Bug inclusion contrôleur RGB
Petit soucis technique lorsque je souhaite re-inclure un contrôleur zigbee RGB via ma clé elelabs.
Voici le « bug »
A
[2023-01-19 21:35:41][DEBUG] : Received trustCenterJoinHandler frame with [0xb98a, a4:c1:38:dc:38:44:db:52, <EmberDeviceUpdate.STANDARD_SECURITY_UNSECURED_JOIN: 1>, <EmberJoinDecision.USE_PRECONFIGURED_KEY: 0>, 0x2884]
[2023-01-19 21:35:41][INFO] : Device 0xb98a (a4:c1:38:dc:38:44:db:52) joined the network
[2023-01-19 21:35:41][DEBUG] : Device a4:c1:38:dc:38:44:db:52 changed id (0x9720 => 0xb98a)
[2023-01-19 21:35:41][INFO] : [a4:c1:38:dc:38:44:db:52][listener.device_joined]
[2023-01-19 21:35:41][INFO] : Send to jeedom :  {'device_joined': 'a4:c1:38:dc:38:44:db:52'}
[2023-01-19 21:35:41][DEBUG] : [0xb98a] Scheduling initialization
[2023-01-19 21:35:41][DEBUG] : [0xb98a] Canceling old initialize call
[2023-01-19 21:35:41][DEBUG] : Send command findKeyTableEntry: (a4:c1:38:dc:38:44:db:52, True)
[2023-01-19 21:35:41][WARNING] : Device failed to initialize due to unexpected error
  File "/usr/local/lib/python3.7/dist-packages/zigpy/device.py", line 177, in initialize
    await self._initialize()
  File "/usr/local/lib/python3.7/dist-packages/zigpy/util.py", line 130, in retry
    r = await func()
  File "/usr/local/lib/python3.7/dist-packages/zigpy/device.py", line 200, in _initialize
    await self.get_node_descriptor()
  File "/usr/local/lib/python3.7/dist-packages/zigpy/device.py", line 162, in get_node_descriptor
    self.nwk, tries=2, delay=0.1
    r = await func()
  File "/usr/local/lib/python3.7/dist-packages/zigpy/device.py", line 300, in request
    use_ieee=use_ieee,
  File "/usr/local/lib/python3.7/dist-packages/bellows/zigbee/application.py", line 825, in request
    res = await asyncio.wait_for(req.result, APS_ACK_TIMEOUT)
  File "/usr/lib/python3.7/asyncio/tasks.py", line 409, in wait_for
    await waiter
concurrent.futures._base.CancelledError
Inclusion incomplète
Avez-vous une idée du problème, perso je pense au module… ?
MAJ Zigbee / Jeedom OK
Oui sauf qu’il est automatiquement détecté en erreur… => Le module est HS test sur une autre installation et même problème :wink:
