Bug avec le plugin MQTT Manager
J’ai fait la dernière mise à jour du plugin MQTT Manager (mqtt2) et il ne veut plus démarrer :
[2022-02-18 15:41:32][INFO] : Start dysond
[2022-02-18 15:41:32][INFO] : Log level on  : debug
[2022-02-18 15:41:32][INFO] : Socket port : 55035
[2022-02-18 15:41:32][INFO] : MQTT : mqtt://xxx:1883
[2022-02-18 15:41:32][INFO] : Username : --password
[2022-02-18 15:41:32][INFO] : Password : --callback
[2022-02-18 15:41:32][INFO] : PID file : /tmp/jeedom/mqtt2/deamon.pid
[2022-02-18 15:41:32][INFO] : Apikey : xxx
[2022-02-18 15:41:32][INFO] : Callback : http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php
[2022-02-18 15:41:32][INFO] : Cycle : 0.3
[2022-02-18 15:41:32][INFO] : Client key : undefined
[2022-02-18 15:41:32][INFO] : Client crt : undefined
[2022-02-18 15:41:32][INFO] : CA : undefined
[2022-02-18 15:41:33][INFO] : Connect to mqtt server
[2022-02-18 15:41:33][DEBUG] : HTTP listen on 127.0.0.1 port : 55035 started
[2022-02-18 15:41:33][INFO] : Connection to mqtt server successfull
[2022-02-18 15:41:33][INFO] : Subscription to all topics
[2022-02-18 15:41:33][INFO] : Subscription to all topics succesfull
[2022-02-18 15:41:33][DEBUG] : Received message on topis : jeedom/status => offline
undefined:1
offline
SyntaxError: Unexpected token o in JSON at position 0
    at JSON.parse (<anonymous>)
    at MqttClient.<anonymous> (/var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js:93:58)
    at MqttClient.emit (events.js:400:28)
    at MqttClient._handlePublish (/var/www/html/plugins/mqtt2/resources/mqtt2d/node_modules/mqtt/lib/client.js:1545:12)
    at MqttClient._handlePacket (/var/www/html/plugins/mqtt2/resources/mqtt2d/node_modules/mqtt/lib/client.js:533:12)
    at work (/var/www/html/plugins/mqtt2/resources/mqtt2d/node_modules/mqtt/lib/client.js:436:12)
    at processTicksAndRejections (internal/process/task_queues.js:77:11)
Même problème pour moi.
Toujours le même bug et le demon NOK avec la dernière mise à jour.
« undefined:1
offline
SyntaxError: Unexpected token o in JSON at position 0 »
Merci d’une correction à venir
Pareil… Bon par contre le plugin est en beta, donc la correction arrivera quand ils pourront :slight_smile:
Le plugin est en cours de révision, la correction sera dans la prochaine beta.
Pour info le plugin risque de passer en stable sans vraiment l’etre c’est juste qu’on a besoin qu’il soit stable pour avancer sur l’installation de ce plugin par d’autre plugin
