Sous ESXi 6.7, VM avec Debian 12 installée.
J’installe Jeedom Alpha 4.4 comme suit :
wget https://raw.githubusercontent.com/jeedom/core/alpha/install/install.sh
chmod +x install.sh
./install.sh -v alpha
L’installation se passe bien jusqu’à la dernière étape.
Néanmoins après le reboot à la fin de l’install j’ai :
fail2ban hs
# systemctl status fail2ban
× fail2ban.service - Fail2Ban Service
Loaded: loaded (/lib/systemd/system/fail2ban.service; enabled; preset: enabled)
Drop-In: /usr/lib/systemd/system/fail2ban.service.d
└─override.conf
Active: failed (Result: exit-code) since Fri 2023-09-01 11:03:18 CEST; 5min ago
Duration: 263ms
Docs: man:fail2ban(1)
Process: 1417 ExecStart=/usr/bin/fail2ban-server -xf start (code=exited, status=255/EXCEPTION)
Main PID: 1417 (code=exited, status=255/EXCEPTION)
CPU: 241ms
sept. 01 11:03:18 Jeedom systemd[1]: Started fail2ban.service - Fail2Ban Service.
sept. 01 11:03:18 Jeedom fail2ban-server[1417]: 2023-09-01 11:03:18,209 fail2ban.configreader [1417]: WARNING 'allowipv6' not defined in 'Definition'. Using default one: 'auto'
sept. 01 11:03:18 Jeedom fail2ban-server[1417]: 2023-09-01 11:03:18,253 fail2ban [1417]: ERROR Failed during configuration: Have not found any log file for sshd jail
sept. 01 11:03:18 Jeedom fail2ban-server[1417]: 2023-09-01 11:03:18,261 fail2ban [1417]: ERROR Async configuration of server failed
sept. 01 11:03:18 Jeedom systemd[1]: fail2ban.service: Main process exited, code=exited, status=255/EXCEPTION
sept. 01 11:03:18 Jeedom systemd[1]: fail2ban.service: Failed with result 'exit-code'.
De plus dans Chrome si je rentre l’adresse IP de cette VM pour avoir Jeedom, cela ne fonctionne pas.
HTTP error 500.
un systemctl me donne ceci
apache2.service loaded active running The Apache HTTP Server
apparmor.service loaded active exited Load AppArmor profiles
atd.service loaded active running Deferred execution scheduler
avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack
console-setup.service loaded active exited Set console font and keymap
cron.service loaded active running Regular background program processing daemon
dbus.service loaded active running D-Bus System Message Bus
exim4.service loaded active running LSB: exim Mail Transport Agent
● fail2ban.service loaded failed failed Fail2Ban Service
getty@tty1.service loaded active running Getty on tty1
ifup@ens192.service loaded active exited ifup for ens192
ifupdown-pre.service loaded active exited Helper to synchronize boot up for ifupdown
keyboard-setup.service loaded active exited Set the console keyboard layout
kmod-static-nodes.service loaded active exited Create List of Static Device Nodes
mariadb.service loaded active running MariaDB 10.11.3 database server
ModemManager.service loaded active running Modem Manager
networking.service loaded active exited Raise network interfaces
ntpsec.service loaded active running Network Time Service
open-vm-tools.service loaded active running Service for virtual machines hosted on VMware
polkit.service loaded active running Authorization Manager
ssh.service loaded active running OpenBSD Secure Shell server
systemd-binfmt.service loaded active exited Set Up Additional Binary Formats
systemd-journal-flush.service loaded active exited Flush Journal to Persistent Storage
La j’avoue que je ne sais pas trop quoi faire pour résoudre le souci
