Bonjour @Loic ,
Merci de bien vouloir intégrer le module suivant:
Interrupteur simple MOES ZTS-EU
Lien: https://zigbee.blakadder.com/Moes_ZTS-EU1-W.html
Image:
JSON
"ieee": "60:a4:23:ff:fe:aa:f7:2f",
"nwk": 58976,
"status": 2,
"lqi": "136",
"rssi": "-66",
"last_seen": "1619174396.9358752",
"node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 81,
"profile_id": 260,
"manufacturer": "_TZE200_amp6tsvy",
"model": "TS0601",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 66
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZE200_amp6tsvy"
"id": 5,
"name": "model",
"value": "TS0601"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 3
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 61184,
"name": "Cluster",
"attributes": []
"signature": {
"model": "TS0601",
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
0,
4,
5,
61184
25,
10
"class": "zigpy.device"
Debug
[2021-04-23 13:19:45][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"372":{"value":"0","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=78, command_id=372, function=0, data=[1, 0])","cluster_name":"Tuya Manufacturer Specicific"}]},"516":{"20480":{"value":"0","cluster_name":"Thermostat User Interface Configuration"}}}}}}
[2021-04-23 13:19:45][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::372 => 0
[2021-04-23 13:19:45][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::0 => 1
[2021-04-23 13:19:45][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=78, command_id=372, function=0, data=[1, 0])
[2021-04-23 13:19:45][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::516::20480 => 0
[2021-04-23 13:19:50][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"629":{"value":"5","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=79, command_id=629, function=0, data=[4, 0, 0, 0, 5])","cluster_name":"Tuya Manufacturer Specicific"}]},"513":{"16391":{"value":"5","cluster_name":"MoesThermostat"}}}}}}
[2021-04-23 13:19:50][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::629 => 5
[2021-04-23 13:19:50][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::0 => 1
[2021-04-23 13:19:50][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=79, command_id=629, function=0, data=[4, 0, 0, 0, 5])
[2021-04-23 13:19:50][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16391 => 5
[2021-04-23 13:21:34][DEBUG] : [2021-04-23 13:24:35][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"614":{"value":"5","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=82, command_id=615, function=0, data=[4, 0, 0, 0, 27])","cluster_name":"Tuya Manufacturer Specicific"}],"615":{"value":"27","cluster_name":"Tuya Manufacturer Specicific"}},"513":{"21":{"value":"500","cluster_name":"MoesThermostat"},"22":{"value":"2700","cluster_name":"MoesThermostat"}}}}}}
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::614 => 5
[2021-04-23 13:24:35][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::0 => 1
[2021-04-23 13:24:35][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=82, command_id=615, function=0, data=[4, 0, 0, 0, 27])
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::615 => 27
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::21 => 500
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::22 => 2700
[2021-04-23 13:24:35][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"514":{"value":"200","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=83, command_id=514, function=0, data=[4, 0, 0, 0, 200])","cluster_name":"Tuya Manufacturer Specicific"}]},"513":{"18":{"value":"2000","cluster_name":"MoesThermostat"}}}}}}
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::514 => 200
[2021-04-23 13:24:35][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=83, command_id=514, function=0, data=[4, 0, 0, 0, 200])
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::18 => 2000
[2021-04-23 13:24:35][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"1028":{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=84, command_id=1028, function=0, data=[1, 1])","cluster_name":"Tuya Manufacturer Specicific"}]},"513":{"16386":{"value":"1","cluster_name":"MoesThermostat"},"37":{"value":"ProgrammingOperationMode.Schedule_programming_mode","cluster_name":"MoesThermostat"},"2":{"value":"Occupancy.Occupied","cluster_name":"MoesThermostat"}}}}}}
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::1028 => 1
[2021-04-23 13:24:35][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=84, command_id=1028, function=0, data=[1, 1])
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16386 => 1
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::37 => ProgrammingOperationMode.Schedule_programming_mode
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::2 => Occupancy.Occupied
[2021-04-23 13:24:35][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"1028":{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=85, command_id=1028, function=0, data=[1, 1])","cluster_name":"Tuya Manufacturer Specicific"}]},"513":{"16386":{"value":"1","cluster_name":"MoesThermostat"},"37":{"value":"ProgrammingOperationMode.Schedule_programming_mode","cluster_name":"MoesThermostat"},"2":{"value":"Occupancy.Occupied","cluster_name":"MoesThermostat"}}}}}}
[2021-04-23 13:24:35][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=85, command_id=1028, function=0, data=[1, 1])
[2021-04-23 13:24:35][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"263":{"value":"0","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=86, command_id=263, function=0, data=[1, 0])","cluster_name":"Tuya Manufacturer Specicific"}]},"516":{"1":{"value":"KeypadLockout.No_lockout","cluster_name":"Thermostat User Interface Configuration"}}}}}}
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::263 => 0
[2021-04-23 13:24:35][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=86, command_id=263, function=0, data=[1, 0])
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::516::1 => KeypadLockout.No_lockout
