Ampoules Wiz : pb affichage retour d'état dans widget
voici un log avec lumière éteinte, état non remonté dans le widget :
0004|[2023-09-26 21:03:37]DEBUG : Cmd : {"method":"getPilot","params":{}}
0005|[2023-09-26 21:03:37]DEBUG :     Receive: {"method":"getPilot","env":"pro","result":{"mac":"a8bb500513af","rssi":-62,"src":"","state":false,"sceneId":0,"r":255,"g":208,"b":0,"c":0,"w":44,"dimming":10}}
0006|[2023-09-26 21:03:37]DEBUG :  state: Array (     [method] => getPilot     [env] => pro     [result] => Array         (             [mac] => a8bb500513af             [rssi] => -62             [src] =>              [state] =>              [sceneId] => 0             [r] => 255             [g] => 208             [b] => 0             [c] => 0             [w] => 44             [dimming] => 10         )  )
0007|[2023-09-26 21:03:37]DEBUG :  state: Array (     [Intensity] => -1     [White] => -1     [White2] => -1     [Color] => #000000     [Hue] => -1     [Prog] => -1     [Speed] => -1     [On] => -1     [Play] => -1     [Saturation] => -1     [Kelvin] => -1     [KelvinVal] => -1     [Connected] => -1     [AmbColor] => -1     [AmbKelvin] => -1     [AmbWhite] => -1     [Eye] => -1     [DiscoNum] => -1     [NightMode] => -1     [EyeNotify] => -1     [CCTAuto] => -1     [AmbIntensity] => -1     [AmbOn] => -1     [Timer] => -1     [Current] => -1     [Power] => -1     [Voltage] => -1     [Led] => -1     [Consommation] => -1     [ConsumptionDay] => -1     [ConsumptionMonth] => -1     [UpDown] => -1     [ModeOn] => -1     [ModeAmb] => -1     [VitHum] => -1     [Eco] => -1     [Locked] => -1     [Auto] => -1     [ConsTemp] => -1     [ConsTempEco] => -1     [ConsTempVac] => -1     [ConsTempComf] => -1     [ConsTempCurrent] => -1     [ValTemp] => zero     [ValTempExt] => zero     [StartState] => -1     [ValHum] => -1     [Impuls] => -1     [Trigger] => -1     [TriggerVal] => -1     [TargetLowAction] => -1     [TargetHighAction] => -1     [TargetLow] => -1     [TargetHigh] => -1     [MultiC] => Array         (         )      [StatDay] => -1     [StatMonth] => -1     [Bat] => -1     [PIR] => -1     [Open] => -1     [CurPosition] => -1     [Position] => -1     [Luminosity] => -1     [Custom] => -1     [ModeCol] => -1     [Detect] => -1     [Type] => 1     [white] => 44     [intensity] => 10 )
mêmes tests
le changement d’état est ok (on et off);
toujours ko pour l’intensité et la couleur (se met à jour 1 fois sur 10 environ, je n’arrive pas à comprendre dans quel cas…)
il me faudrait les mêmes logs quand KO
voici les logs :
[2023-09-27 18:55:35]DEBUG : Cmd : {"method":"getPilot","params":{}}
[2023-09-27 18:55:35]DEBUG :     Receive: {"method":"getPilot","env":"pro","result":{"mac":"a8bb500513af","rssi":-67,"src":"","state":true,"sceneId":19,"dimming":48}}
[2023-09-27 18:55:35]DEBUG :  state: Array (     [method] => getPilot     [env] => pro     [result] => Array         (             [mac] => a8bb500513af             [rssi] => -67             [src] =>              [state] => 1             [sceneId] => 19             [dimming] => 48         )  )
[2023-09-27 18:55:35]DEBUG :  state: Array (     [Intensity] => 48     [White] => -1     [White2] => -1     [Color] => -1     [Hue] => -1     [Prog] => -1     [Speed] => -1     [On] => 1     [Play] => -1     [Saturation] => -1     [Kelvin] => -1     [KelvinVal] => -1     [Connected] => -1     [AmbColor] => -1     [AmbKelvin] => -1     [AmbWhite] => -1     [Eye] => -1     [DiscoNum] => 19     [NightMode] => -1     [EyeNotify] => -1     [CCTAuto] => -1     [AmbIntensity] => -1     [AmbOn] => -1     [Timer] => -1     [Current] => -1     [Power] => -1     [Voltage] => -1     [Led] => -1     [Consommation] => -1     [ConsumptionDay] => -1     [ConsumptionMonth] => -1     [UpDown] => -1     [ModeOn] => -1     [ModeAmb] => -1     [VitHum] => -1     [Eco] => -1     [Locked] => -1     [Auto] => -1     [ConsTemp] => -1     [ConsTempEco] => -1     [ConsTempVac] => -1     [ConsTempComf] => -1     [ConsTempCurrent] => -1     [ValTemp] => zero     [ValTempExt] => zero     [StartState] => -1     [ValHum] => -1     [Impuls] => -1     [Trigger] => -1     [TriggerVal] => -1     [TargetLowAction] => -1     [TargetHighAction] => -1     [TargetLow] => -1     [TargetHigh] => -1     [MultiC] => Array         (         )      [StatDay] => -1     [StatMonth] => -1     [Bat] => -1     [PIR] => -1     [Open] => -1     [CurPosition] => -1     [Position] => -1     [Luminosity] => -1     [Custom] => -1     [ModeCol] => -1     [Detect] => -1     [Type] => 1 )
et qu’est ce qui ne fonctionne pas ?
