Hello, la team ce matin impossible de démarrer ma VM freebow delta.
Le fichier bloque au démarrage. ca vous ai deja arrivé ?
J’ai essayé le recovery mode mais pas mieux
je met le code de la console au cas ou ca vous parle…
Loading Linux 4.19.0-8-arm64 ...
Loading initial ramdisk ...
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services and installing virtual address map...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd081]
[ 0.000000] Linux version 4.19.0-8-arm64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.98-1 (2020-01-26)
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: SMBIOS 3.0=0x7b5c0000 MEMATTR=0x78fad698 ACPI 2.0=0x77f00000 RNG=0x7b67d298
[ 0.000000] efi: seeding entropy pool
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] cma: Reserved 64 MiB at 0x0000000073c00000
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x0000000077F00000 000024 (v02 BOCHS )
[ 0.000000] ACPI: XSDT 0x0000000077EF0000 000054 (v01 BOCHS BXPCFACP 00000001 01000013)
[ 0.000000] ACPI: FACP 0x0000000077EB0000 00010C (v05 BOCHS BXPCFACP 00000001 BXPC 00000001)
[ 0.000000] ACPI: DSDT 0x0000000077EC0000 004848 (v02 BOCHS BXPCDSDT 00000001 BXPC 00000001)
[ 0.000000] ACPI: APIC 0x0000000077EA0000 0000F4 (v03 BOCHS BXPCAPIC 00000001 BXPC 00000001)
[ 0.000000] ACPI: GTDT 0x0000000077E90000 000060 (v02 BOCHS BXPCGTDT 00000001 BXPC 00000001)
[ 0.000000] ACPI: MCFG 0x0000000077E80000 00003C (v01 BOCHS BXPCMCFG 00000001 BXPC 00000001)
[ 0.000000] ACPI: SPCR 0x0000000077E70000 000050 (v02 BOCHS BXPCSPCR 00000001 BXPC 00000001)
[ 0.000000] ACPI: IORT 0x0000000077E60000 00007C (v00 BOCHS BXPCIORT 00000001 BXPC 00000001)
[ 0.000000] ACPI: SPCR: console: pl011,mmio,0x9000000,9600
[ 0.000000] ACPI: NUMA: Failed to initialise from firmware
[ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000007bcfffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x7bced840-0x7bceefff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x000000007bcfffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000077f0ffff]
[ 0.000000] node 0: [mem 0x0000000077f10000-0x00000000781dffff]
[ 0.000000] node 0: [mem 0x00000000781e0000-0x000000007b4bffff]
[ 0.000000] node 0: [mem 0x000000007b4c0000-0x000000007b54ffff]
[ 0.000000] node 0: [mem 0x000000007b550000-0x000000007b55ffff]
[ 0.000000] node 0: [mem 0x000000007b560000-0x000000007b67ffff]
[ 0.000000] node 0: [mem 0x000000007b680000-0x000000007bcfffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007bcfffff]
[ 0.000000] psci: probing for conduit method from ACPI.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] ACPI: SRAT not present
[ 0.000000] random: get_random_bytes called from start_kernel+0x9c/0x4bc with crng_init=0
[ 0.000000] percpu: Embedded 25 pages/cpu s61912 r8192 d32296 u102400
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[ 0.000000] CPU features: enabling workaround for EL2 vector hardening
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 241164
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-8-arm64 root=UUID=5bca12bc-64aa-494d-b443-f4d493b395cd ro biosdevname=0 net.ifnames=0 console=tty0 console=ttyAMA0,115200 earlyprintk=ttyAMA0,115200 consoleblank=0 systemd.show_status=true
[ 0.000000] Memory: 848052K/979968K available (8828K kernel code, 1614K rwdata, 2808K rodata, 4928K init, 529K bss, 66380K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] ftrace: allocating 33199 entries in 130 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv2m: ACPI overriding V2M MSI_TYPER (base:80, num:64)
[ 0.000000] GICv2m: range[mem 0x08020000-0x08020fff], SPI[80:143]
[ 0.000000] arch_timer: cp15 timer(s) running at 25.00MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x5c40939b5, max_idle_ns: 440795202646 ns
[ 0.000001] sched_clock: 56 bits at 25MHz, resolution 40ns, wraps every 4398046511100ns
[ 0.000049] Console: colour dummy device 80x25
[ 0.000219] console [tty0] enabled
[ 0.000255] ACPI: Core revision 20180810
[ 0.000353] Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000)
[ 0.000361] pid_max: default: 32768 minimum: 301
[ 0.000405] Security Framework initialized
[ 0.000410] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.000441] AppArmor: AppArmor initialized
[ 0.000661] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000773] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000796] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.000804] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.001248] ACPI PPTT: No PPTT table found, cpu topology may be inaccurate
[ 0.001416] ASID allocator initialised with 32768 entries
[ 0.001460] rcu: Hierarchical SRCU implementation.
