Résumé
* Installation des dépendances *
Get:1 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Hit:2 http://deb.debian.org/debian buster InRelease
Get:3 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
Get:5 http://security.debian.org/debian-security buster/updates/main Sources [188 kB]
Get:6 http://security.debian.org/debian-security buster/updates/main amd64 Packages [293 kB]
Fetched 599 kB in 1s (517 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
libffi-dev is already the newest version (3.2.1-9).
libssl-dev is already the newest version (1.1.1d-0+deb10u6).
python3-cryptography is already the newest version (2.6.1-3+deb10u2).
python3-pip is already the newest version (18.1-5).
python3-setuptools is already the newest version (40.8.0-1).
python3-dev is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 57 not upgraded.
/usr/lib/python3/dist-packages/secretstorage/dhcrypto.py:15: CryptographyDeprecationWarning: int_from_bytes is deprecated, use int.from_bytes instead
from cryptography.utils import int_from_bytes
/usr/lib/python3/dist-packages/secretstorage/util.py:19: CryptographyDeprecationWarning: int_from_bytes is deprecated, use int.from_bytes instead
Collecting construct
Using cached construct-2.10.67-py3-none-any.whl
Installing collected packages: construct
Successfully installed construct-2.10.67
WARNING: Running pip as root will break packages and permissions. You should install packages reliably by using venv: https://pip.pypa.io/warnings/venv
Collecting pyudev
Using cached pyudev-0.22.0-py3-none-any.whl
Collecting six
Using cached six-1.16.0-py2.py3-none-any.whl (11 kB)
Installing collected packages: six, pyudev
Successfully installed pyudev-0.22.0 six-1.16.0
Collecting requests
Downloading requests-2.26.0-py2.py3-none-any.whl (62 kB)
Collecting urllib3<1.27,>=1.21.1
Downloading urllib3-1.26.6-py2.py3-none-any.whl (138 kB)
Collecting charset-normalizer~=2.0.0
Downloading charset_normalizer-2.0.2-py3-none-any.whl (35 kB)
Collecting certifi>=2017.4.17
Using cached certifi-2021.5.30-py2.py3-none-any.whl (145 kB)
Collecting idna<4,>=2.5
Downloading idna-3.2-py3-none-any.whl (59 kB)
Installing collected packages: urllib3, idna, charset-normalizer, certifi, requests
Successfully installed certifi-2021.5.30 charset-normalizer-2.0.2 idna-3.2 requests-2.26.0 urllib3-1.26.6
Collecting pyserial
Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
Installing collected packages: pyserial
Successfully installed pyserial-3.5
Collecting future
Using cached future-0.18.2-py3-none-any.whl
Installing collected packages: future
Successfully installed future-0.18.2
Collecting pycrypto
Using cached pycrypto-2.6.1-cp37-cp37m-linux_x86_64.whl
Installing collected packages: pycrypto
Successfully installed pycrypto-2.6.1
Collecting cryptography
Using cached cryptography-3.4.7-cp36-abi3-manylinux2014_x86_64.whl (3.2 MB)
Collecting cffi>=1.12
Downloading cffi-1.14.6-cp37-cp37m-manylinux1_x86_64.whl (402 kB)
Collecting pycparser
Using cached pycparser-2.20-py2.py3-none-any.whl (112 kB)
Installing collected packages: pycparser, cffi, cryptography
Successfully installed cffi-1.14.6 cryptography-3.4.7 pycparser-2.20
