Le soucis c’est que trouver c’est possible mais ca me prendrais trop de temps… Avec la 4.2 et tous le reste autour je peux pas passer autant de temps sur ce thermostat (qui n’est meme pas encore sortie en plus)
Ok, ça ce comprend merci quand même pour cette intégration.
J’avais zappé la température actuelle dans mon dernier json… dsl j’ai fait le boulet si tu peux repousser celui ci
"name": "Sunricher.ZG9092",
"configuration": {
"heating": [],
"cooling": [],
"stoping": [],
"window": [],
"failure": [],
"failureActuator": [],
"orderChange": [],
"existingMode": []
"commands": [
"logicalId": "1::513::0",
"generic_type": "THERMOSTAT_TEMPERATURE",
"name": "Température",
"type": "info",
"subType": "numeric",
"isHistorized": "1",
"unite": "°C",
"configuration": {
"repeatEventManagement": "never",
"calculValueOffset": "#value# \/ 100",
"historizeRound": "1"
"isVisible": "1"
"logicalId": "1::513::18",
"generic_type": "THERMOSTAT_SETPOINT",
"name": "Consigne ",
"type": "info",
"isHistorized": "0",
"unite": "°C",
"configuration": {
"template": {
"dashboard": "core::default",
"mobile": "core::default"
"isVisible": "0"
"logicalId": "attributes::1::in::513::18::#slider#*100",
"generic_type": "THERMOSTAT_SET_SETPOINT",
"name": "Regalge consigne",
"type": "action",
"subType": "slider",
"unite": "°C",
"configuration": {
"minValue": "6",
"maxValue": "28"
"template": {
"dashboard": "core::button",
"mobile": "core::button"
"value": "Consigne ",
"isVisible": "1"
"logicalId": "1::513::20",
"name": "Consigne Hors Gel",
"type": "info",
"configuration": {
"isVisible": "1"
"logicalId": "1::513::8194",
"name": "Etat Hors Gel",
"type": "info",
"subType": "string",
"template": {
"isVisible": "1"
"logicalId": "attributes::1::in::513::20::#slider#",
"name": "Réglage Consigne Hors Gel",
"type": "action",
"configuration": {
"minValue": "0",
"maxValue": "15",
"calculValueOffset": "#value#*100",
"actionConfirm": "0"
"template": {
"value": "Consigne Hors Gel",
"isVisible": "1"
"logicalId": "1::513::28",
"generic_type": "THERMOSTAT_STATE_NAME",
"name": "Mode ",
"type": "info",
"template": {
"isVisible": "1"
"logicalId": "attributes::1::in::513::28::0",
"name": "Arrêt",
"type": "action",
"subType": "other",
"template": {
"value": "Mode ",
"isVisible": "1"
"logicalId": "attributes::1::in::513::28::1",
"name": "Auto",
"type": "action",
"subType": "other",
"template": {
"value": "Mode ",
"isVisible": "1"
"logicalId": "attributes::1::in::513::28::4",
"name": "Manu",
"type": "action",
"subType": "other",
"template": {
"value": "Mode ",
"isVisible": "1"
"logicalId": "attributes::1::in::513::28::8",
"name": "Dry",
"type": "action",
"subType": "other",
"template": {
"value": "Mode ",
"isVisible": "1"
"logicalId": "attributes::1::in::513::8194::1",
"name": "Hors Gel",
"type": "action",
"subType": "other",
"template": {
"isVisible": "1"
"logicalId": "1::513::41",
"name": "Etat Chauffage",
"type": "info",
"configuration": {
"minValue": "0",
"maxValue": "1"
"template": {
"isVisible": "1"
"logicalId": "1::513::16",
"name": "Etat Compensation",
"type": "info",
"unite": "°C",
"configuration": {
"minValue": "-30",
"maxValue": "30"
"template": {
"isVisible": "1"
"logicalId": "attributes::1::in::513::16::#slider#",
"name": "Compensation",
"type": "action",
"configuration": {
"minValue": "-30",
"maxValue": "30",
"lastCmdValue": "0.0"
"template": {
"value": "Etat Compensation",
"isVisible": "1"
"logicalId": "1::2820::1291",
"generic_type": "POWER",
"name": "Puissance ",
"type": "info",
"unite": "W",
"configuration": {
"historizeRound": 2,
"calculValueOffset": "#value# \/ 10"
"template": {
"isVisible": "1"
"logicalId": "1::1794::0",
"generic_type": "CONSUMPTION",
"name": "Consommation",
"type": "info",
"unite": "kWh",
"configuration": {
"calculValueOffset": "#value# \/ 1000"
"template": {
"isVisible": "1"
"ref": "Sunricher.ZG9092"
Merci pour le retour ca sera dans la beta de demain
