Aucun nom pour ma Nuki Smart Lock Pro 3
Je n’arrive pas à ajouter ma serrure Nuki Smart Lock Pro 3. Celle-ci est bien découverte par le plugin mais le champ nom est vide. J’ai donc une erreur lorsque j’essaye de l’ajouter.
Ma serrure a bien un nom (« Appartement ») que l’on retrouve dans un des champs name de la configuration mais on voit bien un champs name vide dans cette configuration…
Auriez-vous une idée pour résoudre ce problème ?
Merci pour votre aide.
Voici ma page santé et les logs :
  • Log MQTTDiscovery :
[2024-08-11 18:56:39] INFO  : Arrêt démon
[2024-08-11 18:56:43] INFO  : Lancement démon
[2024-08-11 18:56:44] DEBUG  : test from daemon
[2024-08-11 18:56:45] DEBUG  : new message:{"homeassistant":{"lock":{"nuki_37CCA1EC_lock":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]","mf":"Nuki","name":"Appartement","mdl":"Smart Lock 3.0 Pro"},"name":"","uniq_id":"37CCA1EC_lock","cmd_t":"~\/lockAction","pl_lock":"2","pl_unlk":"1","pl_open":"3","qos":2,"stat_t":"~\/state","stat_locked":"1","stat_locking":"4","stat_unlocked":"3","stat_unlocking":"2","stat_open":"5","stat_opening":"7","stat_jam":"254","val_tpl":"{% if value == \"6\" %}3{% else %}{{value}}{% endif %}"}}},"binary_sensor":{"nuki_37CCA1EC_lock_battery_critical":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Battery critical","uniq_id":"37CCA1EC_lock_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryCritical","pl_off":"false","pl_on":"true"}},"nuki_37CCA1EC_battery_charging":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Battery charging","uniq_id":"37CCA1EC_battery_charging","dev_cla":"battery_charging","ent_cat":"diagnostic","stat_t":"~\/batteryCharging","pl_off":"false","pl_on":"true"}},"nuki_37CCA1EC_door_sensor":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Door sensor","uniq_id":"37CCA1EC_door_sensor","dev_cla":"door","stat_t":"~\/doorsensorState","pl_off":"2","pl_on":"3"}},"nuki_37CCA1EC_door_sensor_battery_critical":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Door sensor battery critical","uniq_id":"37CCA1EC_door_sensor_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/doorsensorBatteryCritical","pl_off":"false","pl_on":"true"}}},"sensor":{"nuki_37CCA1EC_battery_percent":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Battery","uniq_id":"37CCA1EC_lock_battery_percent","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryChargeState","stat_cla":"measurement","unit_of_meas":"%"}}},"button":{"nuki_37CCA1EC_unlatch_button":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Unlatch","uniq_id":"37CCA1EC_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"3","qos":2}},"nuki_37CCA1EC_lockngo_button":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Lock 'n' Go","uniq_id":"37CCA1EC_lock_n_go_button","cmd_t":"~\/lockAction","pl_prs":"4","qos":2}},"nuki_37CCA1EC_lock_n_go_unlatch":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Lock 'n' Go with unlatch","uniq_id":"37CCA1EC_lock_n_go_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"5","qos":2}}}},"nuki":{"37CCA1EC":{"connected":true,"state":1,"timestamp":"2024-08-11T16:54:15Z","doorsensorState":2}}}
[2024-08-11 18:56:45] DEBUG  : ==> type='lock' - content= {"nuki_37CCA1EC_lock":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]","mf":"Nuki","name":"Appartement","mdl":"Smart Lock 3.0 Pro"},"name":"","uniq_id":"37CCA1EC_lock","cmd_t":"~\/lockAction","pl_lock":"2","pl_unlk":"1","pl_open":"3","qos":2,"stat_t":"~\/state","stat_locked":"1","stat_locking":"4","stat_unlocked":"3","stat_unlocking":"2","stat_open":"5","stat_opening":"7","stat_jam":"254","val_tpl":"{% if value == \"6\" %}3{% else %}{{value}}{% endif %}"}}}
