@MrGreen Bonjour, ca c’est via l’interface MQTT, Action: ON / Intensité / OFF / ON (le dernier ON se remette à fond)
Debug 2023-10-10 08:03:05Received MQTT message on 'zigbee2mqtt/Inter SàM/set' with data '{"state":"ON"}'
Debug 2023-10-10 08:03:05Publishing 'set' 'state' to 'Inter SàM'
Info 2023-10-10 08:03:05MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":254,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Debug 2023-10-10 08:03:05Received Zigbee message from 'Inter SàM', type 'attributeReport', cluster 'genOnOff', data '{"onOff":1}' from endpoint 3 with groupID null
Info 2023-10-10 08:03:05MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"action":"on","ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":254,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Debug 2023-10-10 08:03:05Received Zigbee message from 'Inter SàM', type 'attributeReport', cluster 'genLevelCtrl', data '{"currentLevel":5}' from endpoint 3 with groupID null
Info 2023-10-10 08:03:05MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":5,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Debug 2023-10-10 08:03:10Received Zigbee message from 'Inter SàM', type 'attributeReport', cluster 'genLevelCtrl', data '{"currentLevel":254}' from endpoint 3 with groupID null
Info 2023-10-10 08:03:10MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":254,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Debug 2023-10-10 08:03:41Received MQTT message on 'zigbee2mqtt/Inter SàM/set' with data '{"brightness":39}'
Debug 2023-10-10 08:03:41Publishing 'set' 'brightness' to 'Inter SàM'
Info 2023-10-10 08:03:41MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":39,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Debug 2023-10-10 08:03:41Received Zigbee message from 'Inter SàM', type 'attributeReport', cluster 'genLevelCtrl', data '{"currentLevel":250}' from endpoint 3 with groupID null
Info 2023-10-10 08:03:41MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":250,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Debug 2023-10-10 08:03:46Received Zigbee message from 'Inter SàM', type 'attributeReport', cluster 'genLevelCtrl', data '{"currentLevel":39}' from endpoint 3 with groupID null
Info 2023-10-10 08:03:46MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":39,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Debug 2023-10-10 08:03:54Received MQTT message on 'zigbee2mqtt/Inter SàM/set' with data '{"state":"OFF"}'
Debug 2023-10-10 08:03:54Publishing 'set' 'state' to 'Inter SàM'
Info 2023-10-10 08:03:54MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":39,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"OFF"}'
Debug 2023-10-10 08:03:54Received Zigbee message from 'Inter SàM', type 'attributeReport', cluster 'genLevelCtrl', data '{"currentLevel":38}' from endpoint 3 with groupID null
Info 2023-10-10 08:03:54MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":38,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"OFF"}'
Debug 2023-10-10 08:03:59Received Zigbee message from 'Inter SàM', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 3 with groupID null
Info 2023-10-10 08:03:59MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"action":"off","ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":38,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"OFF"}'
Debug 2023-10-10 08:03:59Received Zigbee message from 'Inter SàM', type 'attributeReport', cluster 'genLevelCtrl', data '{"currentLevel":1}' from endpoint 3 with groupID null
Info 2023-10-10 08:03:59MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":1,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"OFF"}'
Debug 2023-10-10 08:04:07Received MQTT message on 'zigbee2mqtt/Inter SàM/set' with data '{"state":"ON"}'
Debug 2023-10-10 08:04:07Publishing 'set' 'state' to 'Inter SàM'
Info 2023-10-10 08:04:07MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":254,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Debug 2023-10-10 08:04:07Received Zigbee message from 'Inter SàM', type 'attributeReport', cluster 'genOnOff', data '{"onOff":1}' from endpoint 3 with groupID null
Info 2023-10-10 08:04:07MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"action":"on","ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":254,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Debug 2023-10-10 08:04:08Received Zigbee message from 'Inter SàM', type 'attributeReport', cluster 'genLevelCtrl', data '{"currentLevel":5}' from endpoint 3 with groupID null
Info 2023-10-10 08:04:08MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":5,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Debug 2023-10-10 08:04:12Received Zigbee message from 'Inter SàM', type 'attributeReport', cluster 'genLevelCtrl', data '{"currentLevel":254}' from endpoint 3 with groupID null
Info 2023-10-10 08:04:12MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":254,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'```
> et la en même action via l'interrupteur physique (ON / intensité / OFF / ON)
`Info 2023-10-12 13:27:44MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"action":"on","ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":1,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Info 2023-10-12 13:27:45MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":254,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Info 2023-10-12 13:27:50MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":117,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Info 2023-10-12 13:27:52MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"action":"off","ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":117,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"OFF"}'
Info 2023-10-12 13:27:56MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":254,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"OFF"}'
Info 2023-10-12 13:27:57MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"action":"on","ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":254,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
Info 2023-10-12 13:28:01MQTT publish: topic 'zigbee2mqtt/Inter SàM', payload '{"ballast_lamp_alarm_lamp_burn_hours":false,"ballast_maximum_level":254,"ballast_minimum_level":1,"ballast_status_lamp_failure":false,"ballast_status_non_operational":false,"brightness":254,"device":{"applicationVersion":2,"dateCode":"","friendlyName":"Inter SàM","hardwareVersion":1,"ieeeAddr":"0x0c4314fffe568c04","manufacturerID":4190,"manufacturerName":"Schneider Electric","model":"WDE002334","networkAddress":7823,"powerSource":"Mains (single phase)","softwareBuildID":"002.004.015 R","stackVersion":6,"type":"Router","zclVersion":3},"dimmer_mode":"auto","level_config":{"current_level_startup":"previous","execute_if_off":false,"on_level":254},"linkquality":255,"state":"ON"}'
