Arret du Erreur - Arret du demon suite apparaige
Bonjour a tous,
Lors de l’appairage mon démon tombe quelques secondes après
Si j’essaie d’appairer 5 GU10 ( spot led ) marque Lidl " en meme temps "
  • J’ai réussi a en appairer 3 mais impossible d’inclure les autres sans planter le démon
Je précise que les 5 ont déjà été appairer mais disparaisse de Z2m après plusieurs jours d’inactivités
VM Freebox Delta : clé zigbee EZSP POP sur port usb unique, dernière maj du plugin
Config du plugin :
Log z2m en debug :
0485|Zigbee2MQTT:info  2023-11-25 12:43:06: Device '0xcc86ecfffe9a2ddf' joined
0486|Zigbee2MQTT:info  2023-11-25 12:43:06: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xcc86ecfffe9a2ddf","ieee_address":"0xcc86ecfffe9a2ddf"},"type":"device_joined"}'
0487|Zigbee2MQTT:info  2023-11-25 12:43:06: MQTT publish: topic 'zigbee2mqtt/0xcc86ecfffe9a2ddf/availability', payload '{"state":"online"}'
0488|Zigbee2MQTT:info  2023-11-25 12:43:06: MQTT publish: topic 'zigbee2mqtt/0xcc86ecfffe9a2ddf', payload '{"brightness":254,"color":{"x":0.3131,"y":0.3232},"color_mode":"color_temp","color_temp":153,"device":{"friendlyName":"0xcc86ecfffe9a2ddf","ieeeAddr":"0xcc86ecfffe9a2ddf","model":"unknown","networkAddress":55101,"type":"Unknown"},"last_seen":"2023-11-25T11:43:06.543Z","linkquality":108,"state":"ON"}'
0489|Zigbee2MQTT:info  2023-11-25 12:43:06: Starting interview of '0xcc86ecfffe9a2ddf'
0490|Zigbee2MQTT:info  2023-11-25 12:43:06: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xcc86ecfffe9a2ddf","ieee_address":"0xcc86ecfffe9a2ddf","status":"started"},"type":"device_interview"}'
0491|Zigbee2MQTT:debug 2023-11-25 12:43:06: Received Zigbee message from 'Inter | Lumiere | Degagement', type 'read', cluster 'genTime', data '["time"]' from endpoint 1 with groupID 0
0492|Zigbee2MQTT:info  2023-11-25 12:43:06: MQTT publish: topic 'zigbee2mqtt/Inter | Lumiere | Degagement', payload '{"device":{"applicationVersion":1,"friendlyName":"Inter | Lumiere | Degagement","ieeeAddr":"0x00158d00029b477b","manufacturerID":4151,"manufacturerName":"LUMI","model":"QBKG04LM","networkAddress":6777,"powerSource":"Battery","type":"EndDevice"},"last_seen":"2023-11-25T11:43:06.755Z","linkquality":200,"state":"OFF"}'
0493|Zigbee2MQTT:info  2023-11-25 12:43:06: MQTT publish: topic 'zigbee2mqtt/0xcc86ecfffe9a2ddf', payload '{"brightness":254,"color":{"x":0.3131,"y":0.3232},"color_mode":"color_temp","color_temp":153,"device":{"friendlyName":"0xcc86ecfffe9a2ddf","ieeeAddr":"0xcc86ecfffe9a2ddf","model":"unknown","networkAddress":55101,"type":"Unknown"},"last_seen":"2023-11-25T11:43:06.759Z","linkquality":108,"state":"ON"}'
0494|Zigbee2MQTT:debug 2023-11-25 12:43:12: Received Zigbee message from 'Inter | Lumiere | Dressing', type 'read', cluster 'genTime', data '["time"]' from endpoint 1 with groupID 0
0495|Zigbee2MQTT:info  2023-11-25 12:43:12: MQTT publish: topic 'zigbee2mqtt/Inter | Lumiere | Dressing', payload '{"device":{"applicationVersion":1,"friendlyName":"Inter | Lumiere | Dressing","ieeeAddr":"0x00158d00029baf02","manufacturerID":4151,"manufacturerName":"LUMI","model":"QBKG04LM","networkAddress":35865,"powerSource":"Battery","type":"EndDevice"},"last_seen":"2023-11-25T11:43:12.386Z","linkquality":204,"operation_mode":"decoupled","state":"ON"}'
0496|Error: {"address":55101,"clusterId":32770,"sequence":221} after 10000ms
0497|at Timeout._onTimeout (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
0498|at listOnTimeout (node:internal/timers:569:17)
0499|at processTimers (node:internal/timers:512:7)
Pour chaque demande d’aide, il faut au minimum:
  • tag du plugin
  • tous les logs
  • page config du plugin
Bonjour iPapy,
j’étais entrain de rédiger, j’ai cliqué trop tôt sur le bouton poster :slight_smile:
J’ai sortie les spot des logements au plafond,
je l’ai ai appairé au coordinateur et pas a tout ou juste au routeur le plus proche
cela n’a pas planté le démon et c’est allé très vite
  • problème de coordination entre les routeurs ?
