log du plugin virtuel en mode debug
[2020-05-03 19:49:02][ERROR] : Erreur sur la fonction cron du plugin : [MySQL] Error code : 42S02 (1146). Table 'jeedom.object' doesn't exist : SELECT `el`.`id`, `el`.`name`, `el`.`logicalId`, `el`.`generic_type`, `el`.`object_id`, `el`.`eqType_name`, `el`.`eqReal_id`, `el`.`isVisible`, `el`.`isEnable`, `el`.`configuration`, `el`.`timeout`, `el`.`category`, `el`.`display`, `el`.`order`, `el`.`comment`, `el`.`tags` FROM eqLogic el LEFT JOIN object ob ON el.object_id=ob.id WHERE eqType_name=:eqType_name AND isEnable=1 ORDER BY ob.name,el.name
[2020-05-03 19:54:02][ERROR] : Erreur sur la fonction cron du plugin : [MySQL] Error code : 42S02 (1146). Table 'jeedom.object' doesn't exist : SELECT `el`.`id`, `el`.`name`, `el`.`logicalId`, `el`.`generic_type`, `el`.`object_id`, `el`.`eqType_name`, `el`.`eqReal_id`, `el`.`isVisible`, `el`.`isEnable`, `el`.`configuration`, `el`.`timeout`, `el`.`category`, `el`.`display`, `el`.`order`, `el`.`comment`, `el`.`tags` FROM eqLogic el LEFT JOIN object ob ON el.object_id=ob.id WHERE eqType_name=:eqType_name AND isEnable=1 ORDER BY ob.name,el.name
[2020-05-03 21:49:02][ERROR] : Erreur sur la fonction cron du plugin : [MySQL] Error code : 42S02 (1146). Table 'jeedom.object' doesn't exist : SELECT `el`.`id`, `el`.`name`, `el`.`logicalId`, `el`.`generic_type`, `el`.`object_id`, `el`.`eqType_name`, `el`.`eqReal_id`, `el`.`isVisible`, `el`.`isEnable`, `el`.`configuration`, `el`.`timeout`, `el`.`category`, `el`.`display`, `el`.`order`, `el`.`comment`, `el`.`tags` FROM eqLogic el LEFT JOIN object ob ON el.object_id=ob.id WHERE eqType_name=:eqType_name AND isEnable=1 ORDER BY ob.name,el.name
[2020-05-13 02:02:53][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=virtual function=pre_update callInstallFunction=1
[2020-05-13 02:02:55][INFO] : Début d'activation du plugin
[2020-05-13 02:02:56][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2020-05-13 02:02:56][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=virtual function=update callInstallFunction=1
[2020-05-16 15:15:27][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=virtual function=pre_update callInstallFunction=1
[2020-05-16 15:15:29][INFO] : Début d'activation du plugin
[2020-05-16 15:15:30][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2020-05-16 15:15:30][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=virtual function=update callInstallFunction=1
[2020-09-27 17:02:03][ERROR] : Erreur sur la fonction cron du plugin : [MySQL] Error code : 42S02 (1146). Table 'jeedom.object' doesn't exist : SELECT `el`.`id`, `el`.`name`, `el`.`logicalId`, `el`.`generic_type`, `el`.`object_id`, `el`.`eqType_name`, `el`.`eqReal_id`, `el`.`isVisible`, `el`.`isEnable`, `el`.`configuration`, `el`.`timeout`, `el`.`category`, `el`.`display`, `el`.`order`, `el`.`comment`, `el`.`tags` FROM eqLogic el LEFT JOIN object ob ON el.object_id=ob.id WHERE eqType_name=:eqType_name AND isEnable=1 ORDER BY ob.name,el.name
[2020-09-27 17:03:02][ERROR] : Erreur sur la fonction cron du plugin : [MySQL] Error code : 42S02 (1146). Table 'jeedom.object' doesn't exist : SELECT `el`.`id`, `el`.`name`, `el`.`logicalId`, `el`.`generic_type`, `el`.`object_id`, `el`.`eqType_name`, `el`.`eqReal_id`, `el`.`isVisible`, `el`.`isEnable`, `el`.`configuration`, `el`.`timeout`, `el`.`category`, `el`.`display`, `el`.`order`, `el`.`comment`, `el`.`tags` FROM eqLogic el LEFT JOIN object ob ON el.object_id=ob.id WHERE eqType_name=:eqType_name AND isEnable=1 ORDER BY ob.name,el.name
C’est celui la qu’il faut?