[ 0.001996] Remapping and enabling EFI services.
[ 0.002276] smp: Bringing up secondary CPUs ...
[ 0.028691] Detected PIPT I-cache on CPU1
[ 0.028805] CPU1: Booted secondary processor 0x0000000001 [0x410fd081]
[ 0.028923] smp: Brought up 1 node, 2 CPUs
[ 0.028939] SMP: Total of 2 processors activated.
[ 0.028945] CPU features: detected: 32-bit EL0 Support
[ 0.032319] CPU: All CPU(s) started at EL1
[ 0.032349] alternatives: patching kernel code
[ 0.032985] devtmpfs: initialized
[ 0.033306] Registered cp15_barrier emulation handler
[ 0.033320] Registered setend emulation handler
[ 0.033406] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.033422] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.034027] pinctrl core: initialized pinctrl subsystem
[ 0.034294] SMBIOS 3.0.0 present.
[ 0.034304] DMI: QEMU KVM Virtual Machine, BIOS 0.0.0 02/06/2015
[ 0.034442] NET: Registered protocol family 16
[ 0.034597] audit: initializing netlink subsys (disabled)
[ 0.034707] audit: type=2000 audit(0.032:1): state=initialized audit_enabled=0 res=1
[ 0.034920] cpuidle: using governor ladder
[ 0.034933] cpuidle: using governor menu
[ 0.035027] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[ 0.035035] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.036047] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.036145] ACPI: bus type PCI registered
[ 0.036152] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.036199] Serial: AMBA PL011 UART driver
[ 0.037921] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.038441] ACPI: Added _OSI(Module Device)
[ 0.038447] ACPI: Added _OSI(Processor Device)
[ 0.038452] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.038456] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.038461] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.038465] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.050584] ACPI: 1 ACPI AML tables successfully acquired and loaded
[ 0.051657] ACPI: Interpreter enabled
[ 0.051664] ACPI: Using GIC for interrupt routing
[ 0.051691] ACPI: MCFG table detected, 1 entries
[ 0.055230] ARMH0011:00: ttyAMA0 at MMIO 0x9000000 (irq = 4, base_baud = 0) is a SBSA
[ 0.363827] console [ttyAMA0] enabled
[ 0.367510] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.370546] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.374218] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR]
[ 0.377603] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.381511] acpi PNP0A08:00: ECAM area [mem 0x4010000000-0x401fffffff] reserved by PNP0C02:00
[ 0.385269] acpi PNP0A08:00: ECAM at [mem 0x4010000000-0x401fffffff] for [bus 00-ff]
[ 0.388777] Remapped I/O 0x000000003eff0000 to [io 0x0000-0xffff window]
[ 0.391933] PCI host bridge to bus 0000:00
[ 0.393824] pci_bus 0000:00: root bus resource [mem 0x10000000-0x3efeffff window]