[2021-04-23 13:24:35][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=87, command_id=1293, function=0, data=[1, 0])","cluster_name":"Tuya Manufacturer Specicific"}]}}}}}
[2021-04-23 13:24:35][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=87, command_id=1293, function=0, data=[1, 0])
[2021-04-23 13:24:35][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"556":{"value":"0","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=88, command_id=556, function=0, data=[4, 0, 0, 0, 0])","cluster_name":"Tuya Manufacturer Specicific"}]},"513":{"16":{"value":"0","cluster_name":"MoesThermostat"}}}}}}
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::556 => 0
[2021-04-23 13:24:35][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=88, command_id=556, function=0, data=[4, 0, 0, 0, 0])
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16 => 0
[2021-04-23 13:24:35][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"104":{"value":"[10, 5, 1]","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=89, command_id=104, function=0, data=[3, 1, 5, 10])","cluster_name":"Tuya Manufacturer Specicific"}]},"6":{"24577":{"value":"10","cluster_name":"On\/Off"},"24576":{"value":"500","cluster_name":"On\/Off"},"0":{"value":"1","cluster_name":"On\/Off"}}}}}}
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::104 => [10, 5, 1]
[2021-04-23 13:24:35][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=89, command_id=104, function=0, data=[3, 1, 5, 10])
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::6::24577 => 10
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::6::24576 => 500
[2021-04-23 13:24:35][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::6::0 => 1
[2021-04-23 13:24:41][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"617":{"value":"300","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=91, command_id=1130, function=0, data=[1, 0])","cluster_name":"Tuya Manufacturer Specicific"}],"1130":{"value":"0","cluster_name":"Tuya Manufacturer Specicific"}},"513":{"16389":{"value":"300","cluster_name":"MoesThermostat"},"16390":{"value":"0","cluster_name":"MoesThermostat"}}}}}}
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::617 => 300
[2021-04-23 13:24:41][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::0 => 1
[2021-04-23 13:24:41][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=91, command_id=1130, function=0, data=[1, 0])
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::1130 => 0
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16389 => 300
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16390 => 0
[2021-04-23 13:24:41][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"619":{"value":"21","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=92, command_id=619, function=0, data=[4, 0, 0, 0, 21])","cluster_name":"Tuya Manufacturer Specicific"}]},"513":{"16384":{"value":"2100","cluster_name":"MoesThermostat"}}}}}}
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::619 => 21
[2021-04-23 13:24:41][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=92, command_id=619, function=0, data=[4, 0, 0, 0, 21])
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16384 => 2100
[2021-04-23 13:24:41][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"620":{"value":"17","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=93, command_id=620, function=0, data=[4, 0, 0, 0, 17])","cluster_name":"Tuya Manufacturer Specicific"}]},"513":{"16385":{"value":"1700","cluster_name":"MoesThermostat"}}}}}}
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::620 => 17
[2021-04-23 13:24:41][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=93, command_id=620, function=0, data=[4, 0, 0, 0, 17])
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16385 => 1700
[2021-04-23 13:24:41][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"621":{"value":"50","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=96, command_id=1135, function=0, data=[1, 0])","cluster_name":"Tuya Manufacturer Specicific"}],"366":{"value":"0","cluster_name":"Tuya Manufacturer Specicific"},"1135":{"value":"0","cluster_name":"Tuya Manufacturer Specicific"}},"513":{"16388":{"value":"50","cluster_name":"MoesThermostat"},"30":{"value":"RunningMode.Heat","cluster_name":"MoesThermostat"},"41":{"value":"RunningState.Heat_State_On","cluster_name":"MoesThermostat"},"16387":{"value":"0","cluster_name":"MoesThermostat"}},"1":{"33":{"value":"200","cluster_name":"Power Configuration"}}}}}}
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::621 => 50
[2021-04-23 13:24:41][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=96, command_id=1135, function=0, data=[1, 0])
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::366 => 0
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::1135 => 0
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16388 => 50
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::30 => RunningMode.Heat
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::41 => RunningState.Heat_State_On
[2021-04-23 13:24:41][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16387 => 0
[2021-04-23 13:24:42][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"112":{"value":"[17, 0, 22, 20, 0, 19, 18, 18, 14, 22, 31, 12, 20, 0, 136, 22, 0, 6]","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=97, command_id=112, function=0, data=[18, 6, 0, 22, 136, 0, 20, 12, 31, 22, 14, 18, 18, 19, 0, 20, 22, 0, 17])","cluster_name":"Tuya Manufacturer Specicific"}]},"513":{"16656":{"value":"6","cluster_name":"MoesThermostat"},"16657":{"value":"0","cluster_name":"MoesThermostat"},"16658":{"value":"2200","cluster_name":"MoesThermostat"},"16672":{"value":"8","cluster_name":"MoesThermostat"},"16673":{"value":"0","cluster_name":"MoesThermostat"},"16674":{"value":"2000","cluster_name":"MoesThermostat"},"16688":{"value":"12","cluster_name":"MoesThermostat"},"16689":{"value":"31","cluster_name":"MoesThermostat"},"16690":{"value":"2200","cluster_name":"MoesThermostat"},"16704":{"value":"14","cluster_name":"MoesThermostat"},"16705":{"value":"18","cluster_name":"MoesThermostat"},"16706":{"value":"1800","cluster_name":"MoesThermostat"},"16720":{"value":"19","cluster_name":"MoesThermostat"},"16721":{"value":"0","cluster_name":"MoesThermostat"},"16722":{"value":"2000","cluster_name":"MoesThermostat"},"16736":{"value":"22","cluster_name":"MoesThermostat"},"16737":{"value":"0","cluster_name":"MoesThermostat"},"16738":{"value":"1700","cluster_name":"MoesThermostat"}}}}}}
