Voila ce que ça donne pour cette partie :
2021-06-25 20:40:03][DEBUG] : ================= CRON pour l'actualisation de : Freebox Débits ==================
[2021-06-25 20:40:03][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/connection/(null)
[2021-06-25 20:40:03][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"type":"ethernet","rate_down":18870,"bytes_up":105485076,"ipv4_port_range":[0,16383],"rate_up":2710,"bandwidth_up":700000000,"ipv6":"xxxxxxxxxxxxxxxxxxxx","bandwidth_down":1000000000,"media":"ftth","state":"up","bytes_down":734567806,"ipv4":"xxx.xxx.xxx.xxx"}}
[2021-06-25 20:40:03][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/connection/config(null)
[2021-06-25 20:40:03][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"allow_token_request":true,"adblock":true,"wol":false,"sip_alg":"direct_media","disable_guest":false,"remote_access_min_port":0,"api_domain":"xlmguldv.fbxos.fr","remote_access":true,"is_secure_pass":true,"https_port":xxxxx,"api_remote_access":true,"https_available":true,"remote_access_ip":"xxx.xxx.xxx.xxx","remote_access_port":xxxxx,"ping":false,"remote_access_max_port":xxxxx,"adblock_not_set":false}}
[2021-06-25 20:40:04][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/connection/xdsl(null)
[2021-06-25 20:40:04][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"status":{"status":"down","protocol":"unknown","uptime":0,"modulation":"adsl"},"down":{"es":0,"attn":0,"snr":0,"nitro":false,"attn_10":0,"hec":0,"rxmt_uncorr":0,"ses":0,"maxrate":0,"phyr":false,"rxmt_corr":0,"ginp":false,"snr_10":0,"crc":0,"rate":0,"fec":0,"rxmt":0},"up":{"es":0,"attn":0,"snr":0,"nitro":false,"attn_10":0,"hec":0,"rxmt_uncorr":0,"ses":0,"maxrate":0,"phyr":false,"rxmt_corr":0,"ginp":false,"snr_10":0,"crc":0,"rate":0,"fec":0,"rxmt":0}}}