[2024-08-11 18:56:45] DEBUG  : handle config: {"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]","mf":"Nuki","name":"Appartement","mdl":"Smart Lock 3.0 Pro"},"name":"","uniq_id":"37CCA1EC_lock","cmd_t":"~\/lockAction","pl_lock":"2","pl_unlk":"1","pl_open":"3","qos":2,"stat_t":"~\/state","stat_locked":"1","stat_locking":"4","stat_unlocked":"3","stat_unlocking":"2","stat_open":"5","stat_opening":"7","stat_jam":"254","val_tpl":"{% if value == \"6\" %}3{% else %}{{value}}{% endif %}"}
[2024-08-11 18:56:45] DEBUG  : ==> type='binary_sensor' - content= {"nuki_37CCA1EC_lock_battery_critical":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Battery critical","uniq_id":"37CCA1EC_lock_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryCritical","pl_off":"false","pl_on":"true"}},"nuki_37CCA1EC_battery_charging":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Battery charging","uniq_id":"37CCA1EC_battery_charging","dev_cla":"battery_charging","ent_cat":"diagnostic","stat_t":"~\/batteryCharging","pl_off":"false","pl_on":"true"}},"nuki_37CCA1EC_door_sensor":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Door sensor","uniq_id":"37CCA1EC_door_sensor","dev_cla":"door","stat_t":"~\/doorsensorState","pl_off":"2","pl_on":"3"}},"nuki_37CCA1EC_door_sensor_battery_critical":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Door sensor battery critical","uniq_id":"37CCA1EC_door_sensor_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/doorsensorBatteryCritical","pl_off":"false","pl_on":"true"}}}
[2024-08-11 18:56:45] DEBUG  : handle config: {"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Battery critical","uniq_id":"37CCA1EC_lock_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryCritical","pl_off":"false","pl_on":"true"}
[2024-08-11 18:56:45] DEBUG  : handle config: {"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Battery charging","uniq_id":"37CCA1EC_battery_charging","dev_cla":"battery_charging","ent_cat":"diagnostic","stat_t":"~\/batteryCharging","pl_off":"false","pl_on":"true"}
[2024-08-11 18:56:45] DEBUG  : handle config: {"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Door sensor","uniq_id":"37CCA1EC_door_sensor","dev_cla":"door","stat_t":"~\/doorsensorState","pl_off":"2","pl_on":"3"}
[2024-08-11 18:56:45] DEBUG  : handle config: {"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Door sensor battery critical","uniq_id":"37CCA1EC_door_sensor_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/doorsensorBatteryCritical","pl_off":"false","pl_on":"true"}
[2024-08-11 18:56:45] DEBUG  : ==> type='sensor' - content= {"nuki_37CCA1EC_battery_percent":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Battery","uniq_id":"37CCA1EC_lock_battery_percent","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryChargeState","stat_cla":"measurement","unit_of_meas":"%"}}}
[2024-08-11 18:56:45] DEBUG  : handle config: {"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Battery","uniq_id":"37CCA1EC_lock_battery_percent","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~\/batteryChargeState","stat_cla":"measurement","unit_of_meas":"%"}
[2024-08-11 18:56:45] DEBUG  : ==> type='button' - content= {"nuki_37CCA1EC_unlatch_button":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Unlatch","uniq_id":"37CCA1EC_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"3","qos":2}},"nuki_37CCA1EC_lockngo_button":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Lock 'n' Go","uniq_id":"37CCA1EC_lock_n_go_button","cmd_t":"~\/lockAction","pl_prs":"4","qos":2}},"nuki_37CCA1EC_lock_n_go_unlatch":{"config":{"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Lock 'n' Go with unlatch","uniq_id":"37CCA1EC_lock_n_go_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"5","qos":2}}}