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::112 => [17, 0, 22, 20, 0, 19, 18, 18, 14, 22, 31, 12, 20, 0, 136, 22, 0, 6]
[2021-04-23 13:24:42][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::0 => 1
[2021-04-23 13:24:42][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=97, command_id=112, function=0, data=[18, 6, 0, 22, 136, 0, 20, 12, 31, 22, 14, 18, 18, 19, 0, 20, 22, 0, 17])
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16656 => 6
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16657 => 0
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16658 => 2200
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16672 => 8
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16673 => 0
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16674 => 2000
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16688 => 12
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16689 => 31
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16690 => 2200
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16704 => 14
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16705 => 18
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16706 => 1800
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16720 => 19
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16721 => 0
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16722 => 2000
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16736 => 22
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16737 => 0
[2021-04-23 13:24:42][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16738 => 1700
[2021-04-23 13:24:47][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"113":{"value":"[17, 0, 22, 19, 30, 17, 18, 30, 12, 19, 30, 11, 19, 0, 11, 20, 0, 9]","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=99, command_id=626, function=0, data=[4, 0, 0, 0, 10])","cluster_name":"Tuya Manufacturer Specicific"}],"626":{"value":"10","cluster_name":"Tuya Manufacturer Specicific"}},"513":{"16912":{"value":"9","cluster_name":"MoesThermostat"},"16913":{"value":"0","cluster_name":"MoesThermostat"},"16914":{"value":"2000","cluster_name":"MoesThermostat"},"16928":{"value":"11","cluster_name":"MoesThermostat"},"16929":{"value":"0","cluster_name":"MoesThermostat"},"16930":{"value":"1900","cluster_name":"MoesThermostat"},"16944":{"value":"11","cluster_name":"MoesThermostat"},"16945":{"value":"30","cluster_name":"MoesThermostat"},"16946":{"value":"1900","cluster_name":"MoesThermostat"},"16960":{"value":"12","cluster_name":"MoesThermostat"},"16961":{"value":"30","cluster_name":"MoesThermostat"},"16962":{"value":"1800","cluster_name":"MoesThermostat"},"16976":{"value":"17","cluster_name":"MoesThermostat"},"16977":{"value":"30","cluster_name":"MoesThermostat"},"16978":{"value":"1900","cluster_name":"MoesThermostat"},"16992":{"value":"22","cluster_name":"MoesThermostat"},"16993":{"value":"0","cluster_name":"MoesThermostat"},"16994":{"value":"1700","cluster_name":"MoesThermostat"},"20":{"value":"1000","cluster_name":"MoesThermostat"}}}}}}
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::113 => [17, 0, 22, 19, 30, 17, 18, 30, 12, 19, 30, 11, 19, 0, 11, 20, 0, 9]
[2021-04-23 13:24:47][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::0 => 1
[2021-04-23 13:24:47][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=99, command_id=626, function=0, data=[4, 0, 0, 0, 10])
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::626 => 10
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16912 => 9
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16913 => 0
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16914 => 2000
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16928 => 11
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16929 => 0
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16930 => 1900
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16944 => 11
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16945 => 30
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16946 => 1900
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16960 => 12
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16961 => 30
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16962 => 1800
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16976 => 17
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16977 => 30
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16978 => 1900
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16992 => 22
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16993 => 0
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::16994 => 1700
[2021-04-23 13:24:47][DEBUG] : Search attribut for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::513::20 => 1000
[2021-04-23 13:24:47][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=100, command_id=371, function=0, data=[1, 0])","cluster_name":"Tuya Manufacturer Specicific"}]}}}}}
[2021-04-23 13:24:47][DEBUG] : Search command for 60:a4:23:ff:fe:a7:e3:8d logicalId : 1::61184::cmd::1 => Command(status=158, tsn=100, command_id=371, function=0, data=[1, 0])
[2021-04-23 13:24:52][DEBUG] : {"devices":{"60:a4:23:ff:fe:a7:e3:8d":{"1":{"61184":{"372":{"value":"0","cluster_name":"Tuya Manufacturer Specicific"},"cmd":[{"value":"1","cluster_name":"Tuya Manufacturer Specicific"},{"value":"Command(status=158, tsn=102, command_id=629, function=0, data=[4, 0, 0, 0, 5])","cluster_name":"Tuya Manufacturer Specicific"}],"629":{"value":"5","cluster_name":"Tuya Manufacturer Specicific"}},"516":{"20480":{"value":"0","cluster_name":"Thermostat User Interface Configuration"}},"513":{"16391":{"value":"5","cluster_name":"MoesThermostat"}}}}}}
