* Installation des dépendances *
Get:2 http://www.deb-multimedia.org stretch InRelease [15.7 kB]
Get:3 http://security.debian.org stretch/updates InRelease [53.0 kB]
Ign:4 http://ftp.debian.org/debian stretch InRelease
Get:5 http://ftp.debian.org/debian stretch-updates InRelease [93.6 kB]
Get:6 http://ftp.debian.org/debian stretch-backports InRelease [91.8 kB]
Get:7 http://ftp.debian.org/debian stretch-proposed-updates InRelease [96.3 kB]
Hit:8 http://ftp.debian.org/debian stretch Release
Hit:9 https://oph.mdrjr.net/meveric all InRelease
Hit:10 https://oph.mdrjr.net/meveric stretch InRelease
Get:11 http://security.debian.org stretch/updates/main Sources [222 kB]
Get:12 http://security.debian.org stretch/updates/main arm64 Packages [519 kB]
Get:13 http://security.debian.org stretch/updates/main Translation-en [237 kB]
Ign:1 https://repo.jeedom.com/odroid stable InRelease
Get:15 https://repo.jeedom.com/odroid stable Release [932 B]
Get:16 https://repo.jeedom.com/odroid stable Release.gpg [659 B]
Fetched 1330 kB in 5s (225 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
libatlas-base-dev is already the newest version (3.10.3-1+b1).
bluetooth is already the newest version (5.43-2+deb9u2).
libbluetooth-dev is already the newest version (5.43-2+deb9u2).
build-essential is already the newest version (12.3).
libffi-dev is already the newest version (3.2.1-6).
libssl-dev is already the newest version (1.1.0l-1~deb9u1).
python3-serial is already the newest version (3.2.1-1).
python3-setuptools is already the newest version (33.1.1-1).
python3-dev is already the newest version (3.5.3-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.12.4-1).
rfkill is already the newest version (0.5-1+b1).
libtiff5 is already the newest version (4.0.8-2+deb9u5).
libopenjp2-7 is already the newest version (2.1.2-1.1+deb9u5).
The following packages were automatically installed and are no longer required:
libmemcached11 libmemcachedutil2 libmysqlclient18 libonig2 libpng12-0
libqdbm14 libvpx1 linux-image-3.14.29+ linux-image-arm64-odroid-c2
python-lockfile u-boot-tools
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 196 not upgraded.
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 196 not upgraded.
Need to get 0 B/142 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 58037 files and directories currently installed.)
Preparing to unpack .../python3-pip_9.0.1-2+deb9u1_all.deb ...
Unpacking python3-pip (9.0.1-2+deb9u1) over (9.0.1-2+deb9u1) ...
Setting up python3-pip (9.0.1-2+deb9u1) ...
Processing triggers for man-db (2.7.6.1-2) ...
Requirement already up-to-date: setuptools in /usr/local/lib/python3.5/dist-packages
git is already the newest version (1:2.11.0-3+deb9u7).
libglib2.0-dev is already the newest version (2.50.3-2+deb9u2).
Requirement already satisfied: pyudev in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from pyudev)
Requirement already satisfied: pyserial in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: requests in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: chardet<4,>=3.0.2 in /usr/local/lib/python3.5/dist-packages (from requests)
Requirement already satisfied: idna<3,>=2.5 in /usr/local/lib/python3.5/dist-packages (from requests)
Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /usr/local/lib/python3.5/dist-packages (from requests)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.5/dist-packages (from requests)
Requirement already satisfied: pybluez in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: pillow in /usr/local/lib/python3.5/dist-packages
Collecting numpy
Using cached https://files.pythonhosted.org/packages/01/1b/d3ddcabd5817be02df0e6ee20d64f77ff6d0d97f83b77f65e98c8a651981/numpy-1.18.5.zip
Building wheels for collected packages: numpy
Running setup.py bdist_wheel for numpy: started
Running setup.py bdist_wheel for numpy: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-dbeysoyt/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpvgcuw711pip-wheel- --python-tag cp35:
Running from numpy source directory.
Cythonizing sources
Processing numpy/random/_bounded_integers.pxd.in
Processing numpy/random/mtrand.pyx
File "/tmp/pip-build-dbeysoyt/numpy/tools/cythonize.py", line 61, in process_pyx
from Cython.Compiler.Version import version as cython_version
ImportError: No module named 'Cython'
During handling of the above exception, another exception occurred:
File "/tmp/pip-build-dbeysoyt/numpy/tools/cythonize.py", line 238, in <module>
main()
File "/tmp/pip-build-dbeysoyt/numpy/tools/cythonize.py", line 234, in main
find_process_files(root_dir)
File "/tmp/pip-build-dbeysoyt/numpy/tools/cythonize.py", line 225, in find_process_files
process(root_dir, fromfile, tofile, function, hash_db)
File "/tmp/pip-build-dbeysoyt/numpy/tools/cythonize.py", line 191, in process
processor_function(fromfile, tofile)
File "/tmp/pip-build-dbeysoyt/numpy/tools/cythonize.py", line 66, in process_pyx
raise OSError('Cython needs to be installed in Python as a module')
OSError: Cython needs to be installed in Python as a module
File "<string>", line 1, in <module>
File "/tmp/pip-build-dbeysoyt/numpy/setup.py", line 488, in <module>
setup_package()
File "/tmp/pip-build-dbeysoyt/numpy/setup.py", line 469, in setup_package
generate_cython()
File "/tmp/pip-build-dbeysoyt/numpy/setup.py", line 275, in generate_cython
raise RuntimeError("Running cythonize failed!")