[2024-08-11 18:56:45] DEBUG  : handle config: {"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Unlatch","uniq_id":"37CCA1EC_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"3","qos":2}
[2024-08-11 18:56:45] DEBUG  : handle config: {"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Lock 'n' Go","uniq_id":"37CCA1EC_lock_n_go_button","cmd_t":"~\/lockAction","pl_prs":"4","qos":2}
[2024-08-11 18:56:45] DEBUG  : handle config: {"~":"nuki\/37CCA1EC","avty_t":"~\/connected","pl_avail":"true","pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Lock 'n' Go with unlatch","uniq_id":"37CCA1EC_lock_n_go_unlatch_button","cmd_t":"~\/lockAction","pl_prs":"5","qos":2}
[2024-08-11 18:56:45] INFO  : Nouvelle découverte, résumé des configuations:
[2024-08-11 18:56:45] INFO  : - Importées:                 0
[2024-08-11 18:56:45] INFO  : - Auto-création inactive:    9
[2024-08-11 18:56:45] INFO  : - Topic ignoré:              0
[2024-08-11 18:56:45] INFO  : - Erronées:                  0
[2024-08-11 18:56:45] INFO  : - Non supportées:            0
[2024-08-11 18:56:45] INFO  : - Total reçues:              9
  • Log MQTTDiscovery_daemon :
[2024-08-11 18:56:44] INFO  : Starting daemon with log level: debug
[2024-08-11 18:56:44] DEBUG  : Writing PID 25409 to /tmp/jeedom/MQTTDiscovery/daemon.pid
[2024-08-11 18:56:44] INFO  : Listening on 127.0.0.1:55074
[2024-08-11 18:56:44] DEBUG  : Connecting to mqtt at 127.0.0.1:1883
[2024-08-11 18:56:44] INFO  : Send async started with a cycle of 1.0s
[2024-08-11 18:56:44] INFO  : Successfully connected to MQTT server
[2024-08-11 18:56:44] INFO  : Successfully subscribed to discovery topic homeassistant
[2024-08-11 18:56:44] INFO  : Successfully subscribed to home
[2024-08-11 18:56:44] INFO  : Successfully subscribed to nuki
[2024-08-11 18:56:44] DEBUG  : message received on topic 'homeassistant/lock/nuki_37CCA1EC_lock/config': b'{"~":"nuki/37CCA1EC","avty_t":"~/connected","pl_avail":"true", "pl_not_avail":"false","dev":{"ids":"[37CCA1EC]","mf":"Nuki","name":"Appartement","mdl":"Smart Lock 3.0 Pro"},"name":"","uniq_id":"37CCA1EC_lock","cmd_t":"~/lockAction","pl_lock":"2","pl_unlk":"1","pl_open":"3","qos":2,"stat_t":"~/state","stat_locked":"1","stat_locking":"4","stat_unlocked":"3","stat_unlocking":"2","stat_open":"5","stat_opening":"7","stat_jam":"254","val_tpl":"{% if value == \\"6\\" %}3{% else %}{{value}}{% endif %}"}'
[2024-08-11 18:56:44] DEBUG  : message received on topic 'homeassistant/binary_sensor/nuki_37CCA1EC_lock_battery_critical/config': b'{"~":"nuki/37CCA1EC","avty_t":"~/connected","pl_avail":"true", "pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Battery critical","uniq_id":"37CCA1EC_lock_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~/batteryCritical","pl_off":"false","pl_on":"true"}'
[2024-08-11 18:56:44] DEBUG  : message received on topic 'homeassistant/binary_sensor/nuki_37CCA1EC_battery_charging/config': b'{"~":"nuki/37CCA1EC","avty_t":"~/connected","pl_avail":"true", "pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Battery charging","uniq_id":"37CCA1EC_battery_charging","dev_cla":"battery_charging","ent_cat":"diagnostic","stat_t":"~/batteryCharging","pl_off":"false","pl_on":"true"}'
[2024-08-11 18:56:44] DEBUG  : message received on topic 'homeassistant/binary_sensor/nuki_37CCA1EC_door_sensor/config': b'{"~":"nuki/37CCA1EC","avty_t":"~/connected","pl_avail":"true", "pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Door sensor","uniq_id":"37CCA1EC_door_sensor","dev_cla":"door","stat_t":"~/doorsensorState","pl_off":"2","pl_on":"3"}'