le retour d’état ne contient que l’ata ON/Off et dimming mis dans intensity qui normalement est mis à jour
le slider d’intensité du widget ainsi que la couleur ne se mettent à jour que de temps en temps lorsque je les modifie via l’application Wiz, comme ici à 21:21:48. Les infos retournées ne semblent pas toujours les mêmes (dans les logs),
0464|[2023-09-27 21:19:13][DEBUG] : Cmd : {"method":"getPilot","params":{}}
0465|[2023-09-27 21:19:13][DEBUG] :     Receive: {"method":"getPilot","env":"pro","result":{"mac":"a8bb500513af","rssi":-68,"src":"","state":true,"sceneId":0,"r":0,"g":3,"b":255,"c":0,"w":69,"dimming":48}}
0466|[2023-09-27 21:19:13][DEBUG] :  state: Array (     [method] => getPilot     [env] => pro     [result] => Array         (             [mac] => a8bb500513af             [rssi] => -68             [src] =>              [state] => 1             [sceneId] => 0             [r] => 0             [g] => 3             [b] => 255             [c] => 0             [w] => 69             [dimming] => 48         )  )
0467|[2023-09-27 21:19:13][DEBUG] :  state: Array (     [Intensity] => 48     [White] => 69     [White2] => -1     [Color] => -1     [Hue] => -1     [Prog] => -1     [Speed] => -1     [On] => 1     [Play] => -1     [Saturation] => -1     [Kelvin] => -1     [KelvinVal] => -1     [Connected] => -1     [AmbColor] => -1     [AmbKelvin] => -1     [AmbWhite] => -1     [Eye] => -1     [DiscoNum] => -1     [NightMode] => -1     [EyeNotify] => -1     [CCTAuto] => -1     [AmbIntensity] => -1     [AmbOn] => -1     [Timer] => -1     [Current] => -1     [Power] => -1     [Voltage] => -1     [Led] => -1     [Consommation] => -1     [ConsumptionDay] => -1     [ConsumptionMonth] => -1     [UpDown] => -1     [ModeOn] => -1     [ModeAmb] => -1     [VitHum] => -1     [Eco] => -1     [Locked] => -1     [Auto] => -1     [ConsTemp] => -1     [ConsTempEco] => -1     [ConsTempVac] => -1     [ConsTempComf] => -1     [ConsTempCurrent] => -1     [ValTemp] => zero     [ValTempExt] => zero     [StartState] => -1     [ValHum] => -1     [Impuls] => -1     [Trigger] => -1     [TriggerVal] => -1     [TargetLowAction] => -1     [TargetHighAction] => -1     [TargetLow] => -1     [TargetHigh] => -1     [MultiC] => Array         (         )      [StatDay] => -1     [StatMonth] => -1     [Bat] => -1     [PIR] => -1     [Open] => -1     [CurPosition] => -1     [Position] => -1     [Luminosity] => -1     [Custom] => -1     [ModeCol] => -1     [Detect] => -1     [Type] => 1 )
0468|[2023-09-27 21:19:44][DEBUG] : Cmd : {"method":"getPilot","params":{}}
0469|[2023-09-27 21:19:44][DEBUG] :     Receive: {"method":"getPilot","env":"pro","result":{"mac":"a8bb500513af","rssi":-68,"src":"","state":true,"sceneId":0,"r":0,"g":3,"b":255,"c":0,"w":69,"dimming":48}}
0470|[2023-09-27 21:19:44][DEBUG] :  state: Array (     [method] => getPilot     [env] => pro     [result] => Array         (             [mac] => a8bb500513af             [rssi] => -68             [src] =>              [state] => 1             [sceneId] => 0             [r] => 0             [g] => 3             [b] => 255             [c] => 0             [w] => 69             [dimming] => 48         )  )
