewejee/core/js/node_modules/express/lib/middleware/query.js:45:5)
(node:17664) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 3)
3°) Pas changement de statut Online :
Même constant pour tout les devices.
que mes devices soient connecter ou pas, je n’ai pas de changement d"état :
Je suis dispo, si tu as besoin de plus d’info.
Bon courage !
Dji
