@lunarok : Concerne la version beta ( & dépendances réinstallées)
Un oubli dans core/xiaomihome.class.php il manque à la ligne 818
$eqLogic = $this->getEqLogic();
Et des erreurs systématiques « Exception on socket : sequence item 0: expected str instance, int found » sur le demon, pour les eq Yeelight et eq Wifi
Exemple stripe:
[2021-02-04 10:40:38][DEBUG] : execute : action yeelight refresh │
[2021-02-04 10:40:38.540][DEBUG] : Client connected to [127.0.0.1:44312] │
[2021-02-04 10:40:38.542][DEBUG] : Message read from socket: b'{"apikey":"XXXXXXXXX","type":"yeelight","cmd":"refresh","model":"stripe","dest":"192.168.0.143","token":"","devtype":"","serial":"","id":"192.168.0.143│
[2021-02-04 10:40:38.543][DEBUG] : Client disconnected from [127.0.0.1:44312] │
[2021-02-04 10:40:38.618][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE │
[2021-02-04 10:40:38.620][ERROR] : Exception on socket : sequence item 0: expected str instance, int found
Exemple Vacuum:
[2021-02-04 10:38:34][DEBUG] : execute : action wifi refresh │
[2021-02-04 10:38:34.588][DEBUG] : Client connected to [127.0.0.1:43852] │
[2021-02-04 10:38:34.589][DEBUG] : Message read from socket: b'{"apikey":"XXXXXXXXX","type":"wifi","cmd":"refresh","model":"vacuum","dest":"192.168.0.10","token":"5546566c306fxxxx63724274613066","devtype":"046f",│
[2021-02-04 10:38:34.589][DEBUG] : Client disconnected from [127.0.0.1:43852] │
[2021-02-04 10:38:34.680][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE ┤
[2021-02-04 10:38:34.682][ERROR] : Exception on socket : sequence item 0: expected str instance, int found