RuntimeError: Running cythonize failed!
Failed building wheel for numpy
Running setup.py clean for numpy
');f.close();exec(compile(code, __file__, 'exec'))" clean --all:
`setup.py clean` is not supported, use one of the following instead:
- `git clean -xdf` (cleans all files)
- `git clean -Xdf` (cleans all versioned files, doesn't touch
files that aren't checked into the git repo)
Add `--force` to your command to use it anyway if you must (unsupported).
Failed cleaning build dir for numpy
Failed to build numpy
Installing collected packages: numpy
Running setup.py install for numpy: started
Running setup.py install for numpy: finished with status 'error'
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-5qrdn2y1-record/install-record.txt --single-version-externally-managed --compile:
Note: if you need reliable uninstall behavior, then install
with pip instead of using `setup.py install`:
- `pip install .` (from a git repo or downloaded source
release)
- `pip install numpy` (last NumPy release on PyPi)
Cythonizing sources
numpy/random/_bounded_integers.pxd.in has not changed
main()
setup_package()
generate_cython()
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-dbeysoyt/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-5qrdn2y1-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-dbeysoyt/numpy/
Cloning into 'bluepy'...
running build
running build_py
creating build
creating build/lib
creating build/lib/bluepy
copying bluepy/thingy52.py -> build/lib/bluepy
copying bluepy/sensortag.py -> build/lib/bluepy
copying bluepy/scanner.py -> build/lib/bluepy
copying bluepy/scan_fuzz.py -> build/lib/bluepy
copying bluepy/get_services.py -> build/lib/bluepy
copying bluepy/btle.py -> build/lib/bluepy
copying bluepy/blescan.py -> build/lib/bluepy
copying bluepy/__init__.py -> build/lib/bluepy
copying bluepy/uuids.json -> build/lib/bluepy
copying bluepy/bluez-src.tgz -> build/lib/bluepy
copying bluepy/bluepy-helper.c -> build/lib/bluepy
copying bluepy/Makefile -> build/lib/bluepy
running install
Working dir is /tmp/bluepy
execute make -C ./bluepy clean
execute make -C bluepy -j1
running build
running build_py
copying bluepy/bluepy-helper -> build/lib/bluepy
running install_lib
copying build/lib/bluepy/bluepy-helper -> /usr/local/lib/python3.5/dist-packages/bluepy
copying build/lib/bluepy/Makefile -> /usr/local/lib/python3.5/dist-packages/bluepy
copying build/lib/bluepy/bluepy-helper.c -> /usr/local/lib/python3.5/dist-packages/bluepy
copying build/lib/bluepy/bluez-src.tgz -> /usr/local/lib/python3.5/dist-packages/bluepy
copying build/lib/bluepy/uuids.json -> /usr/local/lib/python3.5/dist-packages/bluepy
copying build/lib/bluepy/__init__.py -> /usr/local/lib/python3.5/dist-packages/bluepy
copying build/lib/bluepy/blescan.py -> /usr/local/lib/python3.5/dist-packages/bluepy
copying build/lib/bluepy/btle.py -> /usr/local/lib/python3.5/dist-packages/bluepy
copying build/lib/bluepy/get_services.py -> /usr/local/lib/python3.5/dist-packages/bluepy
copying build/lib/bluepy/scan_fuzz.py -> /usr/local/lib/python3.5/dist-packages/bluepy
copying build/lib/bluepy/scanner.py -> /usr/local/lib/python3.5/dist-packages/bluepy
copying build/lib/bluepy/sensortag.py -> /usr/local/lib/python3.5/dist-packages/bluepy
copying build/lib/bluepy/thingy52.py -> /usr/local/lib/python3.5/dist-packages/bluepy
byte-compiling /usr/local/lib/python3.5/dist-packages/bluepy/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/dist-packages/bluepy/blescan.py to blescan.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/dist-packages/bluepy/btle.py to btle.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/dist-packages/bluepy/get_services.py to get_services.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/dist-packages/bluepy/scan_fuzz.py to scan_fuzz.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/dist-packages/bluepy/scanner.py to scanner.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/dist-packages/bluepy/sensortag.py to sensortag.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/dist-packages/bluepy/thingy52.py to thingy52.cpython-35.pyc
running install_egg_info
running egg_info
creating bluepy.egg-info
writing dependency_links to bluepy.egg-info/dependency_links.txt
writing bluepy.egg-info/PKG-INFO
writing entry points to bluepy.egg-info/entry_points.txt
writing top-level names to bluepy.egg-info/top_level.txt
writing manifest file 'bluepy.egg-info/SOURCES.txt'
reading manifest file 'bluepy.egg-info/SOURCES.txt'
removing '/usr/local/lib/python3.5/dist-packages/bluepy-1.1.4-py3.5.egg-info' (and everything under it)
Copying bluepy.egg-info to /usr/local/lib/python3.5/dist-packages/bluepy-1.1.4-py3.5.egg-info
running install_scripts
Installing sensortag script to /usr/local/bin
Installing blescan script to /usr/local/bin
Installing thingy52 script to /usr/local/bin
Requirement already satisfied: cryptography in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: six>=1.4.1 in /usr/lib/python3/dist-packages (from cryptography)
Requirement already satisfied: cffi!=1.11.3,>=1.8 in /usr/local/lib/python3.5/dist-packages (from cryptography)
Requirement already satisfied: pycparser in /usr/local/lib/python3.5/dist-packages (from cffi!=1.11.3,>=1.8->cryptography)
Requirement already satisfied: pycrypto in /usr/local/lib/python3.5/dist-packages
* Installation terminée *
