Amelioration plugin-zigbee
Je teste le plugin zigbee avec des ampoules ali.
Elles remontent sans constructeur ni rien mais remonté bien sous deconz et sous jmqtt.
    "ieee": "00:12:4b:00:22:6d:5f:63",
    "nwk": 63251,
    "status": 2,
    "lqi": "247",
    "rssi": "-63",
    "last_seen": "1617869876.0697794",
    "node_descriptor": "01:40:8e:00:00:50:a0:00:00:00:a0:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 528,
            "profile_id": 49246,
            "manufacturer": "eWeLight",
            "model": "ZB-CL01",
            "output_clusters": [],
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 4,
                            "name": "manufacturer",
                            "value": "eWeLight"
                            "id": 5,
                            "name": "model",
                            "value": "ZB-CL01"
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
                    "id": 8,
                    "name": "Level control",
                    "attributes": []
                    "id": 768,
                    "name": "Color Control",
                    "attributes": []
            "id": 13,
            "status": 1,
            "device_type": 57694,
            "manufacturer": null,
            "model": null,
                    "id": 4096,
                    "name": "LightLink",
                    "attributes": []
            "input_clusters": [
                    "id": 4096,
                    "attributes": []
    "signature": {
        "model": "ZB-CL01",
        "node_desc": {
            "byte1": 1,
            "byte2": 64,
            "mac_capability_flags": 142,
            "manufacturer_code": 0,
            "maximum_buffer_size": 80,
            "maximum_incoming_transfer_size": 160,
            "server_mask": 0,
            "maximum_outgoing_transfer_size": 160,
        "endpoints": {
            "1": {
                "device_type": 528,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    8,
                    768
            "13": {
                "input_clusters": [
                    4096
                    4096
    "class": "zigpy.device"
Voici le json brute.
Et en complément les infos jmqtt
Friendly name 0x00124b00226d5f63
Device type Router
Zigbee model ZB-CL01
Description Zigbee 3.0 LED-bulb, RGBW LED
Support status Supported
IEEE address 0x00124b00226d5f63
Network address 0xF713
Firmware build date 20201216
Firmware version 1.0.13
Vendor Lonsonho
Model ZB-RGBCW
Power source Interview completed
J’en ai 5 qui viennent de vendeurs différent mais toujours de Ali, elles sont toute de la même marque et sur les boites, compatible Hue.
l’ampoule apparait maintenant dans le choix mais les commandes ne fonctionne pas. seulement le changement de couleur.
Voici le message d’erreur :
Erreur lors de la requete : http://127.0.0.1:8080/device/command(PUT), data : {"ieee":"00:12:4b:00:22:6d:5f:63","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"Device not found","code":0}
J’ai effectivement le même problème de mon coté, ces ampoules ne sont pas reconnues par le plugin ZigBee.