[2024-08-11 18:56:44] DEBUG  : message received on topic 'homeassistant/binary_sensor/nuki_37CCA1EC_door_sensor_battery_critical/config': b'{"~":"nuki/37CCA1EC","avty_t":"~/connected","pl_avail":"true", "pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Door sensor battery critical","uniq_id":"37CCA1EC_door_sensor_battery_critical","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~/doorsensorBatteryCritical","pl_off":"false","pl_on":"true"}'
[2024-08-11 18:56:44] DEBUG  : message received on topic 'homeassistant/sensor/nuki_37CCA1EC_battery_percent/config': b'{"~":"nuki/37CCA1EC","avty_t":"~/connected","pl_avail":"true", "pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Battery","uniq_id":"37CCA1EC_lock_battery_percent","dev_cla":"battery","ent_cat":"diagnostic","stat_t":"~/batteryChargeState","stat_cla":"measurement","unit_of_meas":"%"}'
[2024-08-11 18:56:44] DEBUG  : message received on topic 'homeassistant/button/nuki_37CCA1EC_unlatch_button/config': b'{"~":"nuki/37CCA1EC","avty_t":"~/connected","pl_avail":"true", "pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Unlatch","uniq_id":"37CCA1EC_unlatch_button","cmd_t":"~/lockAction","pl_prs":"3","qos":2}'
[2024-08-11 18:56:44] DEBUG  : message received on topic 'homeassistant/button/nuki_37CCA1EC_lockngo_button/config': b'{"~":"nuki/37CCA1EC","avty_t":"~/connected","pl_avail":"true", "pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Lock \'n\' Go","uniq_id":"37CCA1EC_lock_n_go_button","cmd_t":"~/lockAction","pl_prs":"4","qos":2}'
[2024-08-11 18:56:44] DEBUG  : message received on topic 'homeassistant/button/nuki_37CCA1EC_lock_n_go_unlatch/config': b'{"~":"nuki/37CCA1EC","avty_t":"~/connected","pl_avail":"true", "pl_not_avail":"false","dev":{"ids":"[37CCA1EC]"},"name":"Lock \'n\' Go with unlatch","uniq_id":"37CCA1EC_lock_n_go_unlatch_button","cmd_t":"~/lockAction","pl_prs":"5","qos":2}'
[2024-08-11 18:56:44] DEBUG  : message received on topic 'nuki/37CCA1EC/connected': b'true'
[2024-08-11 18:56:44] DEBUG  : message received on topic 'nuki/37CCA1EC/state': b'1'
[2024-08-11 18:56:44] DEBUG  : message received on topic 'nuki/37CCA1EC/timestamp': b'2024-08-11T16:54:15Z'
[2024-08-11 18:56:44] DEBUG  : message received on topic 'nuki/37CCA1EC/doorsensorState': b'2'
[2024-08-11 18:56:45] DEBUG  : Send to jeedom: {'homeassistant': {'lock': {'nuki_37CCA1EC_lock': {'config': {'~': 'nuki/37CCA1EC', 'avty_t': '~/connected', 'pl_avail': 'true', 'pl_not_avail': 'false', 'dev': {'ids': '[37CCA1EC]', 'mf': 'Nuki', 'name': 'Appartement', 'mdl': 'Smart Lock 3.0 Pro'}, 'name': '', 'uniq_id': '37CCA1EC_lock', 'cmd_t': '~/lockAction', 'pl_lock': '2', 'pl_unlk': '1', 'pl_open': '3', 'qos': 2, 'stat_t': '~/state', 'stat_locked': '1', 'stat_locking': '4', 'stat_unlocked': '3', 'stat_unlocking': '2', 'stat_open': '5', 'stat_opening': '7', 'stat_jam': '254', 'val_tpl': '{% if value == "6" %}3{% else %}{{value}}{% endif %}'}}}, 'binary_sensor': {'nuki_37CCA1EC_lock_battery_critical': {'config': {'~': 'nuki/37CCA1EC', 'avty_t': '~/connected', 'pl_avail': 'true', 'pl_not_avail': 'false', 'dev': {'ids': '[37CCA1EC]'}, 'name': 'Battery critical', 'uniq_id': '37CCA1EC_lock_battery_critical', 'dev_cla': 'battery', 'ent_cat': 'diagnostic', 'stat_t': '~/batteryCritical', 'pl_off': 'false', 'pl_on': 'true'}}, 'nuki_37CCA1EC_battery_charging': {'config': {'~': 'nuki/37CCA1EC', 'avty_t': '~/connected', 'pl_avail': 'true', 'pl_not_avail': 'false', 'dev': {'ids': '[37CCA1EC]'}, 'name': 'Battery charging', 'uniq_id': '37CCA1EC_battery_charging', 'dev_cla': 'battery_charging', 'ent_cat': 'diagnostic', 'stat_t': '~/batteryCharging', 'pl_off': 'false', 'pl_on': 'true'}}, 'nuki_37CCA1EC_door_sensor': {'config': {'~': 