Bonjour à tous, quelques temps que je ne m’étais pas penché sur le sujet…
J’ai toujours le même problème.
Voici le log du plugin lors d’un simple clic :
[2021-01-03 10:16:32][DEBUG] : {"00212EFFFF05F8F4":{"id":"3","t":"event","e":"changed","uniqueid":"00:15:8d:00:04:ab:c6:2c-01-0006","r":"sensors","state":{"buttonevent":1000,"lastupdated":"2021-01-03T09:16:32.613"}}}
[2021-01-03 10:16:32][DEBUG] : {"00212EFFFF05F8F4":{"id":"3","t":"event","e":"changed","uniqueid":"00:15:8d:00:04:ab:c6:2c-01-0006","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2021-01-03T09:16:32.799"}}}
[2021-01-03 10:16:36][DEBUG] : {"00212EFFFF05F8F4":{"attr":{"id":"1","lastseen":"2021-01-03T09:16Z","manufacturername":"dresden elektronik","uniqueid":"00:21:2e:ff:ff:05:f8:f4-01","type":"Configuration tool","modelid":"ConBee II","name":"Configuration tool 1"},"id":"1","e":"changed","t":"event","uniqueid":"00:21:2e:ff:ff:05:f8:f4-01","r":"lights"}}
[2021-01-03 10:16:36][DEBUG] : Something received and no value updated, performing sync to create commands if needed
[2021-01-03 10:16:36][DEBUG] : 192.168.0.220:8484/api/EBC4823EAC/sensors type : POST
[2021-01-03 10:16:36][DEBUG] : {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"523f0600d50d87a3a0b0b5b8c84a9184","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":false,"daylight":true,"lastupdated":"2021-01-03T08:12:02.611","status":160,"sunrise":"2021-01-03T07:23:07","sunset":"2021-01-03T16:11:58"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:05:f8:f4-01"},"2":{"config":{"battery":61,"duration":60,"on":true,"pending":[],"reachable":true},"ep":1,"etag":"fec5dc8bca380bc3f7569cef6b3c9ac5","lastseen":"2021-01-03T09:15Z","manufacturername":"eWeLink","modelid":"MS01","name":"Presence 2","state":{"lastupdated":"2021-01-03T09:16:14.711","lowbattery":false,"presence":false,"tampered":false},"swversion":"20191107","type":"ZHAPresence","uniqueid":"00:12:4b:00:22:65:cd:02-01-0500"},"3":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"59590290b1879b3c08837e611ce373b7","lastseen":"2021-01-03T09:16Z","manufacturername":"LUMI","mode":1,"modelid":"lumi.sensor_switch","name":"Smart Switch","state":{"buttonevent":1002,"lastupdated":"2021-01-03T09:16:32.799"},"type":"ZHASwitch","uniqueid":"00:15:8d:00:04:ab:c6:2c-01-0006"},"4":{"config":{"battery":null,"on":true,"reachable":true},"ep":1,"etag":"746d2099d0b36a655ba7626bfa96b20b","lastseen":"2021-01-02T19:22Z","manufacturername":"LUMI","mode":1,"modelid":"lumi.sensor_switch","name":"Smart Switch Bibouche","state":{"buttonevent":1004,"lastupdated":"2021-01-02T19:22:16.552"},"type":"ZHASwitch","uniqueid":"00:15:8d:00:05:43:6c:6d-01-0006"}}
[2021-01-03 10:16:36][DEBUG] : 192.168.0.220:8484/api/EBC4823EAC/lights type : POST
[2021-01-03 10:16:36][DEBUG] : {"1":{"etag":"e398c22101b65cffb7475a737e9026c7","hascolor":false,"lastannounced":null,"lastseen":"2021-01-03T09:16Z","manufacturername":"dresden elektronik","modelid":"ConBee II","name":"Configuration tool 1","state":{"reachable":true},"swversion":null,"type":"Configuration tool","uniqueid":"00:21:2e:ff:ff:05:f8:f4-01"}}
Après le premier appui, autre chose est recu par le plugin mais sans aucun changement. Ce qui suffit pour relancer le scénario et éteindre la lampe du coup …
Est ce que quelqu’un aurait une idée ? …