[ 0.397045] pci_bus 0000:00: root bus resource [io 0x0000-0xffff window]
[ 0.399991] pci_bus 0000:00: root bus resource [mem 0x8000000000-0xffffffffff window]
[ 0.403242] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.420677] pci 0000:00:01.0: BAR 4: assigned [mem 0x8000000000-0x8000003fff 64bit pref]
[ 0.424493] pci 0000:00:02.0: BAR 4: assigned [mem 0x8000004000-0x8000007fff 64bit pref]
[ 0.428065] pci 0000:00:03.0: BAR 4: assigned [mem 0x8000008000-0x800000bfff 64bit pref]
[ 0.431828] pci 0000:00:04.0: BAR 4: assigned [mem 0x800000c000-0x800000ffff 64bit pref]
[ 0.435012] pci 0000:00:05.0: BAR 4: assigned [mem 0x8000010000-0x8000013fff 64bit pref]
[ 0.438497] pci 0000:00:06.0: BAR 0: assigned [mem 0x8000014000-0x8000017fff 64bit]
[ 0.441661] pci 0000:00:01.0: BAR 1: assigned [mem 0x10000000-0x10000fff]
[ 0.444628] pci 0000:00:02.0: BAR 1: assigned [mem 0x10001000-0x10001fff]
[ 0.447472] pci 0000:00:03.0: BAR 1: assigned [mem 0x10002000-0x10002fff]
[ 0.450501] pci 0000:00:01.0: BAR 0: assigned [io 0x1000-0x107f]
[ 0.453598] pci 0000:00:02.0: BAR 0: assigned [io 0x1080-0x10bf]
[ 0.456783] pci 0000:00:03.0: BAR 0: assigned [io 0x10c0-0x10df]
[ 0.459953] pci 0000:00:04.0: BAR 0: assigned [io 0x10e0-0x10ff]
[ 0.463249] pci 0000:00:05.0: BAR 0: assigned [io 0x1100-0x111f]
[ 0.466363] ACPI: PCI Interrupt Link [GSI0] (IRQs *35)
[ 0.468714] ACPI: PCI Interrupt Link [GSI1] (IRQs *36)
[ 0.470907] ACPI: PCI Interrupt Link [GSI2] (IRQs *37)
[ 0.473175] ACPI: PCI Interrupt Link [GSI3] (IRQs *38)
[ 0.476077] vgaarb: loaded
[ 0.477439] pps_core: LinuxPPS API ver. 1 registered
[ 0.479643] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.483719] PTP clock support registered
[ 0.485428] EDAC MC: Ver: 3.0.0
[ 0.487144] Registered efivars operations
[ 0.489708] clocksource: Switched to clocksource arch_sys_counter
[ 0.511967] VFS: Disk quotas dquot_6.6.0
[ 0.513750] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.517036] AppArmor: AppArmor Filesystem Enabled
[ 0.519355] pnp: PnP ACPI init
[ 0.521224] system 00:00: [mem 0x4010000000-0x401fffffff window] could not be reserved
[ 0.524866] pnp: PnP ACPI: found 1 devices
[ 0.530552] NET: Registered protocol family 2
[ 0.532837] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes)
[ 0.536566] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.540138] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 0.543680] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.546755] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.549699] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.554587] NET: Registered protocol family 1
[ 0.556672] NET: Registered protocol family 44
[ 0.559096] pci 0000:00:06.0: enabling device (0000 -> 0002)
[ 0.562377] Unpacking initramfs...