'nuki/37CCA1EC', 'avty_t': '~/connected', 'pl_avail': 'true', 'pl_not_avail': 'false', 'dev': {'ids': '[37CCA1EC]'}, 'name': 'Door sensor', 'uniq_id': '37CCA1EC_door_sensor', 'dev_cla': 'door', 'stat_t': '~/doorsensorState', 'pl_off': '2', 'pl_on': '3'}}, 'nuki_37CCA1EC_door_sensor_battery_critical': {'config': {'~': 'nuki/37CCA1EC', 'avty_t': '~/connected', 'pl_avail': 'true', 'pl_not_avail': 'false', 'dev': {'ids': '[37CCA1EC]'}, 'name': 'Door sensor battery critical', 'uniq_id': '37CCA1EC_door_sensor_battery_critical', 'dev_cla': 'battery', 'ent_cat': 'diagnostic', 'stat_t': '~/doorsensorBatteryCritical', 'pl_off': 'false', 'pl_on': 'true'}}}, 'sensor': {'nuki_37CCA1EC_battery_percent': {'config': {'~': 'nuki/37CCA1EC', 'avty_t': '~/connected', 'pl_avail': 'true', 'pl_not_avail': 'false', 'dev': {'ids': '[37CCA1EC]'}, 'name': 'Battery', 'uniq_id': '37CCA1EC_lock_battery_percent', 'dev_cla': 'battery', 'ent_cat': 'diagnostic', 'stat_t': '~/batteryChargeState', 'stat_cla': 'measurement', 'unit_of_meas': '%'}}}, 'button': {'nuki_37CCA1EC_unlatch_button': {'config': {'~': 'nuki/37CCA1EC', 'avty_t': '~/connected', 'pl_avail': 'true', 'pl_not_avail': 'false', 'dev': {'ids': '[37CCA1EC]'}, 'name': 'Unlatch', 'uniq_id': '37CCA1EC_unlatch_button', 'cmd_t': '~/lockAction', 'pl_prs': '3', 'qos': 2}}, 'nuki_37CCA1EC_lockngo_button': {'config': {'~': 'nuki/37CCA1EC', 'avty_t': '~/connected', 'pl_avail': 'true', 'pl_not_avail': 'false', 'dev': {'ids': '[37CCA1EC]'}, 'name': "Lock 'n' Go", 'uniq_id': '37CCA1EC_lock_n_go_button', 'cmd_t': '~/lockAction', 'pl_prs': '4', 'qos': 2}}, 'nuki_37CCA1EC_lock_n_go_unlatch': {'config': {'~': 'nuki/37CCA1EC', 'avty_t': '~/connected', 'pl_avail': 'true', 'pl_not_avail': 'false', 'dev': {'ids': '[37CCA1EC]'}, 'name': "Lock 'n' Go with unlatch", 'uniq_id': '37CCA1EC_lock_n_go_unlatch_button', 'cmd_t': '~/lockAction', 'pl_prs': '5', 'qos': 2}}}}, 'nuki': {'37CCA1EC': {'connected': True, 'state': 1, 'timestamp': '2024-08-11T16:54:15Z', 'doorsensorState': 2}}}
Informations Jeedom
Core : 4.4.9 (V4-stable)
DNS Jeedom : non
Il faudrait la page santé de Jeedom ainsi que les logs comme demandé dans la documentation.
Là avec juste un constat on ne pourra rien déterminer niveau souci
Luis
En effet désolé pour cet oubli… Je viens de les rajouter dans mon premier post.
Je regarde demain matin.
En fait je ne comprend pas pq il n’y a pas de nom.
le problème n’est pas le champ « name » vide, pour celui-là il y a un fallback sur uniqueid car effectivement c’est optionnel
le problème est sur le nom du device, dans la config il n’est pas repris sur la plupart des entités (ce qui n’est pas logique) mais sur le lock on le voit bien donc ca devrait être bon
Je pensais aussi avoir déjà vu cette erreur par le passé (sur community) et que la personne avait juste redémarré sa serrure pour le régler mais je ne retrouve pas;
à la base ca semble être un petit glitch coté nuki, il devrait publié le nom du device sur chaque entité et pas uniquement sur lock
je pourrais voir le log http.error au moment d’un démarrage du démon? je voudrais voir s’il y a un warning sur un index non trouvé.
Sinon faut essayer avec la version beta demain, j’ai modifié pour protéger le cas où le device name n’est pas renseigné; à tester si ca suffit (le nom devrait apparaitre dans la liste des devices trouvés)
En redémarrant la serrure le problème était toujours là. Par contre ça a l’air de fonctionner avec la version beta j’ai pu ajouter ma serrure le nom était bien rempli merci !
J’arrive bien à lancer des actions mais à priori aucune info ne semble remonter (daterie, door sensor…). Il faut peut-être attendre des changements d’état ?
