bonjour j’ai acheter une box armbian avec debian et jeedom dessus
lors de la connextion sur adresse de jeedom j’ai un message:
Jeedom nécessite l’extension PHP curl . Veuillez faire, en SSH :
sudo su -
apt-get install -y php5-curl
systemctl reload php5-fpm or systemctl reload apache2
je passe en shh et colle le code
root@jeedom3:~# sudo su -
root@jeedom3:~# apt-get install -y php5-curl
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package php5-curl is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'php5-curl' has no installation candidate
root@jeedom3:~# systemctl reload php5-fpm or systemctl reload apache2
Failed to reload php5-fpm.service: Unit php5-fpm.service not found.
Failed to reload or.service: Unit or.service not found.
Failed to reload systemctl.service: Unit systemctl.service not found.
Failed to reload reload.service: Unit reload.service not found.
Warning: The unit file, source configuration file or drop-ins of apache2.service changed on disk. Run 'systemctl daemon-reload' to reload units.
root@jeedom3:~#
root@jeedom3:~# apt install php-curl
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
php-curl : Depends: php7.4-curl but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
c’est pour cela que j’ai deja suggéré de repartir sur du propre…
Et partir pour avoir une prod jeedom avec un OS qui affiche deja ca
ben je préfère réinstaller edbian et jeedom et savoir ou je vais…
La ca sent bien le nid à emmerde aux premières dependances de plugin
Si vous venez de l’acheter neuve, renvoyer la box et envisager d’acheter autre chose même éventuellement
On ne sait pas (en tout cas c’est pas limpide pour moi) quel matériel c’est, ca va être impossible de faire du support la dessus (que le vendeur devrait faire en fait)