[ 1.238020] Freeing initrd memory: 24408K
[ 1.240132] hw perfevents: enabled with armv8_pmuv3_0 PMU driver, 7 counters available
[ 1.243598] kvm [1]: HYP mode not available
[ 1.246519] Initialise system trusted keyrings
[ 1.248669] Key type blacklist registered
[ 1.250661] workingset: timestamp_bits=44 max_order=18 bucket_order=0
[ 1.255769] zbud: loaded
[ 1.463506] Key type asymmetric registered
[ 1.465063] Asymmetric key parser 'x509' registered
[ 1.467758] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.472021] io scheduler noop registered
[ 1.474194] io scheduler deadline registered
[ 1.477242] io scheduler cfq registered (default)
[ 1.479853] io scheduler mq-deadline registered
[ 1.483411] pl061_gpio ARMH0061:00: PL061 GPIO chip @0x0000000009030000 registered
[ 1.488045] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.492390] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 1.497767] ACPI: Power Button [PWRB]
[ 1.500684] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.504222] Serial: AMBA driver
[ 1.505766] msm_serial: driver initialized
[ 1.507747] ACPI PPTT: No PPTT table found, cache topology may be inaccurate
[ 1.510904] ACPI PPTT: No PPTT table found, cache topology may be inaccurate
[ 1.514122] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.516869] mousedev: PS/2 mouse device common for all mice
[ 1.520545] rtc-efi rtc-efi: rtc core: registered rtc-efi as rtc0
[ 1.523749] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.527237] NET: Registered protocol family 10
[ 1.544315] Segment Routing with IPv6
[ 1.546103] mip6: Mobile IPv6
[ 1.547462] NET: Registered protocol family 17
[ 1.549489] mpls_gso: MPLS GSO support
[ 1.551606] registered taskstats version 1
[ 1.553446] Loading compiled-in X.509 certificates
[ 1.601798] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[ 1.606847] Loaded X.509 cert 'Debian Secure Boot Signer: 00a7468def'
[ 1.610753] zswap: loaded using pool lzo/zbud
[ 1.613337] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.617495] rtc-efi rtc-efi: setting system clock to 2020-04-03 09:18:15 UTC (1585905495)
[ 1.625884] Freeing unused kernel memory: 4928K
[ 1.637856] Run /init as init process
[ 1.787616] PCI Interrupt Link [GSI1] enabled at IRQ 36
[ 1.789895] virtio-pci 0000:00:01.0: enabling device (0005 -> 0007)
[ 1.823549] PCI Interrupt Link [GSI2] enabled at IRQ 37
[ 1.835998] ACPI: bus type USB registered
[ 1.836589] virtio-pci 0000:00:02.0: enabling device (0005 -> 0007)
[ 1.837991] usbcore: registered new interface driver usbfs
[ 1.844681] usbcore: registered new interface driver hub
[ 1.848062] usbcore: registered new device driver usb
[ 1.852238] PCI Interrupt Link [GSI3] enabled at IRQ 38
[ 1.855361] virtio-pci 0000:00:03.0: enabling device (0005 -> 0007)
[ 1.864564] PCI Interrupt Link [GSI0] enabled at IRQ 35
[ 1.868239] virtio-pci 0000:00:04.0: enabling device (0005 -> 0007)
[ 1.871804] xhci_hcd 0000:00:06.0: xHCI Host Controller
[ 1.875375] xhci_hcd 0000:00:06.0: new USB bus registered, assigned bus number 1
[ 1.879416] xhci_hcd 0000:00:06.0: hcc params 0x00080001 hci version 0x100 quirks 0x0000000000000010
[ 1.883585] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.884241] virtio-pci 0000:00:05.0: enabling device (0005 -> 0007)
[ 1.886727] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.893996] usb usb1: Product: xHCI Host Controller
[ 1.896318] usb usb1: Manufacturer: Linux 4.19.0-8-arm64 xhci-hcd
[ 1.898974] usb usb1: SerialNumber: 0000:00:06.0
[ 1.901497] hub 1-0:1.0: USB hub found
[ 1.903078] hub 1-0:1.0: 8 ports detected
[ 1.905058] xhci_hcd 0000:00:06.0: xHCI Host Controller
[ 1.907007] xhci_hcd 0000:00:06.0: new USB bus registered, assigned bus number 2
[ 1.910062] xhci_hcd 0000:00:06.0: Host supports USB 3.0 SuperSpeed
[ 1.912466] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.916122] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 1.920017] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.921723] virtio_blk virtio0: [vda] 88080392 512-byte logical blocks (45.1 GB/42.0 GiB)
[ 1.922899] usb usb2: Product: xHCI Host Controller
[ 1.929937] usb usb2: Manufacturer: Linux 4.19.0-8-arm64 xhci-hcd
[ 1.932219] usb usb2: SerialNumber: 0000:00:06.0
[ 1.934223] hub 2-0:1.0: USB hub found
[ 1.935765] hub 2-0:1.0: 8 ports detected
[ 1.952351] SCSI subsystem initialized
[ 1.953264] vda: vda1 vda2
[ 1.959075] scsi host0: Virtio SCSI HBA
[ 1.967763] scsi 0:0:0:0: CD-ROM QEMU QEMU CD-ROM 2.5+ PQ: 0 ANSI: 5
[ 2.051003] random: fast init done
[ 2.106912] sr 0:0:0:0: Power-on or device reset occurred
[ 2.109379] sr 0:0:0:0: [sr0] scsi3-mmc drive: 16x/50x cd/rw xa/form2 cdda tray
[ 2.112850] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.561749] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[ 2.719800] usb 1-1: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
[ 2.722884] usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.725525] usb 1-1: Product: CSR8510 A10
[ 3.149739] usb 1-2: new full-speed USB device number 3 using xhci_hcd
[ 3.299561] usb 1-2: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
[ 3.302686] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 3.305259] usb 1-2: SerialNumber: 32303136-3131-3033-3030-303032363731
[ 3.394834] EXT4-fs (vda2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.620711] systemd[1]: Inserted module 'autofs4'
[ 3.643135] random: crng init done
[ 3.657353] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.670211] systemd[1]: Detected virtualization kvm.