0471|[2023-09-27 21:19:44][DEBUG] :  state: Array (     [Intensity] => 48     [White] => 69     [White2] => -1     [Color] => -1     [Hue] => -1     [Prog] => -1     [Speed] => -1     [On] => 1     [Play] => -1     [Saturation] => -1     [Kelvin] => -1     [KelvinVal] => -1     [Connected] => -1     [AmbColor] => -1     [AmbKelvin] => -1     [AmbWhite] => -1     [Eye] => -1     [DiscoNum] => -1     [NightMode] => -1     [EyeNotify] => -1     [CCTAuto] => -1     [AmbIntensity] => -1     [AmbOn] => -1     [Timer] => -1     [Current] => -1     [Power] => -1     [Voltage] => -1     [Led] => -1     [Consommation] => -1     [ConsumptionDay] => -1     [ConsumptionMonth] => -1     [UpDown] => -1     [ModeOn] => -1     [ModeAmb] => -1     [VitHum] => -1     [Eco] => -1     [Locked] => -1     [Auto] => -1     [ConsTemp] => -1     [ConsTempEco] => -1     [ConsTempVac] => -1     [ConsTempComf] => -1     [ConsTempCurrent] => -1     [ValTemp] => zero     [ValTempExt] => zero     [StartState] => -1     [ValHum] => -1     [Impuls] => -1     [Trigger] => -1     [TriggerVal] => -1     [TargetLowAction] => -1     [TargetHighAction] => -1     [TargetLow] => -1     [TargetHigh] => -1     [MultiC] => Array         (         )      [StatDay] => -1     [StatMonth] => -1     [Bat] => -1     [PIR] => -1     [Open] => -1     [CurPosition] => -1     [Position] => -1     [Luminosity] => -1     [Custom] => -1     [ModeCol] => -1     [Detect] => -1     [Type] => 1 )
0472|[2023-09-27 21:20:15][DEBUG] : Cmd : {"method":"getPilot","params":{}}
0473|[2023-09-27 21:20:15][DEBUG] :     Receive: {"method":"getPilot","env":"pro","result":{"mac":"a8bb500513af","rssi":-69,"src":"","state":true,"sceneId":0,"r":0,"g":255,"b":248,"c":0,"w":92,"dimming":13}}
0474|[2023-09-27 21:20:15][DEBUG] :  state: Array (     [method] => getPilot     [env] => pro     [result] => Array         (             [mac] => a8bb500513af             [rssi] => -69             [src] =>              [state] => 1             [sceneId] => 0             [r] => 0             [g] => 255             [b] => 248             [c] => 0             [w] => 92             [dimming] => 13         )  )
0475|[2023-09-27 21:20:15][DEBUG] :  state: Array (     [Intensity] => 13     [White] => 92     [White2] => -1     [Color] => -1     [Hue] => -1     [Prog] => -1     [Speed] => -1     [On] => 1     [Play] => -1     [Saturation] => -1     [Kelvin] => -1     [KelvinVal] => -1     [Connected] => -1     [AmbColor] => -1     [AmbKelvin] => -1     [AmbWhite] => -1     [Eye] => -1     [DiscoNum] => -1     [NightMode] => -1     [EyeNotify] => -1     [CCTAuto] => -1     [AmbIntensity] => -1     [AmbOn] => -1     [Timer] => -1     [Current] => -1     [Power] => -1     [Voltage] => -1     [Led] => -1     [Consommation] => -1     [ConsumptionDay] => -1     [ConsumptionMonth] => -1     [UpDown] => -1     [ModeOn] => -1     [ModeAmb] => -1     [VitHum] => -1     [Eco] => -1     [Locked] => -1     [Auto] => -1     [ConsTemp] => -1     [ConsTempEco] => -1     [ConsTempVac] => -1     [ConsTempComf] => -1     [ConsTempCurrent] => -1     [ValTemp] => zero     [ValTempExt] => zero     [StartState] => -1     [ValHum] => -1     [Impuls] => -1     [Trigger] => -1     [TriggerVal] => -1     [TargetLowAction] => -1     [TargetHighAction] => -1     [TargetLow] => -1     [TargetHigh] => -1     [MultiC] => Array         (         )      [StatDay] => -1     [StatMonth] => -1     [Bat] => -1     [PIR] => -1     [Open] => -1     [CurPosition] => -1     [Position] => -1     [Luminosity] => -1     [Custom] => -1     [ModeCol] => -1     [Detect] => -1     [Type] => 1 )