Collecting enum34
Using cached enum34-1.1.10-py3-none-any.whl (11 kB)
Installing collected packages: enum34
Successfully installed enum34-1.1.10
Collecting enum-compat
Using cached enum_compat-0.0.3-py3-none-any.whl (1.3 kB)
Installing collected packages: enum-compat
Successfully installed enum-compat-0.0.3
Collecting wheel
Using cached wheel-0.36.2-py2.py3-none-any.whl (35 kB)
Installing collected packages: wheel
Successfully installed wheel-0.36.2
Collecting yeelight
Using cached yeelight-0.6.3-py3-none-any.whl (28 kB)
Collecting ifaddr
Using cached ifaddr-0.1.7-py2.py3-none-any.whl (10 kB)
Collecting future
Installing collected packages: ifaddr, future, yeelight
Successfully installed future-0.18.2 ifaddr-0.1.7 yeelight-0.6.3
Collecting python-miio
Using cached python_miio-0.5.6-py3-none-any.whl (268 kB)
Collecting pytz
Using cached pytz-2021.1-py2.py3-none-any.whl (510 kB)
Collecting netifaces<1,>=0
Using cached netifaces-0.11.0-cp37-cp37m-manylinux_2_5_x86_64.manylinux1_x86_64.whl (32 kB)
Collecting cryptography<4,>=3
Collecting click<8,>=7
Using cached click-7.1.2-py2.py3-none-any.whl (82 kB)
Collecting defusedxml<0.7,>=0.6
Using cached defusedxml-0.6.0-py2.py3-none-any.whl (23 kB)
Collecting construct<3.0.0,>=2.10.56
Collecting importlib_metadata<2,>=1
Using cached importlib_metadata-1.7.0-py2.py3-none-any.whl (31 kB)
Collecting android_backup<1,>=0
Using cached android_backup-0.2.0-py3-none-any.whl
Collecting PyYAML<6,>=5
Using cached PyYAML-5.4.1-cp37-cp37m-manylinux1_x86_64.whl (636 kB)
Collecting tqdm<5,>=4
Downloading tqdm-4.61.2-py2.py3-none-any.whl (76 kB)
Collecting croniter<1,>=0
Using cached croniter-0.3.37-py2.py3-none-any.whl (13 kB)
Collecting zeroconf<1,>=0
Downloading zeroconf-0.32.1-py3-none-any.whl (102 kB)
Collecting appdirs<2,>=1
Using cached appdirs-1.4.4-py2.py3-none-any.whl (9.6 kB)
Collecting attrs
Using cached attrs-21.2.0-py2.py3-none-any.whl (53 kB)
Collecting natsort
Using cached natsort-7.1.1-py3-none-any.whl (35 kB)
Collecting python-dateutil
Downloading python_dateutil-2.8.2-py2.py3-none-any.whl (247 kB)
Using cached cffi-1.14.6-cp37-cp37m-manylinux1_x86_64.whl (402 kB)
Collecting zipp>=0.5
Downloading zipp-3.5.0-py3-none-any.whl (5.7 kB)
Collecting ifaddr>=0.1.7
Collecting six>=1.5
Installing collected packages: six, pycparser, zipp, python-dateutil, natsort, ifaddr, cffi, zeroconf, tqdm, PyYAML, pytz, netifaces, importlib-metadata, defusedxml, cryptography, croniter, construct, click, attrs, appdirs, android-backup, python-miio
Successfully installed PyYAML-5.4.1 android-backup-0.2.0 appdirs-1.4.4 attrs-21.2.0 cffi-1.14.6 click-7.1.2 construct-2.10.67 croniter-0.3.37 cryptography-3.4.7 defusedxml-0.6.0 ifaddr-0.1.7 importlib-metadata-1.7.0 natsort-7.1.1 netifaces-0.11.0 pycparser-2.20 python-dateutil-2.8.2 python-miio-0.5.6 pytz-2021.1 six-1.16.0 tqdm-4.61.2 zeroconf-0.32.1 zipp-3.5.0
ERROR: Invalid requirement: '_thread'
* Installation terminée *
Si je rescanne les yeelights, il me trouve mes yeelights et les nouveaux detectés sont fonctionnels.
Pour l"aspirateur xiaomi, j’ai une croix sur le périphérique
Les commande ne fonctionnent pas