[ 3.673156] systemd[1]: Detected architecture arm64.
[ 3.678846] systemd[1]: Set hostname to <jeedombk>.
[ 4.001237] systemd[1]: /lib/systemd/system/fail2ban.service:12: PIDFile= references path below legacy directory /var/run/, updating /var/run/fail2ban/fail2ban.pid → /run/fail2ban/fail2ban.pid; please update the unit file accordingly.
[ 4.032613] systemd[1]: Reached target System Time Synchronized.
[ 4.035934] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.038581] systemd[1]: Reached target Swap.
[ 4.041803] systemd[1]: Created slice system-getty.slice.
[ 4.044111] systemd[1]: Reached target Remote File Systems.
[ 4.181526] EXT4-fs (vda2): re-mounted. Opts: errors=remount-ro
[ 4.260517] systemd-journald[181]: Received request to flush runtime journal from PID 1
[ 4.634291] cdc_acm 1-2:1.0: ttyACM0: USB ACM device
[ 4.641018] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 4.644715] usbcore: registered new interface driver cdc_acm
[ 4.646775] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 4.702525] EFI Variables Facility v0.08 2004-May-17
[ 4.743486] pstore: Using compression: deflate
[ 4.749209] pstore: Registered efi as persistent store backend
[ 4.756387] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[ 4.831641] cryptd: max_cpu_qlen set to 1000
[ 4.967077] Bluetooth: Core ver 2.22
[ 4.974094] NET: Registered protocol family 31
[ 4.978476] Bluetooth: HCI device and connection manager initialized
[ 4.986246] Bluetooth: HCI socket layer initialized
[ 4.992321] Bluetooth: L2CAP socket layer initialized
[ 5.002141] Bluetooth: SCO socket layer initialized
[ 5.029587] usbcore: registered new interface driver btusb
[ 5.222603] FAT-fs (vda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 5.348434] audit: type=1400 audit(1585905499.228:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=292 comm="apparmor_parser"
[ 5.359121] audit: type=1400 audit(1585905499.228:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=292 comm="apparmor_parser"
[ 5.371091] audit: type=1400 audit(1585905499.228:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=292 comm="apparmor_parser"
[ 5.383889] audit: type=1400 audit(1585905499.228:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=294 comm="apparmor_parser"
[ 5.397988] audit: type=1400 audit(1585905499.228:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=294 comm="apparmor_parser"
[ 5.407907] audit: type=1400 audit(1585905499.264:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ntpd" pid=293 comm="apparmor_parser"
[ 9.284827] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.284830] Bluetooth: BNEP filters: protocol multicast
[ 9.284839] Bluetooth: BNEP socket layer initialized
[ 9.777628] Adding 1048572k swap on /var/swap. Priority:-2 extents:5 across:1212412k FS
[ 116.426155] tun: Universal TUN/TAP device driver, 1.6