0476|[2023-09-27 21:20:46][DEBUG] : Cmd : {"method":"getPilot","params":{}}
0477|[2023-09-27 21:20:46][DEBUG] :     Receive: {"method":"getPilot","env":"pro","result":{"mac":"a8bb500513af","rssi":-69,"src":"","state":true,"sceneId":0,"r":0,"g":255,"b":248,"c":0,"w":92,"dimming":13}}
0478|[2023-09-27 21:20:46][DEBUG] :  state: Array (     [method] => getPilot     [env] => pro     [result] => Array         (             [mac] => a8bb500513af             [rssi] => -69             [src] =>              [state] => 1             [sceneId] => 0             [r] => 0             [g] => 255             [b] => 248             [c] => 0             [w] => 92             [dimming] => 13         )  )
0479|[2023-09-27 21:20:46][DEBUG] :  state: Array (     [Intensity] => 13     [White] => 92     [White2] => -1     [Color] => -1     [Hue] => -1     [Prog] => -1     [Speed] => -1     [On] => 1     [Play] => -1     [Saturation] => -1     [Kelvin] => -1     [KelvinVal] => -1     [Connected] => -1     [AmbColor] => -1     [AmbKelvin] => -1     [AmbWhite] => -1     [Eye] => -1     [DiscoNum] => -1     [NightMode] => -1     [EyeNotify] => -1     [CCTAuto] => -1     [AmbIntensity] => -1     [AmbOn] => -1     [Timer] => -1     [Current] => -1     [Power] => -1     [Voltage] => -1     [Led] => -1     [Consommation] => -1     [ConsumptionDay] => -1     [ConsumptionMonth] => -1     [UpDown] => -1     [ModeOn] => -1     [ModeAmb] => -1     [VitHum] => -1     [Eco] => -1     [Locked] => -1     [Auto] => -1     [ConsTemp] => -1     [ConsTempEco] => -1     [ConsTempVac] => -1     [ConsTempComf] => -1     [ConsTempCurrent] => -1     [ValTemp] => zero     [ValTempExt] => zero     [StartState] => -1     [ValHum] => -1     [Impuls] => -1     [Trigger] => -1     [TriggerVal] => -1     [TargetLowAction] => -1     [TargetHighAction] => -1     [TargetLow] => -1     [TargetHigh] => -1     [MultiC] => Array         (         )      [StatDay] => -1     [StatMonth] => -1     [Bat] => -1     [PIR] => -1     [Open] => -1     [CurPosition] => -1     [Position] => -1     [Luminosity] => -1     [Custom] => -1     [ModeCol] => -1     [Detect] => -1     [Type] => 1 )
0480|[2023-09-27 21:21:17][DEBUG] : Cmd : {"method":"getPilot","params":{}}
0481|[2023-09-27 21:21:17][DEBUG] :     Receive: {"method":"getPilot","env":"pro","result":{"mac":"a8bb500513af","rssi":-69,"src":"","state":true,"sceneId":0,"r":0,"g":255,"b":248,"c":0,"w":92,"dimming":13}}
0482|[2023-09-27 21:21:17][DEBUG] :  state: Array (     [method] => getPilot     [env] => pro     [result] => Array         (             [mac] => a8bb500513af             [rssi] => -69             [src] =>              [state] => 1             [sceneId] => 0             [r] => 0             [g] => 255             [b] => 248             [c] => 0             [w] => 92             [dimming] => 13         )  )
0483|[2023-09-27 21:21:17][DEBUG] :  state: Array (     [Intensity] => 13     [White] => 92     [White2] => -1     [Color] => -1     [Hue] => -1     [Prog] => -1     [Speed] => -1     [On] => 1     [Play] => -1     [Saturation] => -1     [Kelvin] => -1     [KelvinVal] => -1     [Connected] => -1     [AmbColor] => -1     [AmbKelvin] => -1     [AmbWhite] => -1     [Eye] => -1     [DiscoNum] => -1     [NightMode] => -1     [EyeNotify] => -1     [CCTAuto] => -1     [AmbIntensity] => -1     [AmbOn] => -1     [Timer] => -1     [Current] => -1     [Power] => -1     [Voltage] => -1     [Led] => -1     [Consommation] => -1     [ConsumptionDay] => -1     [ConsumptionMonth] => -1     [UpDown] => -1     [ModeOn] => -1     [ModeAmb] => -1     [VitHum] => -1     [Eco] => -1     [Locked] => -1     [Auto] => -1     [ConsTemp] => -1     [ConsTempEco] => -1     [ConsTempVac] => -1     [ConsTempComf] => -1     [ConsTempCurrent] => -1     [ValTemp] => zero     [ValTempExt] => zero     [StartState] => -1     [ValHum] => -1     [Impuls] => -1     [Trigger] => -1     [TriggerVal] => -1     [TargetLowAction] => -1     [TargetHighAction] => -1     [TargetLow] => -1     [TargetHigh] => -1     [MultiC] => Array         (         )      [StatDay] => -1     [StatMonth] => -1     [Bat] => -1     [PIR] => -1     [Open] => -1     [CurPosition] => -1     [Position] => -1     [Luminosity] => -1     [Custom] => -1     [ModeCol] => -1     [Detect] => -1     [Type] => 1 )
0484|[2023-09-27 21:21:48][DEBUG] : Cmd : {"method":"getPilot","params":{}}
0485|[2023-09-27 21:21:48][DEBUG] :     Receive: {"method":"getPilot","env":"pro","result":{"mac":"a8bb500513af","rssi":-68,"src":"","state":true,"sceneId":0,"r":255,"g":52,"b":0,"c":0,"w":75,"dimming":13}}
0486|[2023-09-27 21:21:48][DEBUG] :  state: Array (     [method] => getPilot     [env] => pro     [result] => Array         (             [mac] => a8bb500513af             [rssi] => -68             [src] =>              [state] => 1             [sceneId] => 0             [r] => 255             [g] => 52             [b] => 0             [c] => 0             [w] => 75             [dimming] => 13         )  )
0487|[2023-09-27 21:21:48][DEBUG] :  state: Array (     [Intensity] => 13     [White] => 75     [White2] => -1     [Color] => #ff3400     [Hue] => -1     [Prog] => -1     [Speed] => -1     [On] => 1     [Play] => -1     [Saturation] => -1     [Kelvin] => -1     [KelvinVal] => -1     [Connected] => -1     [AmbColor] => -1     [AmbKelvin] => -1     [AmbWhite] => -1     [Eye] => -1     [DiscoNum] => -1     [NightMode] => -1     [EyeNotify] => -1     [CCTAuto] => -1     [AmbIntensity] => -1     [AmbOn] => -1     [Timer] => -1     [Current] => -1     [Power] => -1     [Voltage] => -1     [Led] => -1     [Consommation] => -1     [ConsumptionDay] => -1     [ConsumptionMonth] => -1     [UpDown] => -1     [ModeOn] => -1     [ModeAmb] => -1     [VitHum] => -1     [Eco] => -1     [Locked] => -1     [Auto] => -1     [ConsTemp] => -1     [ConsTempEco] => -1     [ConsTempVac] => -1     [ConsTempComf] => -1     [ConsTempCurrent] => -1     [ValTemp] => zero     [ValTempExt] => zero     [StartState] => -1     [ValHum] => -1     [Impuls] => -1     [Trigger] => -1     [TriggerVal] => -1     [TargetLowAction] => -1     [TargetHighAction] => -1     [TargetLow] => -1     [TargetHigh] => -1     [MultiC] => Array         (         )      [StatDay] => -1     [StatMonth] => -1     [Bat] => -1     [PIR] => -1     [Open] => -1     [CurPosition] => -1     [Position] => -1     [Luminosity] => -1     [Custom] => -1     [ModeCol] => -1     [Detect] => -1     [Type] => 1 )
mêmes tests nouvelle beta
ça m’a l’air beaucoup mieux (il faudra que je fasse quelques tests complémentaires ce soir…).
Merci beaucoup pour le temps passé en débugage !
Après quelques tests complémentaires, je confirme que le plugin est désormais pleinement fonctionnel avec les ampoules Wiz.
et met solution !
La prochaine stable intègrera les modifications.
Merci à toi !
