Ajout module tuya zigbee contact de porte
J’ai acheté des modules Tuya TS0203
Tuya_TS0203_
lien → https://fr.aliexpress.com/item/1005003570500522.html?spm=a2g0o.order_list.0.0.3fea5e5bmNiKTD&gatewayAdapt=glo2fra
J’ai essayé les modules TS0203 de la liste Tuya mais il ne j’ai un erreur de com sur le debug Zigbee ci-dessous et le module ne fonctionne pas.
2022-05-17 12:56:14][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2022-05-17 12:56:14][DEBUG] : {"ieee":"a4:c1:38:07:2b:6e:aa:36","endpoint":1,"cluster":1280,"cluster_type":"in","attributes":[2,2],"allowCache":0}
[2022-05-17 12:56:24][INFO] : [Salon][TZ3000_n2egfsli.TS0203_1] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"a4:c1:38:07:2b:6e:aa:36","endpoint":1,"cluster":1280,"cluster_type":"in","attributes":[2,2],"allowCache":0} erreur : {"state":"error","result":"[0x9d0f:1:0x0500]: Message send failure","code":0}
[2022-05-17 12:56:24][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2022-05-17 12:56:24][DEBUG] : {"ieee":"a4:c1:38:07:2b:6e:aa:36","endpoint":0,"cluster":1280,"cluster_type":"in","attributes":[2],"allowCache":0}
[2022-05-17 12:56:24][INFO] : [Salon][TZ3000_n2egfsli.TS0203_1] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"a4:c1:38:07:2b:6e:aa:36","endpoint":0,"cluster":1280,"cluster_type":"in","attributes":[2],"allowCache":0} erreur : {"state":"error","result":"No such 'in_clusters' ZDO command","code":0}
et les infos brutes du modules sont
    "ieee": "a4:c1:38:07:2b:6e:aa:36",
    "nwk": 40207,
    "status": 2,
    "lqi": "None",
    "rssi": "None",
    "last_seen": "1652386740.508",
    "node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 1026,
            "profile_id": 260,
            "manufacturer": "_TZ3000_n2egfsli",
            "model": "TS0203",
            "output_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
                    "id": 8,
                    "name": "Level control",
                    "attributes": []
                    "id": 4096,
                    "name": "LightLink",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": []
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 1280,
                    "name": "IAS Zone",
                    "attributes": [
                            "id": 2,
                            "name": "zone_status",
                            "value": 1
                            "id": 16,
                            "name": "cie_addr",
                            "value": "00:21:2e:ff:ff:06:99:61"
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 69
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_n2egfsli"
                            "id": 5,
                            "name": "model",
                            "value": "TS0203"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
    "signature": {
        "model": "TS0203",
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "input_clusters": [
                    1,
                    3,
                    1280,
                    0
                    3,
                    4,
                    5,
                    6,
                    8,
                    4096,
                    25,
                    10
    "class": "zigpy.device"
merci d’avance pour votre aide
repasse en inclusion sur le plugin et recommence l’appairage.
Merci pour votre réponse.
Après plusieurs essais d’appairage, le module communique afin. Le module choisi dans la liste est celui-ci :
C’est logique que tu as du choisir ce module dans la liste déroulante car c’est celui que tu as acheté .
:v: si ça fonctionne !
Oui, j’ai préféré préciser le module car il existe deux TS0203 dans la liste Tuya et ce qui les différencie c’est l’adresse de l’info d’ouverture dans la page de config des commandes.
Ok je regarde demain car dans les équipements compatibles avec le plugin Zigbee je ne vois qu’un seul équipement de cette référence.
Je parlais de la liste qui est dans les paramètres généraux de l’équipement. Ci-dessous le second module TS0203 qui ne fonctionne pas avec les miens.
